Question about Zanussi Dryers
How do i get my sanussi zdc37200w dryer to drain out of pipe and not into tank can **** water out ofpipe but it wont drain out of pipe just fills tank up
How do i get my sanussi zdc37200w dryer to drain out of pipe and not into tank can suck water out ofpipe but it wont drain out of pipe just fills tank up
Timon90
  • 126 Answers
SOURCE: Water tank not filling
Probably it is lint in the condense pump.
Posted on Jan 30, 2008
  • 1073 Answers
SOURCE: Whirlpool Quiet Wash -8 Cycle- Fills with water-agitates-doesn't empty...
check the lid switch could be broken or not functional
Posted on May 06, 2008
MNTECH
  • 1543 Answers
SOURCE: Water Surge Making Pipes Knock
What you are describing is called "water hammering" and is caused when a water valve shuts off quickly. The momentum of the water moving within the pipe causes the pipe to bang when it comes to a sudden stop. Plumbers can install an air chamber to absorb the water hammer (just like a shock absorber) but you might try ones that you can just screw onto the hoses behind the washer. I have seen them at places like Home Depot in the plumbing department. (hope you can find someone who actually knows what you are talking about to help you find them) Alternately, you may be able to find them at a hardware store or appliance parts supplier.
Posted on Feb 01, 2009
  • 22 Answers
SOURCE: Haier HDY61 clothes dryer top tank not filling and
if your draining water from a dryer you have the problem not the dryer
Posted on Aug 09, 2009
  • 294 Answers
SOURCE: Not sucking up the dirty water
This is one possibility. other things to look are the screen filter on the machine. intake hose behind the motor. ensure that accessory hose cover is closed when extracting water from the floor.
Posted on Oct 11, 2009
Machine is set to drain out, but Drain Light wont stop flashing
sounds like the drain is plugged and wont drain all the way check the drain line and see if it is clogeed with something
Nov 20, 2014 | EuroTech EDC158 Electric Dryer
Low flow trough the heater
follow this steps and fix it. God bless you
Drain a tank:
  1. Shut off power at the electric panel and post a sign warning others not to turn it on.
  2. Close the cold-water supply valve and open a hot-water faucet somewhere in the house (to speed draining).
  3. Attach a garden hose to the drain valve and run it outside the house.
  4. Open the drain valve and allow all water to drain out.
  5. To refill the tank, close the drain valve tightly and open the cold-water supply valve. Also open a nearby hot-water faucet. When a steady stream of water flows from that faucet, the tank is full and the faucet can be closed.
  6. Once the tank is full, turn the electrical power back on.
Test and replace a relief valve:
  1. Lift the spring lever on the valve to fill a small cup. Check the cup for sediment.
  2. If no water spurts out, or if water continues to drip after the valve is released, replace the valve.
  3. Cut power at the electric panel and post a sign warning others not to turn it on. Close the cold-water supply valve.
  4. Drain a few gallons of water from the tank.
  5. Unscrew and remove the discharge pipe if used.
  6. Loosen the relief valve with a pipe wrench, then remove the valve by hand.
  7. Apply pipe tape to the threads of the replacement valve and screw it into the tank by hand. Tighten it with a pipe wrench. Screw the discharge pipe (if any) into the valve outlet.
  8. Refill the water heater and restore electrical power.
Oct 08, 2013 | Water Heaters
Water is draining continously from tank
its over filling its the soilnoid valve letting by u will need to replace it
Aug 26, 2012 | Electrolux Washing Machines
I have a Kenmore 80 series washer it will not stop filling with water so it wont go into agitate cycle, help
Has your drain for your washer backed up recently? Or is the drain hose from the washer sealed into the drain pipe, meaning that you can't just lift the hose out anymore? There needs to be air around the drain hose or it will cause the washer to allow water to be siphened threw the drain by not closing the filling valve. This can also happen if your drain is backed up. Rooter the drain out and make sure that the drain hose is not sealed up to the drain pipe and see if that fixes your problem.
