Question about NEC 1GB Workstation WA2510 667MHz RDIMM
After power on, NEC wa2510 cannot start, ie can we get NEC motherboad
Motherboard bad
    Master:
  • 680 Answers
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 71 Answers
Step 1:
Check the power cord
Step 2:
check the supply (Power Supply)
Posted on Jan 10, 2013
Lg ibm multinet i tower wont start up
Please follow the following:
1. Check if you correctly plug in to 220v outlet.
2. Check if the motherboard power is enough the 12v and the main power should have the connection to the power supply.
3. Clean your Memory stick and put it back again
Apr 18, 2014 | Computers & Internet
I have NEC wa2510 workstation for sercel 428XL seismic acquisition.I have some problem in system boot.After power "on" ,I can't see in monitor any massage.Pl..
Seismic work, huh? I'm an old 'Doodlebugger' from back in the '80's.
(Vibroseis, and 'Shothole' {Dynamite)
http://www.mitchamindustries.com/Products/detail.php?pId=18
Geophones have changed!
No error message on screen, nor do you hear BIOS Beep Codes?
Hmmm,.................
Suggest use the monitor, and monitor cable on a KNOWN to be working computer, to make sure monitor AND cable are good.
Monitor and monitor cable show to be good, move on.
The two main problems for desktop computer failure; are the computer is dirty inside, and Power Supply failure.
Motherboards get blamed all the time, when the problem was just a bad Power Supply.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your computer.
Computer ON a table, (NOT a bed, couch, or directly on a carpet floor!), computer unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
1) Is the computer dirty inside?
Use a can, or two of compressed air for computers, and clean it out.
'Gunk' = dirt, dust, hair, lint, food crumbs, .....you name it.
For heavy gunk I use Q-tips to 'stir' it a little bit, so the compressed air can remove it easier. (Saves on air too!)
Q-tips are good for the Processor fan blades, and where the fan blades meet the center hub.
The finned Heatsink sitting on the Processor, MUST be clean also.
Fan and Heatsink -> CLEAN, then move on to the rest of the inside, of the computer.
2) While you're in there remove ALL ram memory modules, ('Stick'), and clean the gold plated contact pins.
The BODY is everywhere on the ram memory module, EXCEPT the gold plated contact pins at the Bottom.
Handle the ram memory module by the Body.
The Body is coated with a see-through protective plastic.
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
Note that the bottom of the ram memory module shown, is DDR Sdram. Has 184 gold plated contact pins. 92 on each side.
Your motherboard uses DDR2 Sdram.
Has 240 gold plated contact pins. 120 on each side.
(DDR2 Sdram at either 400MegaHertz, 533MHz, or 667MHz.
That is PC2-3200, PC2-4200, (Or PC2-4300), and PC2-5300; respectively. Also is ECC. Error Correcting Checking. It's a server computer)
NOTE the Locating Notch on the bottom. Is NOT centered. The Locating Notch lines up with a Locating Lug, in the bottom of the ram memory slot. ONLY goes in one direction; one way.
Use a pencil eraser to clean the gold plated contact pins.
If you are using an eraser on the end of a pencil, and not a solid eraser; refrain from letting the metal band on the pencil, touch the gold plated contact pins.
Rub across all pins, (BOTH sides), plus up, and down. Doesn't take much pressure, nor rubbing.
(If the pencil eraser is dirty when you start, clean it off first by rubbing on a sheet of clean white paper)
When finished use air to remove the eraser dust. You can use a can of compressed air if available, or air pressure from your mouth will be sufficient.
Reinstall the ram memory modules.
http://www.pcpro.co.uk/reviews/workstations/122230/nec-wa2510
This is the motherboard used in an NEC wa2510 desktop computer,
http://tyan.com/product_board_detail.aspx?pid=175
This is the download page for the Motherboard Manual, (User Manual),
http://tyan.com/support_download_manuals.aspx?model=S.S2927
Click on the Second file listed.
User Guide -> S2927_UG_v1_1
Click on the green --> S2927_UG_V1_1
3) Look at the capacitors on the motherboard.
Solid capacitors, and Electrolytic capacitors.
The solid capacitors are Polymer solid capacitors. These are the little 'cans' that have a blue marking on one side, and on top.
If one of them is bad you will know it. They explode like a miniature grenade. Sends shrapnel all over inside the computer case.
(BANG!)
The Electrolytic capacitors are Radial Aluminum Electrolytic Capacitors.
These often fail. This is why solid 'caps' were brought out.
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A&noredirect=1
See if any of these 'puppies' are bad.
(Yes, they can be replaced if bad, and I can guide you)
Why could just some of the Electrolytic Capacitors be bad?
KNOW this,
http://en.wikipedia.org/wiki/Capacitor_plague
YES. Still affecting use today all over the world.
4) Power Supply:
The Power Supply is an SMPS. Switched-Mode Power Supply.
It is cooled by air, just like the rest of the computer hardware components, inside the computer.
