Question about LG LMV2053 Microwave Oven
Buld replaced, now microwave does NOTHING
We tried to replace the buld under the unit, and it broke off in the socket. we got it out, and now the unit will do nothing at all. no lights, no nothing. the fuse is fine and our main breaker is fine. we have seen that you suggest repairing the board and when we search for you on yahoo...we find nothing. please let us know where to go and what to do...the search on yahoo does nothing for us.
  • 105 Answers
It sounds as if an internal fuse has failed. You will need a qualified repairman for this, as ther are no user serviceable parts inside, but there are INSTANTLY LETHAL voltages present, even when the unit is off & unplugged.
Posted on Jul 16, 2007
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
How do I change light bulb under a 2009 ge microwave/model no.lvm1750dm1ww
The range top bulbs can be replaced by removing the screw that holds the glass and frame to the underside of the unit, they swing down, the bulbs usually screw in, the power needs to be turned off by way of unplugging the unit before replacing the bulbs, the interior cavity bulb can be replaced by removing the top grille and accessing the socket assy from the front. Pleazer Appliance...
Dec 22, 2014 | GE Microwave Ovens
Has stopped working. light gone off at same time. plug fuse has not broke. any ideas ?
There is a fuse inside the microwave also.It is a ceramic fuse,usually 15A.It has to be replaced with another ceramic fuse of the same rating.Bear in mind,the fuse blew for a reason,so if it is the interior fuse replace it after a search for a fault.
Dec 17, 2014 | Microwave Ovens
Have a Whirlpool RMC275PD microwave. Light bulb
no, no, no,,,its far to dangerous for you to open up the case of your microwave to change a light buld,,,
dont even think of going in there,,,
inside your microwave there are 1000,s of volts stored up in a capacitor if you tuch it you could kill yourself
have you ever seen a police stun gun working,,
it realy hurts you,,,,,
inside your microwave is the stun guns big brother
it dont just stun you,, it could kill you,,,
thats why you dont go inside it ok,,,
the light buld can be changed from inside the case normaly if it cant be, then drop it in the shop for a repair or use it with out a light in it,,
dont try and kill yourself just for a light buld
Oct 31, 2009 | Whirlpool RMC275PD Microwave Oven
Exact same problem - Needlenose slipped and spark in the socket
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You have a short in one of the door safety switches
There function is prevent the oven to work whit the door open
some are normally close and some normally open when one of then don’t work properly causes a short and blow the main fuse check the all and replace the faulty one but be careful and don’t test the microwave
Whit the cover removed.
Note:
if you have a blown fuse buy several emplacement fuses because my take several trays to fix the problem and you will need more than one fuse.
Jun 08, 2009 | Whirlpool MH1150XMQ Microwave Oven
GE SpaceMaker JVM XL1800
Sounds like the ERC board failed. It maybe covered under warranty, check that first cause a new ERC could cost around $150-$200. Anything electric can cause the .."what the*^&% just happened syndrome.
Dec 09, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Our Expert microwave buld blew and now...nothing
Have you checked the 10 amp internal fuse. It is located where the pwer lead enters underneath the cover
Jun 28, 2007 | LG LMV2053 Microwave Oven
On replacing nite-lite/under hood bulb, 1 lead broke off in the socket
Be sure to disconnect the oven from the power line before removing or installing bulbs or working on it. You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383 We have critical safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Apr 22, 2007 | GE JVM1490 Convection/Microwave Oven
Broken light bulb
First of all, always disconnect the oven from the line before you remove or install bulbs, otherwise, you can damage the control board. We repair them all the time because of this. You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383 We have critical safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Apr 21, 2007 | GE JVM1430 Microwave Oven
LG LMV2053 Microwave Oven Logo
82 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
