Question about Dryers
My maytag quiet series 200 electric dryer will not start.
    Sergeant:
  • 475 Answers
Does it make any noise, did you unplu it then plug it back in, is the outlet woring ok that you have it plug into?
Posted on Jan 05, 2013
SOURCE: Maytag Quiet Series 200 Electric Dryer
I also had a similar problem with my maytag dryer which is 3 1/2 years old. It was the idler lever assembly with pulley. The part number is 11222607JG and the cost is about $20.00. Hope this helps.
Posted on Sep 07, 2009
SOURCE: maytag ensignia electric dryer makes alot if
I had a squirrel(?) stuck in mine! I removed the lint pipe and it was really nasty. Something had chewed through the screen and climbed down the pipe to stay warm?? We live in Minnesota and it was cold as heck. Anyway, Have a shop vac ready, I hope this helps. Remove pipe at the dryer, push start a couple of times and see if anything blows out. K.J.
Posted on Jan 21, 2010
SOURCE: maytag quiet series 100 electric dryer clicking
my dryer clicks on then runs for 30 sec then clicks off and all the lites flash then it stays on the regular lite
Posted on May 16, 2010
richroth
  • 9472 Answers
SOURCE: I have a quiet series
Sounds like your belt broke. Here is a video to show you how to replace it if it is broken.
Here is a link to the part.
Posted on Nov 30, 2010
heatman101
  • 43501 Answers
SOURCE: maytag quiet series 200 electric
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Mar 28, 2011
Maytag quiet series 200 runs, dries but timer does not move and time out.?
Probably the timer motor is broken, or electrical connection bad. Probably need a replacement timer. OR something has wrapped around the dial shaft and is binding the dryer.
Feb 28, 2015 | Maytag Dryers
Maytag quiet series 200 electric dryer the dryer turns on and seems to work correctly but does not dry the clothes does not get warm or even hot
heatman101
Mar 28, 2011 | Dryers
I have a quiet series 200 Maytag dryer. The dryer comes on but the drum does not turn?
Nov 30, 2010 | Maytag PYE2300AY Electric Dryer
My Maytag dryer (model no. 3758AYW) makes a loud humming noise...otherwise it works. Vent was disconnected and it still hums continuously when turned on. This is supposedly a "Quiet Series 200".
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
This often indicates that the motor is going bad...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 17, 2010 | Whirlpool LER5636P Electric Dryer
Apr 04, 2009 | Maytag Dryers
My maytag dryer is blowing cool air
it should be located it a small trap door around the drum either on the side , inside , or on the bottom. to replace it you must remove the screws the hold it in place slide it out remove the wiring and then slide the new one in screw it back in and plug the wires back on it. please make sure during this process the dryer is unpluged from the wall plug. hope it works out for you .
Jan 05, 2009 | Maytag MDE3706 Electric Dryer
NEED HELP WITH WIRING
There should be a diagram inside the back panel
Dec 15, 2007 | Maytag MDE3706 Electric Dryer
Dryers Logo
83 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