Feb 12, 2012 | Kenmore Washing Machines
I have installed a Fluidmaster 403 G fill valve, flapper and tank lever to the water tank in my toilet. The tank fills OK but after several minutes the water in the tank has drained out I can not see...
if no leaks in tank. push down on flapper when it fills up. if water stops draining then it is the seal under flapper that is bad. you can lift up flapper and put patrolium jelly on bottom of flapper. this may just seal it. or it needs a certain type of flapper.
Dec 26, 2010 | Fluidmaster INC #B1F09 9" Faucet Connector
I have a hotpoint hot water heater it's about 6 years old. When I turn the hot water on it runs very slowly the water pressure is very low and it's like this throughout the house how do I fix this problem...
You have clog in the water line.
Since all hot water pipes are involved, clog is probably near water heater.
Buy pressure gauge at hardware store that threads onto hose connection.
Brady BTG 100 at Amazon
Picture of gauge
Check outdoor pressure for baseline pressure in your home.
Turn off electricity to hot water heater for an hour or two so there is not scalding water.
Open drain valve on water heater to see if water heater is clogged with sediment.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Put pressure gauge on drain valve and compare with outside pressure.
Open hot water spigot on bathtub and see if tank pressure drops ... if tank pressure drops significantly with bathtub spigot on, then clog is on incoming cold water before tank, and could be on outgoing hot water pipes too.
If tank pressure stays about the same, then clog is on outgoing hot water pipes.
Clog can be sediment caught in cold water shut off valve located above tank. Open and close valve and test pressure again. Take apart incoming cold water pipes above tank and check for sediment. Replace valve. Look at condition of cold water nipple on top of tank.
Sediment caught at hot water elbow near tank.
Sediment can fill up old pipes. Take apart hot water pipes above water heater and see condition.
Look at condition of hot water nipple on top of tank.
You may have to take apart pipes up to first or second elbow.
Pipes can decay at joint where copper pipe connects to galvanized pipe. Check for copper to galvanized connections on cold or hot pipes and replace section of galvanized pipe. Copper pipe will probably be good, the galvanized pipe will deteriorate. Replace copper-to-galvanized joint with 3/4" non-conducting union from hardware store
Dec 06, 2010 | Water Heaters
There is water constantly draining through the drain valve.
Grab a cap from the hardware store to stop it on the cheap. If it it is a brass drain valve you may be able to get away with draining the tank and replacing the small washer inside. Replacing the drain valve will be the ultimate solution.
Turn off the power on and electric or shut the gas valve to its off position.
Turn the water supply off above the tank or at the house main.
Connect a garden hose to the drain and open it all the way.
Open the safety valve on the top or side of the water heater to allow air in the tank so it will drain faster.
Unscrew the old drain valve with a pipe wrench.
Wrap plumber's teflon tape clockwise around the threads of the new drain valve and screw it into the tank by hand.
Tighten the valve with your pipe wrench until it is facing down at a 45 degree angle.
Close the safety valve.
Turn the water back on.
Open a faucet or two in the hows to let the air out of the tank while it is filling.
Turn the power or gas back on ONLY after the water heater it filled with water.
Oct 11, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
It wont drain the water away after a wash we
sounds like your pump may be gone, or could be pipe blocked. to check pipe fill machine take outlet pipe at rear of machine and lay this into a bowl. If water flows ok then all pipes are clear. As water is coming through just put machine onto spin cycle and raise hose to see if water will then pump out.
Feb 17, 2010 | Zanussi FS1255S Front Load Washer
Washer fills up than starts draining while in wash cycle
Hello , here is the fix-your drain hose is placed to low in the drain line in the wall, it can not be placed in water or it will siphon the water out of your washer into the drain pipe and it wont stop until it hits air. try pulling your drain hose up and out of the drain and get a zip tie or cable and tie it to one of the water valves by the drain pipe placing the end of the drain hose about 5-6 inches inside the drain pipe. Let me know if you have any other questions and good luck it will work.
Phil
Jan 28, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
Dryers Logo
104 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
