Question about Whirlpool GD5SHAX Side by Side Refrigerator
Leaks water water comes out on the left side at unpredictable times sometimes its 2 times a week sometimes it goes for 2 weeks without leaking has anyone else have this problem? with water on the floor it is a accident about to happen can you help me Judy
  • isingle2 Feb 14, 2009
    I think my the hose going to the dispenser is leaking. I need to find out how to change?
  • 135 Answers
You likely have a plugged drain inside the bottom of the freezer. You may need a hair dryer to thaw it out, then clear it with a stiff wire. Otherwise your drain pan below may be cracked. Hope this helps!
Posted on Feb 16, 2009
Mitsubishi Eclipse AC leak & dealership cannot find the leak. Been in for service 5 times and dye is not showing leak. Any suggestions as to where it can be?
Your leak may not be coming from the outside. The AC has an evaporator tray that catches the humidity pulled from the air in the car drains it to the ground.. Sometimes the drain gets plugged up. Clear the drain and clean the tray. Sometimes that situation is accompanied by a nasty smell.
Mar 27, 2015 | 2007 Mitsubishi Eclipse Spyder GT...
Why is my GE (ZFSB23D SS) side by side refrigerator leaking at the back corner, near the rear wheel where the plastic water line goes in?
If the tubing is plastic it could have cracked when you moved the tubing to install the filter. If the tubing is OK then possinly the filter isn't all the way in or is leaking.
Jul 31, 2014 | Refrigerators
Toyota pickup antifreeze leak around timing belt cover
You won't really know until you can see the bottom of the pump. Most pumps have a "weep" hole where coolant will leak from if the seal goes bad. It can leak and still function without symptoms until the bearing goes.
Dec 15, 2012 | 1987 Toyota Pickup
Antifreeze leaking from left side of engine on 2001 cougar 2.0 4cyl
If you can remove components that are in your line of sight to check where the leak is coming from, it would help. Sometimes leaks come from hoses or sensor housing which mount to engine block.
Prior to removing anything, may want to use de-greaser or steam clean entire engine.
Apr 13, 2017 | 2001 Mercury Cougar
The Whirlpool side-by-side refrigerator, model ED2KVEXVQ01 occassionally leaks water onto the floor. There could be a cup or more of water, but the problem has occurred a few times, but may go weeks or...
sometimes we overload our refrigerators and the doors will not close properly, next time you notice the water see if your doors are closed tightly and the seals engaged tightly. My wife has this habit of not checking after she has put away the remains of a big dinner or BBQ and I find drips of condensate water all over the floor as a result. The defrost collection pan overfills and the excess water goes on the floor. once the doors are closed properly the problem goes away.
Aug 03, 2010 | Whirlpool ED2KVEXVQ (217 cu ft) Side by...
2003 saturn ion adding antifreeze every 2 weeks cannot find leak
There should be a radiator cap as it controls what goes into the overfill tank. You might consider replacing it. If there are no leaks in the radiator or hoses, there are only 3 places the coolant can go (water pump leak, blown gasket, or out throught the radiator cap). Hope its the cap because that's the cheapest. Good luck!
Mar 10, 2010 | 2003 Saturn ION
10 year old frige leaking water from the freezer onto the floor
drain tube is plugged the fridge goes into defrost about every 8 hours use a hair dryer to melt the ice and check the drain tube goes to the pan by the compressor
Jun 30, 2009 | Refrigerators
Trouble starting
Sounds like the head gaskets are leaking.
Nov 09, 2008 | 1999 GMC Jimmy
Whirlpool GD5SHAX Side by Side Refrigerator Logo
94 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
