Karcher RC3000 Bagless Robotic Vacuum
Problem for Karcher RC3000 Bagless Robotic Vacuum
RC3000 cannot return to the base smoothly
By jackywun on Jun 28, 2007
I found my RC3000 always cannot return to the base on first attempt. It is always 5cm, or even up to 10cm, deviated from the target charge-up metal plates and the sucking hole of the base. It needs to go to and fro in front of the base several times before it can hook up with the base by accident. It seems to me that the RC3000 is not well tuned.
Solution #1
posted on Nov 19, 2008
Not Rated)
kbright1
Rank: Apprentice
Rating: 0%, 0 votes
Mine was doing the same thing.  Turned out to be dust that had gathered inside preventing the electric eyes (ir sensors) from work well.  Carefully using some lock ring pliers turn the three grey fasteners 90 degrees counter clockwise.  Then lift off the yellow top cover.  Using an air hose or soft brush clean the sensors sticking up from the circuit board.  Be careful not to bend the out ones has they are not hard mounted.  The also clean the inside of the IR windows on the yellow top cover.  While your at it take the time to blow out all the dust from the unit.  You should remove the inner screen prior to using compressed air so you can blow out the vac fan itself.  About every six months I do this or when it starts to act weird.  You should blow of all sensors on the base unit also.
Keith
Was this helpful?
Yes
No
Solution #2
posted on Oct 22, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
CHECK TO BE SURE THE RUBBER SWEEP BEHIND THE BRUSH IS COMPLETLY INTACK & BE SURE ALL OTHER BOTTOM PARTS ARE IN CORRECT POSITION ROBERT K
Popular Solutions for Karcher RC3000 Bagless Robotic
Questions and Unsolved Problems for Karcher RC3000 Bagless Robotic
Do you recommend Karcher RC3000 Bagless Robotic Vacuum?
Answer
Answer
hi, I opened my rc3000 to clean the sensor windows from dust, and I noticed that two small springs... (More)
Answer
Hi, about 2 ½ weeks ago I placed my RC3000 in storage in the upstairs unoccupied guest room... (More)
Answer
need a wiring diagram description for a karcher 350 especially the pressure switch
Answer
The robo vacuum was working just fine.  The other morning, I looked at it and there were no... (More)
Answer
I have an oil leak on my Karcher k2.94 Need advice John
Describe your Vacuums problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuum Experts
Top Vacuum Repairmen
in , AK
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
