Whirlpool Ultimate Care II Washer - not spinning
  • Washing Mach... Master
  • 17,170 Answers
This could several things. It could be the wires to the motor, it could be the the transmission
Posted on Jan 05, 2013
honeymokey
  • 3113 Answers
SOURCE: Whirlpool Ultimate Care II washer fills with water and stops
Lid switch. Push down on lid.
Posted on Jun 18, 2009
IFIXALL
  • 868 Answers
SOURCE: whirlpool ultimate care 2 washer wont spin
Are you in the Delicate Cycle? Do you have spin speed control set for slow?If both answers are no,than what is the model & serial number??
Posted on May 21, 2008
mikedurland
  • 481 Answers
SOURCE: Whirlpool Ultimate Care II Plus Washer Model: LSQ9264HZ0
if you hear the motor running while it is supposed to be agitating or spinning then it is most likely the direct drive coupling between the motor and transmission.43f18ab.jpg9bd1c44.jpg if you already checked this and think it is a different problem then let me know, i will help you figure it out.  Mike
Posted on Jul 15, 2008
reg501
  • 413 Answers
SOURCE: Whirlpool Ultimate Care II washer won't spin clothes more dry than soggy
Tip the washer backward, inspect the bottom of the gearcase for oil. If oil is present, the oil has migrated to the clutch causing it to slip during spin. The gearcase and clutch will have to be replaced if oil is present. Check the owners manual for limited warranty on the gearcase. If oil is not present, the clutch is just worn and should be replaced.
Posted on Oct 05, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care Heavy Duty Washer will not spin
It sounds like you have a broken motor coupling. This is a very inexpensive and simple repair.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Posted on Jul 23, 2009
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    Washer will not spin.
    May be the coupler between the motor and the transmission.
    Sep 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Does not spin or empty
    it might be jammed or there might be dirt or some sort of a clog. I would suggest you clean it out.
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool washer ultimate care II sometimes does not spin.
    HI It sounds like the spin basket drive is going bad. If it was the lid switch, you would get no sound. Let me know if I can assist you further.
    Thanks
    Vic
    May 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Oct 04, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool ultimate care 2 washer wont spin
    Apr 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool Ultimate Care II washing maching but will not spin.
    lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
    Dec 03, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washing Machines Logo
    867 people viewed this question
    Top Washing Machines Experts
