Question about Car Audio & Video
I have a auto vision dvd player roof mounted model no 380051700 I am looking to find the wiring and connections for it where can I get them
4 Suggested Answers
SOURCE: Insignia roof mount DVD player for car wont read disc
My Necvox RE9269 Dvd Player Starts And Then Stops In A Moment Then Displays The Message 'NO DISC' Can Anyone Help Please
Posted on Jul 03, 2008
  • 10 Answers
SOURCE: how do you install a roof mounted dvd player in
if you have a light switch at the top you can install it through there if not you can run wires through the roof down to your deck and hook it up through there depends where do you live i could install it for you
Posted on Dec 27, 2009
walesarumi
  • 6993 Answers
SOURCE: I own a XO Vision gx1360d roof mounted DVD player
I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Posted on May 17, 2011
I just bought my car and it has a nesa nscm 1128 ovehead dvd mounted. I can not figure out how it works. No manual. Someone said it works with the radio?
It all depends on what Radio Unit you've got fitted in the car.
Their could be a separate DVD Player mounted somewhere in the Car, possibly in the boot.
If you can look to see if there is a separate DVD Player anywhere and confirm whats the Make & Model No. of your Radio Unit I'l look into it further.
Jul 31, 2011 | Nesa Vision NSCM1128 Car Monitor
For J 9'" roof mount dvd problem
on the unit itself there is a switch for the fm station. look to see what station it is set for and tune your car radio to that station
Apr 08, 2010 | MT&V Dual 7" Headrest Monitors & DVD...
Installing roof mounted dvd system
The door control wire can be picked up from any of the doors light switches in the door jamms.
the ACC+ wire must connect to a source at the fuse panel that has 12 volts to it only when the ignition is turned on.
Mar 31, 2010 | 2003 Chrysler Town & Country
Instruction manual for a Visteon XV101 in car DVD player -
I acn send you a copy of mine if you need.
ferndog8@yahoo.com
Dec 18, 2009 | Visteon Corporation Hdp250 Hd Jump...
WILL A OVERHEAD DVD PLAYER LOOK RIGHT IF I HAVE A SUNROOF.
Plenty of cars have sun roofs and roof mounted DVD players,you just need to look at where youre positioning it in relation to the interior slide sunroof trim so it isnt screwed through mounting DVD,and look at the position in relation to the passengers looking at it
Nov 17, 2009 | 2007 Suzuki XL-7
Xo vision dvd player
hi there
it shouldn't be to hard to install this but it does require cutting a hole in your interior part of roof........a install like this could take anywhere from 30 mins - 1hr for a installer to put it in. to do it yourself it could take 1-3hrs to complete (note for your first time doing this take your time and follow the install manual that will be provided)
Mar 05, 2009 | XO Vision GX1027D Car DVD Player
Help me with back up camera for xo vision xod1740bt
I am just giving a suggestion. I too need to know how to wire this. From what you posted it sounds like you hooked the wire to a constant +12v that is always on. Forgive me if I am wrong. Anyway, Did you connect this wire to rear reverse light power. I think from what you say it is supposed to be connected to the positive side of that light. If this solves your problem can you PLEASE let me know the full details of everything else you hooked up on the circuit to make the backup work. For instance what is the label of the orange wire. TIA.
Jan 13, 2009 | XO Vision XOD1735 Car DVD Player
XOvision DVD/ Tv Tuner
the brake wire is connected to your hand brake to stop you watching tv while you r driving its a safty thing as you have not connected it it might be why you cannt watch tv hope this is of some help
Dec 27, 2007 | XO Vision GX1211 XOVision 12" Roof Mount...
Car Audio & Video Logo
73 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
