Question about Vornado VH2 Compact Heater
I have a Vornado VH2 portable heater. The fan has quit working.
When you first turn it on, the fan tries to move, ever so slowly, but never gets going. Sometimes it still heats up and other times I get nothing, no heat and no fan. What do I need to replace? Is it worth it or just buy a new one?
  • 59 Answers
Generaly a problem like this ocures because of gummed up bearings
1.take apart heater
2.remove fan
3.wipe of bearings
4.lightly oil bearings and shaft around bearings ## TO MUCH OIL COULD POSE A FIRE HAZARD :0
5.asemble
6.test
Posted on Jan 19, 2009
My Vornado VH2 heater stops heating several moments after switching on. The fan runs but no heat. The heating elements never get hot but all the wiring appears to be firmly in place. The tilt shutoff...
A big problem with these heaters ans well as others is the motor driving the fan. The bearings get stiff from dirt and do not spin fast enough activating the over temp device of the heating element. Check the motor out by placing the unit in fan mode them pull the plug or turn off looking at the fan to see how many revolutions is makes with no power applied. It should rotate like five times or more indicating freeness. If it hals to a stop immediately after power is removed the motor bearings are tight.
If your handy you take apart and oil the shafts using 3inone motor lube. Clean the motor of dust and dirt drop a few drops on the shafts near the bearings then work it in by hand rotating the blades. Do this a few times reassemble then ler ripp!!!
Feb 15, 2011 | Vornado VH2 Compact Heater
When I turn on Vornado the fan blades turn slowly on all 3 speeds. The blades spins freely, no friction.
The issue may be something called a capacitor these are little boxes with two wires coming out of them these can easily be ordered online for a fair price
Jan 02, 2011 | Vornado CR1-0052-02 Floor / Box Fan
Vornado VH2 heater appears to switch on, but fan and heating element no longer come on. Any solutions?
For some reason the re-set system had clicked off. Unplugged the unit for a while, and when plugged back in it was working once again.
Dec 22, 2009 | Vornado VH2 Compact Heater
Does not turn on
This is a pretty common issue with these heaters. The switch can easily be replaced by opening the unit and swapping out the switch assembly. One switch I have found that works well and is reatively inexpensive (under $4) is the one from Radio Shack (P# 275-0020) which is a 16A 125VAC illuminated round rocker switch. Unlike the OEM one that drops in, the RS one is a panel type which you will have to screw into place. The whole procedure shouldn't take you more than 15min.
Dec 21, 2009 | Vornado VH2 Compact Heater
I need a new on/off switch
I have the same problem with a VH Vornado heater
No need to change switch.
The switch has to sets of contacts, but uses only one. This one is burnt out
Just reconnect the black cable (hot) to the opposite free switch connector.
Then interchange the white (resistance) with the brown cable (ground for switch light)
You may have to turn around the switch because the heater will turn on on the "OFF" position
Check your cables with tester, to avoid any short circuit.
Dec 15, 2009 | Vornado REH1-0001-01 VortexHeat Compact...
Vornado dvth lights are on but no fan
I would call Vornado at 1-800-234-0604. They have great customer service- and usually have really good warranties with their products. I bet they can get you figured out. Any time I have had any questions, they have been very helpful. Vornado is also on Twitter, by the way - so if you "tweet" then some people ask questions via twitter too. I have always had good luck with their fans...
Mar 01, 2009 | Vornado DVTH Compact Heater
The fan has quit on my Vornado VH2 portable heater.
take apart the heater clean the bearings, and oil the shaft around the berings lightly with all purpass oil
Jan 19, 2009 | Vornado VH2 Compact Heater
Vornado VH2 stopped working. on/off not functioning
if it is a rocker type switch replace the swich
IMPORTAINT make shure switch it is replaced with is rated at 15Amps
Jan 08, 2009 | Vornado VH2 Compact Heater
Motor stopped
hi,
you can try and oil it, unplug it and begin taking it apart, your destination is the fan motor, dust around the motor and I would recommend using regular automotive 10w30 motor oil on that motor, put some in a small bowl and use a small baster or equivalent and oil around both ends of the motor shaft(where it protrudes from the motor) behind the fan blades and behind it, look closely with a flashlight where the motor attatches to the back guard. try get some oil in there and within the motor housing to the inner bearing areas if possible. My guess is that its sealed from the factory, but you can try, those fans are the best on the market and have a long warranty, heres a link to the manual
http://www.vornado.com/manuals/allcirc.pdf
J
Aug 05, 2008 | Vornado Circulating Fan
Varnado EH1-020 VH2 blows cold air or wont stay on
THERE IS A LIMIT SWITCH THAT REGULATES HOW LONG THE HEAT STAYS ON SOUNDS LIKE THIS LIMIT SWITCH WHENT BAD MOST ITEMS LIKE THIS HAVE A FACTORY WARRANTY THAT COVERS THIS ISSUE MY RECCOMENDATION IS TO TAKE IT BACK TO WARE YOU BOUGHT IT OR IF YOU LIKE TAKE IT APART WHILE IT IS UNPLUGGED AND LOOK FOR A LITTLE DEVICE THAT BREAKS ONE WIRE TO YOUR HEATER ELEMENT AND TRY TO MATCH IT UP AND REPLACE IT.
Dec 27, 2007 | Vornado EH1-0020-01 Compact Heater
Vornado VH2 Compact Heater Logo
538 people viewed this question
Top Vornado Heating & Cooling Experts
Bill Long
Lyle Siemens
Lyle Siemens
Roberto Lopez
Level 1 Expert
Are you a Vornado Heating and Cooling Expert? Answer questions, earn points and help others
