Question about Belling 924 Dual Fuel (Electric and Gas) Kitchen Range
Diagram of the rear of a range cooker
Im trying to conect my cooker to the electric supply
Looking for a circuit diagram
It's usually und the console. A Google search on how to remove the console for your particular make will give you specific instructions.
Mar 07, 2015 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Total electrical output
Bad news really, the supply cable you have there is not going to be capable of supply to any type of electric oven and hob like you listed above. Your supply cable is possibly only 2.5mm in size, and not the required 6mm with a much higher MCB at the fuseboard. Get a registered electrician to run a new cable from the board to your cooking area. A single oven takes about 3.2Kw adding the hob rings will take way over your limit. Curry's listing of that cooker as a load of .75Kw or thereabouts is obviously incorrect.
Jan 15, 2014 | Ovens
Wiring diagram for my creda concept solar plus cooker
Request the wiring diagram directly from Creda.
Feb 23, 2018 | Crock Pots & Slow Cookers
Hi, I have a Rangemaster 110 (electric double oven), which has a double grill. Unfortunately one half of the grill has blown - not working. Is it easy to repair? Thanks a lot - Krisztina
Usually fairly straight forward. Remove the blown element being careful not to loose the wires into the void behind the grill. Insert new element making sure the orientation and wires are conected as the original was.
Dec 28, 2010 | Rangemaster Range Cookers Kitchener 110...
Ignition wont work, there is an electrical supply to the cooker
yes there will be a cooker switch located somewhere in the kitchen & from that there will be a supply to a cooker point witch is a white box that is no bigger than a single socket.
there should or should have been a 10mm heat resistant flex running from that to your cooker.
if there is a flex then your ignition mite run off a 3volt battery.check your manual if not then try this web site :
http://www.rangecookers.co.uk/installation-guide-content,MGQJD.aspx
Jul 02, 2009 | Rangemaster Classic 90 (Electric) Kitchen...
Conection of a beko electric cooker
Pretty normal problem with Beko.
You need a Philips 2 screwdriver to get a suitable grip on the screwhead.
Good Luck!
Nov 26, 2008 | Ovens
I need to wire up the electrics on a gas cooker
the oven should have a flex already fitted, this will need to be plugged in or connected in to a supply ensuring it is correctly fused, i suggest no more than 3 amp.
Oct 05, 2008 | Parkinson Cowan SG340 Gas Kitchen Range
Cooker keeps tripping the electricity supply.
If the main oven is electric, disconnect the heater element and try, if no trip operqates. then replace element.
Nov 22, 2007 | Belling CookCenter 151 Dual Fuel (Electric...
Kitchen cooker
The green wire is the ground,
the white wire is the common,
the red and black wires are the 240 volts (hot) wires)
Nov 15, 2007 | KitchenAid KESC308LSS Electric Kitchen...
Range master toledo 90
I would follow these requirements if I were you:
The cooker must be connected to the correct electrical supply as stated on the voltage label on the cooker (This is obvious so far!). It should be connected through a suitable cooker control unit incorporating a double pole switch having a contact separation of at least 3mm in all poles (This means one of those big red switches with "COOKER" written on them). The cooker must NOT be connected to an ordinary domestic power point. The cable size used should be between 6mm squared and 10mm squared twin and earth. Where the installation is protected by a 30 milliamp sensitivity residual current device (RCD Breaker), the combined use of your cooker and other domestic appliances may occasionally cause nuisance tripping. In these instances, the cooker circuit may need to be protected by fitting a 100 milliamp device. This work should be carried out by a qualified electrician.
Oct 28, 2007 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Belling 924 Dual Fuel (Electric and Gas) Kitchen Range Logo
22 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
