In philips ctv model 21PT2216 tv goes to standby position while turnedon n
While the set turns on it goes to standby position within five seconds
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Do a hard reset to this TV and check whether it help you. To make it a had reset, unplug it from AC mains wall socket, and re-plug it back after 10 minutes or so. If this do not help you, the main system memory IC to your TV must be replaced.
Posted on Jan 05, 2013
wooger
  • 9 Answers
SOURCE: Philips wide screen TV
OK sorted the problem on my set. Replaced the capacitor ref: 2455 on main board it is a 47uf 25v but i was told a 35v will work as well? But mine is a 28pw6506/05
Posted on Nov 17, 2007
SOURCE: New tv won't set up channels
We are returning the tv to RCA and getting our money back.
Posted on Apr 18, 2008
SOURCE: philips tv
I have a 32 inch phillips tv that I bought from someone else and it has a child lock code on certain channels. How do I get this code off.
Posted on Jul 15, 2008
jingjao
  • 252 Answers
SOURCE: Sony Trinitron KV-32FS12
i think your tv had a lose contact or crack on board
Posted on Oct 18, 2008
ginko
  • 19396 Answers
SOURCE: Standby Indicator flashing SONY KD-32NX100U
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Payparticular attention at inverter and power board, power board can beinspected looking for bulged or leaking capacitors, then tested with amultimeter. The inverter is more difficult to test , there is need toread voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
I have a Philips plasma TV Model 42pf9952/12s and the problem is it starts for some seconds then suddenly it goes to standby.
No mystery, set is not making it on and shutdown circuit takes over, shop repair and may not be worth the cost of that repair.
Sep 04, 2012 | Samsung Televison & Video
My sony kp-51ws510 color rear video projector tv when i turn it on it stays on for abt five seconds and then turns off and also the timer and standby light is flashing red
this model did have problems with bad picture tubes---screen goes bright red,green,blue and set shuts down.
set also does this to protect itself---when fails look to see if specific sequence of blinks
Apr 17, 2012 | Televison & Video
Remote code of 21pt2216/94 philips
Yes it worked for me by doing blw :
Press : 062596 & menu button to open service menu.
Then change blw values on option tab :
op1 : 128op2 : 215op3 : 065op4 : 000op5 : 192op6 : 129op7 : 112
then press menu button & power button on remote & plug-out the main cable from power socket for 10 seconds.
Then switch on the unit for result...............
Jul 22, 2009 | Televison & Video
My TV is going into standby mode whenever it is turned on
My screen turns black and the TV goes into standby mode (I get an Amber Light) within 3 seconds after turning the TV on.
Dec 16, 2008 | Televison & Video
21pt2216/94 phillips 21'' audio problem
your speaker maybe busted or check the amplifier IC
Oct 22, 2008 | Televison & Video
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
