Question about Intel Motherboard
I have NEC wa2510 workstation for sercel 428XL seismic acquisition.I have some problem in system boot.After power "on" ,I can't see in monitor any massage.Pl..
First Power On, the system don't start.Monitor is black out but monitor is ok.
  • Intel Master
  • 5,660 Answers
Seismic work, huh? I'm an old 'Doodlebugger' from back in the '80's.
(Vibroseis, and 'Shothole' {Dynamite)
http://www.mitchamindustries.com/Products/detail.php?pId=18
Geophones have changed!
No error message on screen, nor do you hear BIOS Beep Codes?
Hmmm,.................
Suggest use the monitor, and monitor cable on a KNOWN to be working computer, to make sure monitor AND cable are good.
Monitor and monitor cable show to be good, move on.
The two main problems for desktop computer failure; are the computer is dirty inside, and Power Supply failure.
Motherboards get blamed all the time, when the problem was just a bad Power Supply.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your computer.
Computer ON a table, (NOT a bed, couch, or directly on a carpet floor!), computer unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
1) Is the computer dirty inside?
Use a can, or two of compressed air for computers, and clean it out.
'Gunk' = dirt, dust, hair, lint, food crumbs, .....you name it.
For heavy gunk I use Q-tips to 'stir' it a little bit, so the compressed air can remove it easier. (Saves on air too!)
Q-tips are good for the Processor fan blades, and where the fan blades meet the center hub.
The finned Heatsink sitting on the Processor, MUST be clean also.
Fan and Heatsink -> CLEAN, then move on to the rest of the inside, of the computer.
2) While you're in there remove ALL ram memory modules, ('Stick'), and clean the gold plated contact pins.
The BODY is everywhere on the ram memory module, EXCEPT the gold plated contact pins at the Bottom.
Handle the ram memory module by the Body.
The Body is coated with a see-through protective plastic.
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
Note that the bottom of the ram memory module shown, is DDR Sdram. Has 184 gold plated contact pins. 92 on each side.
Your motherboard uses DDR2 Sdram.
Has 240 gold plated contact pins. 120 on each side.
(DDR2 Sdram at either 400MegaHertz, 533MHz, or 667MHz.
That is PC2-3200, PC2-4200, (Or PC2-4300), and PC2-5300; respectively. Also is ECC. Error Correcting Checking. It's a server computer)
NOTE the Locating Notch on the bottom. Is NOT centered. The Locating Notch lines up with a Locating Lug, in the bottom of the ram memory slot. ONLY goes in one direction; one way.
Use a pencil eraser to clean the gold plated contact pins.
If you are using an eraser on the end of a pencil, and not a solid eraser; refrain from letting the metal band on the pencil, touch the gold plated contact pins.
Rub across all pins, (BOTH sides), plus up, and down. Doesn't take much pressure, nor rubbing.
(If the pencil eraser is dirty when you start, clean it off first by rubbing on a sheet of clean white paper)
When finished use air to remove the eraser dust. You can use a can of compressed air if available, or air pressure from your mouth will be sufficient.
Reinstall the ram memory modules.
http://www.pcpro.co.uk/reviews/workstations/122230/nec-wa2510
This is the motherboard used in an NEC wa2510 desktop computer,
http://tyan.com/product_board_detail.aspx?pid=175
This is the download page for the Motherboard Manual, (User Manual),
http://tyan.com/support_download_manuals.aspx?model=S.S2927
Click on the Second file listed.
User Guide -> S2927_UG_v1_1
Click on the green --> S2927_UG_V1_1
3) Look at the capacitors on the motherboard.
Solid capacitors, and Electrolytic capacitors.
The solid capacitors are Polymer solid capacitors. These are the little 'cans' that have a blue marking on one side, and on top.
If one of them is bad you will know it. They explode like a miniature grenade. Sends shrapnel all over inside the computer case.
(BANG!)
The Electrolytic capacitors are Radial Aluminum Electrolytic Capacitors.
These often fail. This is why solid 'caps' were brought out.
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A&noredirect=1
See if any of these 'puppies' are bad.
(Yes, they can be replaced if bad, and I can guide you)
Why could just some of the Electrolytic Capacitors be bad?
