LGX12 mains compartment is broken. Where can I get the part
Mains compartment is broken, can't use av charger
3 Suggested Answers
gpetti2009
  • 92 Answers
SOURCE: my laptop is overheating when plugged into mains.
Could be one of two things the adapter that you are using is not rated for your laptop or you have a loose power port .if you have a test meter set it for 20 volt dc touch the the silver outside contact with the black ground probe and the inside contact with the red positive probe the voltage should match what is labled on the adapter.if not you may have a faulty adapter .if the power port is loose you will have all kind of problem like starting and shuting down after 10 to 20 secounds or blue screen and serious error meassage and the board getting hot and failure .
Posted on Mar 18, 2009
Grrrrrrrr666
  • 114 Answers
SOURCE: I have been given an
I have a T42 here and the AC adapter (genuine IBM) is 16V 3.36A positive center pin
Posted on Jan 04, 2011
My old 611 dosent hold the battery charge for long even though I have put in a new battery
An in car charger will not charge as well as the mains, when charging for the first time you should use the mains, and charge for at least 8 hours. If it didn't charge correctly, it will be the same low charge all the time, as the battery has a memory that makes it charge the same each time. Try charging from the mains, you might be lucky.
May 22, 2012 | Cell Phones
My MW511 won't start
Check the input power is coming or not. Check fuse inside control board & wiring too. If everything ok then it's problem of control board
Oct 14, 2017 | Washing Machines
Works when connected to charger but no power from battery changed battery still the same
if you disconnect the charger and the battery died then that means that your laptop battery is broken and it won't work untill you get a new one.
Apr 10, 2012 | Panasonic Toughbook CF-27 Notebook
Booting up issue
Does it do this with the mains charger connected or only on battery power?
The plugging in the mains charger if not already, wait a couple of minutes and then try switching it on.
If the boots up fine you more than likely have a battery problem.
If it still doesn't start then you either have a power supply problem on the laptop itself or your main charger is faulty and not charging the battery.
You can also remove the battery and try booting it with only the mains charger connect.
Please provide the results of these queries
Mar 19, 2012 | Acer eMachines 520-2890 Notebook
Broken nc10 charger
Depending on what type of plug it is you may be able to change the fuse.
If the fuse has blown then you really need to know why before plugging it back in to the mains. The charger may have a broken wire in the lead that plugs in to the laptop. Usually it happens right near the plug where it gets bent and twisted. It could also be the internal fuse inside the charger box.
If you can't get it tested properly then a new one is your best bet. They are quite cheap on Ebay. Just look for the one for your make and model number and check to make sure the voltage on your chargers label is the same, it's output voltage is probably 19 volts. The voltage must be the same, NOT lower or higher.
Then have a look at the label for the current which is in Amps, something like 3.15Amps. You can buy one with higher current than the one you have but NOT lower than the label says.
Feb 15, 2012 | Samsung NC10 Netbook
I require a mains charger for Tomtom 4n00.001. I need to charge it from home
You can buy a Tomtom main charger but they are fairly expensive.
You can use a Main powered USB charger along with your normal PC Tomtom USB cable: it should ideally be rated at 1 Amp or more.
You might even have a suitable main USB charger on hand now as they often come with generic MP3/MP4 players and some mobile phones: I use my Huawei U8150 or E585 modem charger for that purpose myself!
Hope it helps.
Sep 23, 2011 | Tomtom ONE GPS Receiver
How do i install a car charge for my mag?
Hi
I had one about 15 years ago and it was installed in the car.
The click in base used to charge it has a metal base which can be screwed into place in the vehicle.
The base take's 12 volts from your mains charger, If you still have the full kit supplied with the torch you will have got a lead for connecting the base up to the 12 volt supply.
If you do not have the lead you will have to find a lead with the same connection on the end as the mains one.
You will need to use an in-line car fuse holder with a fuse of 6 amp's size to protect the lead and charger. Observe the polarity of the lead coming from the mains charger and duplicate it with the lead in the car. (reversed polarity will prevent the charger from working.)
In my case I used the cigarette charger supply in the car to power it. (the load is very small)
Regards
Jan 27, 2011 | MagLite - Mag Charger System 110v (M)...
K700i NOT CHARGING
the mains charger may be dead or the charging connector broken, the tiny pins on the connector break easy, common fault on sony ericsson chargers, try using the usb cable if you have one with your pc, when you plug it in, select 'media transfer' and the fone should start charging, if it charges then fone is ok but mains charger is bad, if you cant get it to charge either way then battery may be worn out and needs replacing.
Jan 14, 2011 | Sony Ericsson K700
What does the flashing red light mean?!?
The flashing red probably means that the charger is working correctly and is indeed charging the batteries. The light should turn green when charging is complete after anything from 1 to 16 hours depending on how this charger works.
Do the following test: Fit the charger with your batteries and connect it to the mains. After 1 hour check if there is a detectable temperature rise in the batteries. You can do this without interrupting the charge cycle by touching the cells with the back of your fingers. If the temperature is still low, let it continue for another 15 hours or so, checking every now & then for any temperature increase. Should the temperature rise more than a few degrees, then stop the charging by removing the charger from the mains. Should the red lamp remain flashing after 16 hours, then I suspect you to have a defective charger.
Dec 27, 2010 | Duracell AAA NiMH Battery Charger with 4...
Wont start
I would like to help with your problem, but I will need some more information. What type of iPod do you have, and what type of charger is a 'mains' charger?
Nov 05, 2007 | Apple iPod MP3 Player
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
