Question about Konica Minolta DiALTA Di183F Copier
Minolta dilta 183,theres a code j--- varios jam,,what is the solution?
  • Konica Minolta Master
  • 1,294 Answers
Please the precise code .
Posted on Jan 30, 2013
2 Suggested Answers
  • 525 Answers
SOURCE: hi.. please help me.. my minolta dialta 183 is not
C0500: Warm-up failure
Step 1
Check:
Fusing Heater Lamp (H1) turns
ON.
Step 2
Check:
Fusing Heater Lamp (H1) is open-circuited.
<Check Procedure>
Check the resistance across both
ends of the Fusing Heater Lamp
(H1).
The Fusing Heater Lamp is open-circuited
if the resistance is infinity.
Result: YES
Action: Change Fusing Heater Lamp (H1).
Step 3
Check: Thermoswitch 1 (TS1) is operational.
<Check Procedure>
ends of the Thermoswitch 1 (TS1).
The Thermoswitch 1 is open-circuited
Result: NO
Action: Change Thermoswitch 1 (TS1).
Step 4
Check: Fusing Unit Interlock Switch (S2) is
operational.
<Check Procedure>
Check continuity across terminals
when the Fusing Unit Interlock
Switch (S2) is turned ON.
• Across S2-1A and S2-1B
• Across S2-2A and S2-2B
Result: NO
Action: Change Fusing Unit Interlock
Switch (S2).
Result : YES
Action: Change DC Power Supply (PU1).
Step 5
Check: Thermistor (TH1) is open-circuited.
<Check Procedure>
Check the resistance across CN15-2
and CN15-3 on the Fusing Unit side
with CN15 disconnected.
The Thermistor is open-circuited if
Result: YES
Action: Change Thermistor (TH1).
Step 6
Check: The following voltages are supplied
from the Master Board (copier: PWBA).
<Check Procedure>
Check voltage across a Master Board
(copier: PWB-A) pin and GND when
the Power Switch is turned ON.
• Voltage across PJ10A-7 and GND
DC24 V when Fusing Heater Lamp
(H1) is OFF
DC0 V when Fusing Heater Lamp
(H1) is ON
• Voltage across PJ10A-10 and
GND
(H1) is OFF
(H1) is ON
Result: NO
Action: Change Master Board (copier:
PWB-A).
Posted on Oct 08, 2011
Consistent paper jam on konica minolta bizhub c451e
Please look the jam code, then only b easy to provide solution.
To check Jam code follow these steps.
UTILITY-METER COUNT
STOP 00 STOP 01
COUNTER
JAM HISTORY
Here you will find Jam code E.g J2202 like that.
Post again with jam code, I will give u solution
Dec 23, 2016 | Konica Minolta bizhub Office Equipment &...
DIALTA DI 183. What does code CO3FF indicate?
Minolta di183 C03FF
minolta di183 C03FF Go to Adjust Mode 11, change the setting from 0 to 1.
Sep 08, 2015 | Minolta Office Equipment & Supplies
Error code c 145 E ON MINOLTA di 552
Sir/Mam the you have the problem under the Di183 but you have di552 check the 183 no such code Sure it is a Di 552 and code is c145E?
Apr 11, 2014 | Minolta DiALTA Di183 Copier
How do i change the code from 0 to 1 in code error ff c03 in minolta dialta 183
Looks like you have a problem that require machine in adjust mode that enter service mode them press stop start
Oct 29, 2013 | Minolta DiALTA Di183 Copier
Minolta DI 183 error code FFC03
Never seen 5 Letter/number normally it C-13F0 or something like that please check again
Mar 29, 2012 | Minolta DiALTA Di183 Copier
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Paper keeps jamming. we get a partially printed page,then jams about 2/3 of the way and we have to pull it out.
You can avoid most paper jams by correctly loadingpaper and other media in the printer. Tips on how to help prevent paper jams · Do not loadwrinkled, creased, or damp paper. · Make sure thepaper is not buckled in the tray. · Never mixpaper/media types within a single tray. · Flex, fan, andstraighten paper before you load it. · Do not exceed themaximum stack height. · Push all papertrays firmly into the printer after loading them. · Make sure theguides in the trays are positioned snugly against the paper. · Do not remove anypaper trays while a job is printing. Wait for a Load Paper light sequencebefore you remove the tray. See the 'Load Media' section on page 61 of theUser's Guide for more information. · Use onlyrecommended paper. Consult the CardStock & Label Guide on the Lexmark web site for more information aboutwhich paper provides optimum results for your printing environment. For additional assistance, please contact LexmarkTechnical Support.
May 31, 2011 | Lexmark E232 Laser Printer
Please describe code 542-00
SC542: Fusing Temperature Warming-up Error
Definition [A]
The fusing temperature does not reach the fusing standby temperature within
125 seconds after the main power switch is turned on.
Possible Causes
· Fusing thermistor defective or out of position
· Fusing lamp open
· Fusing thermofuse open
· BICU defective
· Power supply board defective
· Poor fusing unit connection
SC543: Fusing Overheat Error 1
possibly a paper jam or thermistors are dirty
Nov 18, 2010 | Ricoh Aficio 450 Copier
I want download drive printer minolta dilta DI183F
You can visit the below mentioned link to download Konica Minolta drivers:
http://kmbs.konicaminolta.us/content/support/supporthome.html
http://www.printcountry.com/drivers/minolta_dialta_di183f_DRIVER_DOWNLOAD.htm
Thanks and regards,
Anil.B.
Sep 24, 2010 | Computers & Internet
MInolta Di 183
Abnormally high toner density detected Black ATDC (auto toner density control circuit)
Replace black IU, check toner motors, make sure toner is loose not clumpy. Change dev reset toner level.
Thanks.
Mar 25, 2009 | Minolta DiALTA Di183 Copier
Konica Minolta DiALTA Di183F Copier Logo
24 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
