Question about Onkyo Txnr809 Tx-nr809 Hdmi Board
Missing hdmi board - Onkyo Txnr809 Tx-nr809 Hdmi Board
Sony klv32Bx350 red colour missing
Please Do the following steps to get a solution.
Reset the TV to the Factory Default mode. and play a high contrast RGB color flashing flashing video through USB.
It could solve your red color missing problems.
if not solved then ask a technical expert.
Thanks.
Aug 17, 2017 | Sony Televison & Video
Only a single "HDMI" appears along with TV, AV input options. Tried turning it on and off and keeping it off for a few hours, but the same issue persists. Please help?
Input selector IC at its main board is faulty. Contact any service technician to replace it. This is not a user repairable one. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 15, 2016 | LG Televison & Video
How do I fix my Element 55" LCD TV?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jan 23, 2015 | Element Televison & Video
Marantz SR7005 not working.
I have the same receiver SR7005 and the HDMI board went out. The boards are on back order and weren't expected to ship for a month or so. Magnolia, the store where I purchased it gave me a new receiver. I think they might be having issues with this board. The board went out on 4/30/12, just got my new receiver 6/21/12. I have a feeling that this will happen again and others will have the same issue. All you need is a new HDMI board, the processor went out in it.
May 23, 2012 | Marantz Sr 7005 7.1 Channel 195 Watt...
Problem with Samsung LNR408D 40 in. HDTV LCD Television Broken HDMI port HDMI port in rear of TV seems to be no longer connected to board. How much would that cost to get fixed and/or how easy is it to...
After you are sure you have hooked up the receiver to the TV properly and with the proper setting in the menu, if you are still having problems then you need to change the main board (the one with all the jacks on it). You will have to take the back from off the set. You will have to get the number from off the board itself and it should start with BN94-. Do a search on ebay with the part number or go to shop jimmy.com for price and availability. Also try to google search. The board is easy to change just unplug and unscrew from the panel.
Nov 07, 2011 | Samsung LN-R408D 40 in. LCD HDTV
It turns on flashes green then turns off
Missing some cable connection between
boards. Check cable.
If all cable intact connected try-unplugging cable one by one then power ON. Plug back unplug other one. Start from cable, which attached to HDMi board.
Oct 02, 2011 | Denon AVR-887
HDMI/ DVI inputs failed approx. one month after connection of Denon home theater receiver with HDMI pass-through feature "on." Gear successfully re-connected via component video...
hi welcome to fixya
i want to clarify first the problem sir so as of now the problem with your tv won't power on then you are using again the old main board is that right ? when you use the new replacement main board the tv is functioning will the only problem is that the HDMI / DVI inputs doesn't work. and now you encountered power supply problem like won't start up or something that cut the supply in which the stand by indicator is turn off so as my idea it has a problem with the old board. but before you come up with the board making sure all the connectors coming from the power supply is properly connected to the main board as will as flexible and lvds cable for the T-con board is properly inserted.just let me know if is that what you are asking for so i can give you additional solution thanks for consulting the fixya.
Aug 30, 2011 | Televison & Video
This is my first build and fired it up but no display on monitor. Neither hdmi or VGA. what could i be missing?
Check to see if the red jumper for the Bios is jumper to the normal two pins 2-3 and the board like this ram 1Gb OCZ Platinum DDR3-1333 make sure they are plugged in tight. Make sure the video is plugged in tight if you are using external video.
Feb 19, 2011 | Biostar A880G+ AMD 880G Socket AM3 mATX...
When I connect my Laptop to a Philips lcd tv via HDMI cable, the video is ok but the sound is missing.
Hey FixYa
Thank you for your answer.
My problem is that my graphic board in my HP Pavilion Laptop dos not support sound from the HDMI output, only video. That was the reason
why i could not hear anything from my Philips lcd TV.
I wish you all a happy New Year.
Greetings from sgkbcl
Dec 27, 2009 | Philips 52 In. LCD HDTV
TV Sound
First lets determine where the sound is missing. What are you using for sound. RCA jacks? HDMI cable? If you are using the HDMI cable, please make sure the correct sound is selected in the Cable box. In New York Cable Box, The HDMI sound has to be selected in order to get sound using the HDMI cable. Hoping that all other settings are ok, You may need a new signal board. Part Number BN94-00629R. Average Cost $176.14
Best regards
CircuitCity
Nov 22, 2007 | Samsung LN-R328W 32 in. HD-Ready LCD...
Onkyo Txnr809 Tx-nr809 Hdmi Board Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