The cooling components are Heatsinks, and the small internal fan,
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Click on the photo to the upper right; of the open SMPS.
The letter B marks the Input Stage capacitors. They are Electrolytic Capacitors. (And specifically Radial Aluminum Electrolytic Capacitor)
The incoming 100 to 240 Volts AC, is handled by them.
In between the letter B, and C; is a Heatsink.
Rectangular 'silvery' looking blocks, connected together. The 'Blocks are actually fins.
There is another one in-between the letters C and D, also.
(The Electrolytic Capacitors marked by the letter E, are in the Output Stage)
The Heatsink's absorb heat from whatever they are placed against. Then the tall, thin fins; radiate the heat away. Air flow from the small internal fan, helps to carry heat away from the fins of the Heatsink.
If the fins of the Heatsink are clogged, and the fan blades, center hub, and shroud, (Surrounding cage) are dirty; the Power Supply overheats.
Heat = Wasted Energy.
The Power Supply strains to keep up with the call for power, but eventually cannot, and components inside it fail.
This makes a weak voltage power rail.
(There are 3 main voltage power rails;
3.3 Volts, 5 Volts, and 12 Volts. ALL are DC Voltage.
The Power Supply is a Converter. It converts the high, dangerous 100 to 240 Volts AC, to the low DC Voltages stated above.
In comparison two D cell flashlight batteries produce 3 Volts DC)
With a Power Supply having a weak voltage power rail, you can see LED lights light, and fans spin. But there will NOT be enough power for the Processor. Means the computer isn't working.
A) If ALL of the LED lights were on at once, they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use 51 to 125 Watts of power. Just depends on what Processor it is.
Since this Tyan motherboard supports AMD Opteron processors, that fit in a Socket F processor socket, and are of the 2000 series;
could be from 95 Watts to 115 Watts.
Also take that number times TWO. There are two processor sockets, and two processors can be used.
Power Supply is checked with a multimeter set to DC Voltage.
Have a multimeter? I can guide you.
5) Do you have the Restoration Disk?
Install, and when asked choose Repair. (Non-Destructive Installation)
Just repairs the basic Windows files, and leaves programs/ applications alone.
Post back in a Comment.
Regards,
joecoolvette
(Looking at the user photo of yours, reminds me of when I was your age, and in oil exploration. Wish I was there, lol!)
Jan 05, 2013 | Intel Motherboard
My Lenovo 3000 J Series switches itself off at startup before the opening of Windows xp. Any ideas? This message is from another pc.
the problem of power off after startup can be caused by:
  1. a Faulty ATX power supply (the power good signal was not prperly generated to the motherboad)
  2. Cpu fan problem, the CPU temperature is abnormal
  3. faulty motherboard
to solve this problem, first change your ATX power supply unit with the same power rate. then clean the radiator and the fan. if the problem still not solved change your motherboad.
Dec 13, 2010 | Lenovo 3000 J Series 1.80G VBE PC Desktop
My computer..can play video and music... but no sounds.....!!!
your motherboad requires "active Speakers" IE Speaker with their own amplifier. this is a common problem as their are some M/b's out there that do not need them or send the sound through a mini speaker mounted on the board. Unfortunately yours does neither and so need a set of speaker with their own amplifier
Jul 23, 2010 | ASUS P5PE-VM Motherboard
My 845gvsr motherboad showed no display problem,in...
If your keyboard linked three lights thats mean its not a problem of motherboard check your RAM or Connection of HDD.
Regards.
Andy
May 21, 2010 | Intel Motherboard
What lights should be on when the computer boot up. sony vgc-rb34g desktop . power on fans run at high speed keyboard lights flash hard disk light flashes mouse light on no beeps or codes no display on...
You may possibly have a bad video card and a bad circuit on your motherboard. I would have the motherboard replaced. Some motherboards come with video cards, so once it is replaced, you may alerady have a new one with the motherboad part. If you not versed in doing this, you may want to get a professional to do so.
Nov 22, 2009 | Sony VAIO VGC-RB34G PC Desktop
Asus Motherboad P4B screen
I think the problem is on your motherboard, because in this time windows is not loaded yet. So, check out your motherboad, or take it to service center (if you have no experience in hardware fixing)
May 15, 2009 | ASUS (P4BGV-MX) Motherboard
No power
if you have changed and confirmed the psu and after that no power, then do a final test.
by the way, have u plug the power switch,reset switch, hdd led connector, power on led connector in the right pins on the motherboad. confirm it with the help of user manual , also mentioned in the motherboard too.
if all are in the right positions, and system still not working then do a final test.
remove all the power, data cables for all devices like cdrom,hdd,dvd etc. just plug the power plug of psu inside the motherboard and check. remove the ram too. the supply fan and processor fan should run without ram. but it should give a continuous on and off beeps.
if after removing all this, its still not working then it is surely dead.
Jul 24, 2008 | NEC /Packard Bell 4 DIMM AT Motherboard...
NEC 1GB Workstation WA2510 667MHz RDIMM Logo
179 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