KNOW this,
http://en.wikipedia.org/wiki/Capacitor_plague
YES. Still affecting use today all over the world.
4) Power Supply:
The Power Supply is an SMPS. Switched-Mode Power Supply.
It is cooled by air, just like the rest of the computer hardware components, inside the computer.
The cooling components are Heatsinks, and the small internal fan,
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Click on the photo to the upper right; of the open SMPS.
The letter B marks the Input Stage capacitors. They are Electrolytic Capacitors. (And specifically Radial Aluminum Electrolytic Capacitor)
The incoming 100 to 240 Volts AC, is handled by them.
In between the letter B, and C; is a Heatsink.
Rectangular 'silvery' looking blocks, connected together. The 'Blocks are actually fins.
There is another one in-between the letters C and D, also.
(The Electrolytic Capacitors marked by the letter E, are in the Output Stage)
The Heatsink's absorb heat from whatever they are placed against. Then the tall, thin fins; radiate the heat away. Air flow from the small internal fan, helps to carry heat away from the fins of the Heatsink.
If the fins of the Heatsink are clogged, and the fan blades, center hub, and shroud, (Surrounding cage) are dirty; the Power Supply overheats.
Heat = Wasted Energy.
The Power Supply strains to keep up with the call for power, but eventually cannot, and components inside it fail.
This makes a weak voltage power rail.
(There are 3 main voltage power rails;
3.3 Volts, 5 Volts, and 12 Volts. ALL are DC Voltage.
The Power Supply is a Converter. It converts the high, dangerous 100 to 240 Volts AC, to the low DC Voltages stated above.
In comparison two D cell flashlight batteries produce 3 Volts DC)
With a Power Supply having a weak voltage power rail, you can see LED lights light, and fans spin. But there will NOT be enough power for the Processor. Means the computer isn't working.
A) If ALL of the LED lights were on at once, they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use 51 to 125 Watts of power. Just depends on what Processor it is.
Since this Tyan motherboard supports AMD Opteron processors, that fit in a Socket F processor socket, and are of the 2000 series;
could be from 95 Watts to 115 Watts.
Also take that number times TWO. There are two processor sockets, and two processors can be used.
Power Supply is checked with a multimeter set to DC Voltage.
Have a multimeter? I can guide you.
5) Do you have the Restoration Disk?
Install, and when asked choose Repair. (Non-Destructive Installation)
Just repairs the basic Windows files, and leaves programs/ applications alone.
Post back in a Comment.
Regards,
joecoolvette
(Looking at the user photo of yours, reminds me of when I was your age, and in oil exploration. Wish I was there, lol!)
Posted on Jan 05, 2013
My hp xw4600 workstation beeps red light blinks on off
read the code the blink codes tell the story,
red lights where,
1: power button LED green? (can be red) and beeps
2: Monitor LED lamps?
3: caps lock on keyboard blink.
4: is the COIN cell dead? 2.9v to 3.3vdc good, lower volts is bad , as most are this old !!!
http://www.pcdied.com/intel-magic/xw4600.html
the service manual covers all this! ever heard of HP and there REAL pages,,???
why not read that?
(do the fans all spin, if not PSU is dead.
PSU fan is first. does it.
CPU fan , huge fan on heatsink must spin.
the stock GPU card has no fan (ASUSc card but mine does. at ATI card.as fan right on the express 16 card.
does the DVD drive eject work.
if any of the above fail the PSU is bad.
but we strip off all loads from the MOBO
to prove its not some part shorted. first.
the front LED on this PC has flash codes
mine flashes in sleep mode, or w10 power off.
w10 never turns power fully off, it uses hibernate to turn off, (unless i cure that, ask)
the factory manual starting on page 111 cover this.
fully.
i own this beast so .....
code 2 red is overheated.clean the PC and all fans.
code 3 red, processor errors CPU.
code 4 PSU dead or shorts on load buses of same.
we call them power rails, we bench test the PSU
or read page 111 , how.
code 5 = GPU RAM failure, this PC has on board, GPU chip only X16 slot card, replace it. or the DDR2 rams are bad.
code 6 = GPU card bad.
code 7= BIOS ROM, put in a new coin cell first.!!!
