Question about Cell Phones
I can't hear caller on my nokia C2 how do I fix it but phone showing caller still on line and I can hear phone ring and when messages arrive
I can hear the phone ring and can hear when messages come through, all of a sudden unable to hear caller although can see call has been activated, I can only hear caller when loud speaker is on
  • Jackson Jones Jan 07, 2013
    I can hear my phone ring but when I answer as usual I can not hear caller and caller can not hear me, I have noticed that I have a prompt telling me to use speakerphone and that's the only way I can communicate
SOURCE: problem with heaing incoming and outgoing calls unless using speakerphone
I can't hear people that call me unless I put them on speaker phone. Called Motorola and they had me reset the phone but that did nothing. Any other suggestions?
Thanks.
Posted on Jan 08, 2008
SOURCE: unable to hear caller
try using a headset.
Posted on Nov 27, 2008
SOURCE: Cannot hear incoming call or caller cannot hear me
cannot hear incoming calls or outgoing calls
Posted on Apr 08, 2009
help kid
  • 35 Answers
SOURCE: functioing of my nokia n73M is too slow - the
This is the reason they are going to stop making the nseries due to the nokia nSeries going slow after awhile. There isn't much you can do but with the gallery situation it may be due to the amount of images and images sizes you have.
Posted on Apr 23, 2009
SOURCE: Problem with Nokia 6300 - Can't hear anything
You need to changed,Your mouth piece, and you earpiece.
As for your ringer, it can be changed,but sometimes the problems always from the panel of the phone,and when it's from there, and ones is from there,it's damaged.
For your mouth piece and your earpiece it will workafter changing it.
Posted on Jan 20, 2010
I have 10 Panasonic KX-T7730 using 8 phone lines. I've confirmed with AT&T that all 8 lines are setup for caller ID. I've confirmed that all 8 extensions have the Caller ID enabled. Two of the
Firstly, you have not indicated which phone system your phones are connected to, e.g. KX-TA824, KX-TDA50 or other, so I'm a little in the dark. That being said, most of the Panasonic Systems only display Caller ID information (CID) to phones that are programmed to "Ring" on the line with the incoming call, and the line button flashes green to show it's ringing... so you must "system program" ringing for the line(s) on each phone. If the CID is not displayed on a particular phone, then that line is likely not programed to ring on that phone (it's light may flash red instead of green). After you "system program" the line to ring, you can still shut off the ringing sound on a phone using the slide switch on the left edge of the phone if you don't want to hear ringing, and this will not interfere with the CID display. Also, on a second note, CID does not display on the first ring coming in from the phone company (TELCO). The CID signal is sent from the TELCO to your system after the first ring has ended, during what would be the silence period that would occur before the second ring, if there was no CID. It is for that reason that most knowledgeable installers program lines with a five second delayed ring; in this way, you don't know the call has arrived until after enough time has passed for your system to receive the CID signal... this is why it seems the CID appears instantly, with an incoming call. Check out the line programming for each line and set it to ring with a 5 second delay. If you don't set up a delay, your phones will ring and if you answer the call immediately, its likely it won't allow the system to receive CID, so no CID will be displayed for that call.
Oct 28, 2014 | Panasonic KX-T7730 Corded Phone
Caller ID not working on Norstar terminal using line dedicated to fax and phone
You must have latest software to have Caller ID
You must have a Caller ID line card
Caller ID must be programmed on the phone to allow it
Caller ID signal from carrier is sent between 1st and 2nd call
FYI on the fax: Analog ports (ATA's) on the Norstar system do not show Caller ID, instead you would need to use a line share device that supports caller id such as the STICK.
Oct 25, 2012 | NorStar M7310 Corded Phone
Nokia c2-02 probulam no sim working. Shows enter code undo
Hi, I think your mobile must be network restricted. You must unlock it. The safest and easiest way to unlock a Nokia C2-02 is to unlock using unlock code. You can get the unlock code for a Nokia C2-02 from www.prounlocking.com/nokia-c2-02/rs8wp9/ at affordable cost with easy unlocking instructions.
Here are the steps for unlocking a Nokia C2-02,
1 - Switch on your Nokia C2-02 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C2-02.
3 - Compose #pw+CODE+1#.
4 - The Nokia C2-02 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia C2-02 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
Sep 27, 2012 | Cell Phones
NOKIA C2-03 CONTACT SERVICE SOLUTION
Message CONTACT SERVICE on nokia c2-03 please solution...........
Apr 19, 2012 | Nokia Cell Phones
My Nokia c2-00 shows "Contacts not ready" message after I turned it on. I can't see received calls, missed calls, dialled calls & contacts list. I can make a dial call, but I can't get receive...
i have faced the same problem in my Nokia c2-00 and i did the following and problem solved.
1. switch off the mobile.
2. Remove the battery.
3. Remove the sim cards & memory card from the slots and reinsert it one by one.
4. restart the mobile. Now i can view the contacts and msg's in my phone..!!
Mar 29, 2012 | Nokia mobile C2-00 Dual SIMbiosis
E63 - contact names do not appear next to text messages in inbox
No duplicates in there if there is more than one number attached to more than one name the nokia refuses to show caller name, cheak phonebook to make sure there is one number to one name only
Apr 16, 2009 | Nokia E63 Cell Phone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
Cant hear person talking to me
I think the earpiece has become disconnected either in the curly lead or in the handset.
Oct 06, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
166 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
