Question about Cartier Tank Francaise W50005R2 Watch for Men
Problem with Cartier Tank Francaise W50005R2 Watch for Men
The chronograph is not resetting properly to zero when reset. What could cause this and is it expensive to fix. Apart from that the watch works fine.
  • Cartier Master
  • 18,409 Answers
Try this,,pull winder out to second position then press start button till it goes to 0 then push winder back in,,
Posted on Jan 05, 2013
2 Suggested Answers
  • 3 Answers
SOURCE: setting a cartier chronograph watch
  1. click the top button to stop the second hand
  2. click the bottom button to reset the timer
  3. pull the crown out all the way
  4. twist the crown forward hard and fast for a few seconds. The minute hand will start advancing very quickly.
  5. when the desired date and time is reached, push the crown back in place. If you missed the time, pull the crown back out and twist backwards. The minute hand will move slowly in reverse. If you twist hard and fast, the minute hand will start spinning in reverse again.
Posted on Mar 11, 2010
I need an instruction manual (user's manual)
Hello James,
I couldn't find an online documentation of the manual you are looking. But I did find instructions with a video on how to set the date/time of your watch here:
http://www.keepthetime.com/blog/instruction-guides/how-to-set-the-timedate-on-a-cartier-tank-francaise-quartz-chronograph/
I hope that will help you.
Nov 23, 2011 | Cartier Tank Francaise Chronograph White...
I have a Cartier Tank Francaise, and the clasp seems to be loose, as it keeps opening up. The watch is about 10 years old already.
replace the clasp, I see it all the time in this model watch. I usually charge $50.00 for the clasp for these watches, It can be adjusted but it will loosen within the next year or less.
Dec 02, 2010 | Cartier Tank Francaise W51001Q3 Wrist...
I just received a Cartier tank Francaise Mens
mcdevito75 here, The easiest way to check the authentisity of your Cartier watch is by a jeweler, try to find a small watch repair jeweler over a fancy place which may charge you. You can also check Cartier watches on ebay, or simply type in Cartier watch on the search of your computers home page. The jeweler is best though, specially if your not that familiar with watches. the little I know tells me the Cartier name on the face should be Staright all the letters exactky the same (CARTIER) and all the hour and minute markers the exact same.
Jun 15, 2010 | Cartier Francaise #51002Q3 Watch for Men
Reset tank franchase cartier
Not completely sure what is being asked.
If what is being asked is how to reset chronograph hands to their zero point on a quartz watch then do the following:
1) Pull the crown out to the setting position.
2) press the chronograph buttons. Each one will move a different hand.
3) Once the hands are set push the crown back in.
Normally the zero point needs to be reset after a battery change or if the battery in the watch is getting weak.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Nov 01, 2009 | Cartier Tank Francaise W50005R2 Watch for...
Setting a cartier chronograph watch
Sep 15, 2009 | Cartier Tank Francaise Chronograph White...
Need to know how to operate Cartier Tank Francaise Chronography W
The top button is for chronograph function and puts the chronograph seconds hand in motion. The bottom button is for resetting chronograph seconds hand to zero.
Do as follows:
1) push the top button once- seconds hand starts moving,
2) push the top button once more- seconds hand stops,
3) push the bottom button once- seconds hand returns to zero.
You can repeat as many times as you like- seconds hand will allways start the countdown from zero.
Depending on what movement your watch has(mechanical or quartz), there can be more variations, but the basics are as described.
If you need more info, supply full info of your watch(make, model, numbers, etc.), please.
Do not forget to rate, please.
Jan 10, 2009 | Cartier Tank Americaine W2601156 Wrist...
My cartier tank f.
I NEED TO REPLACE SOME LINKS ON MY WATCH BAND
CARTIER FRANCAISE W51001Q3 SEND ME INFO. WERE I CANT PURCHASE LINKS.
THANK YOU
Dec 20, 2007 | Cartier Tank Francaise W51001Q3 Wrist...
Set date on Cartier Tank Francaise Chronoflex
Oct 14, 2007 | Cartier Tank Francaise W51001Q3 Wrist...
Owner's Manual
you have to ask cartier for the menu
Need to reset chronogragh
pull out the crown one click and press the bottom chronograph button. If That does not work you will have to send it in for service to cartier.
Feb 08, 2007 | Cartier Tank Francaise W51001Q3 Wrist...
Cartier Tank Francaise W50005R2 Watch for Men Logo
221 people viewed this question
Top Cartier Watches Experts
Jimmy Accardi
ray gallant
Are you a Cartier Watch Expert? Answer questions, earn points and help others