Code 8= BIOS, always do nee COIN cell first.
code 9 = cant boot hdd, hdd bad or software gone, or corrputed, PC can now boot to a linux live CD or USB stick proving now PC is ok,
only hdd and OS suspected now. code 9
coin.
http://www.pcdied.com/intel-magic/slots.jpg
page 111 is here, 24/7 !
http://h50146.www5.hp.com/lib/doc/manual/workstation/hp_workstation/WS_UG_xw4600_STRG_453080-001_screen.pdf
Sep 01, 2017 | HP Computers & Internet
After power on, NEC wa2510 cannot start, ie can we get NEC motherboad
Step 1:
Check the power cord
Step 2:
check the supply (Power Supply)
Jan 05, 2013 | NEC 1GB Workstation WA2510 667MHz RDIMM
Dell precision workstation t7500 won't boot. Showing solid amber.
You may have to reinstall operating system by buying a Dell cd(from amazon) that reinstalls the operating system you had on the workstation.
Dec 07, 2011 | Dell Precision T7500 Computer Workstation ...
HP workstation going to sleep mode when windows logo appears.and it is working in safe mode and vga mode.
Did you change your monitor / resolution / card drivers / refresh rate?
Sounds like your computer resolution is out of range for the monitor. (or refresh rate)
Solution: Boot in safe mode and change the resolution, then boot to normal.
Optional: Update graphic card drivers.
Aug 09, 2011 | HP xw9300 Workstation PC Desktop
Blue power led doesn't come on when powering up. Power supply works, fans working, but no video. Tested harddrive in another workstation - works. Have 2 workstations that have crashed with this problem in...
Try reseating the ram modules, and the video card if you have an external one. To do this, open the case and locate the ram, they're long green sticks with black squares on them, to remove them, depress the taps on both sides and reseat them in their port. Then look for where your monitor plugs in, if its a removable card, try removing it and inspecting it for obvious damage, replace it and see if the machine boots. If possible, try swapping the video card with another one from a working computer to narrow down the problem.
May 03, 2011 | Acer Veriton M420 PC Desktop
My NEC MultiSync LCD1970NX monitor went black while in use and green power light is flashing.
If the system is booting up and if you see the "NUM LOCK" key lighting up in your keyboard then the system is working fine. The problem is with your graphic card. Check and repalce it. If not, the problem is with your monitor. Check the warranty and ask for a replacement.
Mar 03, 2011 | NEC MultiSync LCD1970NX-BK (Black) Monitor
How do you put a monitor into power save?
Depending on your operating system go to Control Panel of Windows and find the Power Options section.
There should be a setting there to change how long to waite before the monitor sleeps.
Jul 16, 2009 | NEC MultiSync FE700 17" CRT Monitor
System will not boot when monitors turned on
This may not be a video problem at all (hardware or software).
You say your "monitors" and it makes me wonder just how much you have plugged in to each of your power strips. Or extension cor
If you have a UPS, then you can take full advantage of all of the plug ports. BUT if you are using POWER STRIPS (these do NOT protect against power surges), then you need to look at what you have plugged in. Some big devices (system unit or "CPU" as some people call it, printer-especially the AIOs, MONITOR) pull quite a bit of electricity, moreso than speakers, a modem, or other small devices). Sometimes you need to have the big components plugged in to their own power source in order to work. You can't have them plugged together because there's just not enough power to go around.
I would try to spread the power around the room a little more, and then see if the system boots. Don't go rewiring your house, if it does!!! LOL. It's the computer systems we are using these days. I've also had fax machines, routers, and a few other things not want to work because they weren't getting their share of the "juice".
Jan 31, 2009 | Dell Precision Workstation 470 (204816690)...
Boot problem
It's maybe because of your bios battery are weak, change it with a new one 3volt cr2032, hopefully this could help
Dec 22, 2007 | NEC PowerMate 2000 PC Desktop
Nec 700 crt
Not a solution at all, but I'll post that I have a NEC MultiSync FE700 monitor that I purchased back in 2001, and have I been using the monitor since that time. Lately the monitor has been showing signs of 'acting up'. I read on the Internet that CRT monitors generally have a working life of about six years. It may be, depending on years of use, that the monitors are just reaching the end of their life.
Oct 20, 2007 | NEC MultiSync FE700 17" CRT Monitor
Intel Motherboard Logo
118 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
