Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Poulan wild thing will not start
Getting spark,gas and compression is fine.been working on it for three days and had it running once for about two minutes any suggestions
  • camaro_hodge Jan 20, 2009
    Model 2375 - having exactly the same problem, and it is day two for me. I replaced fuel lines and cleaned the carb. I am getting fire. I can get it to start for 5 seconds, but then it dies. I can spray it with either and it will start for 5 seconds and then die. Any ideas would be appreciated.
  • viperpier Jan 25, 2009
    i do not know anything at all about saws,but i am kindoff handy. i took the carb off and replaced the gasket with the round metel circle. got me what it is i may assume fuel pump maybe and then i found out what to set the low high setting at or close and it started then started tunning the best i could. today i cut 2 truckloads of wood with it.
Check the fuiel filter in the gas tank, it might be dirty, or need to be replaced
Posted on Jan 22, 2009
My 2006 poulan wild thing chain saw 42cc will not hit at all i am getting fuel
check for spark, if you have spark pour a very small amount of fuel down the spark plug hole, if it runs for a few seconds and stops. You have a fuel problem. If there is no spark, try a new plug, if still no spark you have an electrical problem. All is assuming you have compression. If no compression your motor needs refurbishing.
Oct 23, 2016 | Poulan 18" Wild Thing Chainsaw
40 CC WILD THING POULAN
maybe the thermal sensor in the engine is overheated..it is inthere to keep the engine from frying.
Oct 23, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a wild thing 2375. Was running one day,shut itself off,and has never fired or started since. It has compression,fuel,spark,but will not so much as even pop. Not even on ether. Even local chainsaw...
In my experiance with two-cycles that have spark and fuel usually the missing ingredient is not enough compression. Try taking the piston out of the cylinder and check the condition of the piston ring and cylinder wall. The piston ring cannot be broken, collapsed or 'welded' to the piston which can happen if the saw is run on straight gas. The cylinder wall cannot be scored at all to get the compression levels required for gas with oil mixed in it to burn. One other possibility is that your spark isn't hot enough. Possibly caused by a small piece of carbon stuck in the spark plug or a bad ignition module.
Mar 05, 2012 | Poulan Garden
I have a wild thing. the rope pull starter is very hard to pull. when i take the spark plug out it is easy to pull. the saw was not used for about 4 years until yesterday. it ran for about 45 minutes fine....
one piston ring has expanded now having no or a very fine gap increasing the compression ratio causing this to happen. When the spark plug is removed it is very easy to pull on the cord in any means. A inspection is due of this engine or a new chain saw is needed
Jun 05, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
The spark plug is firing and is getting gas but won't start
It sounds like you have low compression in the engine. I would check the compression it should be 100 psi.
Mar 10, 2011 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
Poulan Wild Thing 18" Gas chain saw starts no problem but it runs for maybe 30 sec. then stops each time. I changed the core same thing.
Do a tune up. It is easy. Just take out the carb and clean with any commercial carb cleaner nad change the spark plug.
Oct 13, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chaged gas and spark plug. Get no combustion
Make sure your getting a spark at the plug. Not much to these machines but verify good spark before anything else.
Nov 07, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
Sep 30, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan Wild Thing starts great but as soon as I try to cut it die
The carb low idle needs to be adjusted this is fairly common among the Poulan chain saws. Once you adjust the low idle from factory setting it will work
Feb 16, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Wild Thing-(18")hard starting
I own the Poulan Chain Saw the Wild Thing. Replaced the spark plug and fuel filter and made a fresh batch of gasoline mix and I am still having a hard time getting it started. I had the exact same problem last fall. Repair shop told me it was flooded. If this is the case how do I resolve the problem. I took the plug out and it was dry.
Thanks,
**** Hansen
Oct 30, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
412 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
