Question about Stoves (161221) Heater
Where can i get a light bulb fitting for a bi flame electric stove
How do you change the light bulb in a dimplex gem 20 heater?
Hi, First ALWAYS disconnet from the mains!
To change the bulb on your Dimplex you'll firstly need to remove the log effect, there are 2 small black head pozi type screws hidden at the front one on the left and one on right which your bulbs are under situated in their holders (as there are 2 of them) they are mini screw types as opposed to the standard baynot type replace the defective bulbs with like for like once fitted reconnect the mains and try if working, JOB DONE! Page 14 on the link shows exactly how to do it Regards Steve.
http://www.dimplex.com/cms/publications/7400070000r01.pdf
Aug 07, 2014 | Dimplex Compact Electric Flame Stove...
NO FLAME
There are little light bulbs (like large Christmas lights) that have probably burned out.
remember to replace with only the same wattage and type.
Apr 12, 2014 | Duraflame Electric Fireplace Stove DFS-750
Fire was working fine, then flame effect stopped. Heater still works on both settings, but no flame effect. Tried new bulbs, but still no flame effects, any ideas?
If it is not the bulbs, it is often a melted switch or circuit board.
You can obtain technical support for your stove here:
Dimplex Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Jan 05, 2013 | Dimplex Compact Electric Flame Stove...
Motor running but no flicker effect shaft drive
If you check your owners manual it should tell you how to change bulbs etc. Are you not seeing light, or light comes on but no flicker? If you can reply with model number on your unit, perhaps we can guide you to diagnosis and repair easier.
Sep 21, 2011 | Dimplex Compact Electric Flame Stove...
Light and flame effect not coming on dimplex springborne electric stove.
The light bulbs that provide the flame effect, may have burned out. You can access the bulbs by remove a rectangular access panel on the back of the stove, just above the bottom edge of the stove. Be sure to turn the unit OFF and unplug it before attempting the bulb replacement. The bulb type is 60 watt, small base, clear chandelier bulb.
I hope this helps you and thanks for choosing FixYa.
Jul 25, 2011 | Dimplex Compact Electric Flame Stove...
How do I replace the light bulb in a Dimplex Springborne electric stove?
You can access the bulbs by removing the rectangular access panel on the back of the stove, just above the bottom edge of the stove. Be sure to turn the unit OFF and unplug it before attempting the bulb replacement. The bulb type is 60 watt, small base, clear chandelier bulb.
I can't to find the area to replace the bulb. Everything works except for the light To eacy to leave on without the light. Where is the bulb located and what should I purchase to replace it. model #...
On the back of the heater stove, you will see a rectangular panel in the center, near the bottom of the stove. If you remove that (by removing the screws that hold it in place), you will have access to the small base, 60 watt. chandelier bulbs that you will need to replace. Be sure to turn the stove OFF and unplug it, before attempting to replace the bulbs.
Hope this helped you and Happy Easter!
Apr 24, 2011 | Dimplex Compact Electric Flame Stove...
Fan working heat coming out no embers
It's a bit unusual for all the bulbs that create the flames to go out at the same time. But, I guess it could happen. However, I thinks more likely the flame switch or its circuitry has failed. Not at all that uncommon in electric fireplaces and stoves, regardless of who the manufacturer is. It happens more than you'd suspect. If you don't know how to access the light bulbs, check you Owners Manual. If you know longer have your Owners Manual, go to the Dimplex USA website and you can download the Owners Manual in a pdf format and print it for future reference. Have your Model # handy when you do this.
Hope this helps you solve the problem.
Feb 16, 2011 | Dimplex Compact Electric Flame Stove...
Flame on electralog stove not working stove is still working
Rich's answer works for the heater problem, but not the light. My unit's heater quit working and I noticed the vents were clogged with dust. I vaccumed the front and back vents out with the unit unplugged and this fixed that problem. But the light/fire burn out is a different problem. I suspect it is burnt out bulbs, as I have had this unit for multiple years.
Sep 11, 2010 | Dimplex Compact Electric Flame Stove...
Heating & Cooling Logo
120 people viewed this question
Top Stoves Heating & Cooling Experts
Paul Carew
vance jones
ghold1
Level 1 Expert
Are you a Stoves Heating and Cooling Expert? Answer questions, earn points and help others
