Question about Vacuums
Bisell clearview compact dual cyclonic leaves dirty streak trails on the carpet.How do I fix it?
My bisell clearview recently started leaving dirty streaky trails on the carpet while vaccumming.The belt seems to be working fine and the filters are clean too..i checked it to see if it was clogged and it wasnt!!!Please any advice on how to get it fixed will be well appreciated!!! Thanx
  • Vacuums Master
  • 18,424 Answers
Check this video out
Posted on Jan 05, 2013
ukvacfan
  • 328 Answers
SOURCE: Dirt Devil Reaction Dual Cyclonic- M110000, "cyclones" not spinni
If the filters have been washed and installed back in instantly there wont be any suction. Check the top filters have been cleaned thoroughly and also check inspection tubes/hose and dust channels to check for a clog. Also check the sole plate / bottom of where the beater bar as there may be a clog somewhere.
Posted on Jan 23, 2009
  • 36 Answers
SOURCE: using too much solution AND leaving dirty streaks in my carpet
The reason for it to use soloution is it may be set on heavy traffic. To fix this turn your knob labeled heavy,normal& light traffic and water rinse to either normal or light traffic. To fix the streaks when you pull the machine backward pull it super slow (you may have to do this a few times) if this dont work take it back
Posted on Jul 31, 2009
  • 174 Answers
SOURCE: when shampooing the clean water comes out
Sounds like the brush is not turning. Could be the belt or jammed
Posted on Aug 06, 2009
Vac Belts
  • 701 Answers
SOURCE: Cyclone will not spin
Even thought the belt may look fine the belt still can be worn and therefore no turn the brush or the clutch. The belts you need are these here:
DC07 with clutch belts
DC07 without clutch belts
Posted on Nov 08, 2009
  • 31 Answers
SOURCE: it leaves dirt and fluff in the rollers not in the
is there something stuck in the air passage between the tank and inlet
Posted on Jan 07, 2010
My sweeper leaves streaks in carpet.what do I do to correct this. I have moved all 3settings but still leaves streaks.
As in the machine leaves patterns on the carpet? That's totally normal. If its leaving dirt streaks, its not operating correctly.
Aug 20, 2017 | Vacuums
Kirby ultimate g vacuum cleaner (not the shampooer) leaving white marks/trails all over brown carpet
This is not a normal occurence...maybe something the previous owner did or used the vacuum on?? A KIRBY will not normally leave any marks on Your carpet..
Lee in Australia
Oct 14, 2012 | Kirby Ultimate G Bagged Upright Vacuum
Eureka upright no bag started leaving streaks of dirt behind
check the hoses or check where the beater bar is. the opening where the hose connects. their is a clogg somewhere in the hoses
Aug 21, 2010 | Eureka Whirlwind 4388 Bagless Upright...
Whem i vacuum it leaves streak marks of the dirt on the carpet. i clean out the cup and the hose, what am i doing wrong? and how could i solve this problem?
It sounds like your filters may be clogged. Try pulling out the tray directly underneath of your dirt cup. You should see a black, or plastic piece directly underneath of the dirty cup that says PULL, pull this tray out and inspect the filter. If it's dirty, remove it and rinse it off. Make sure that this filter is 100% completely dry before putting it back in the vacuum and using it.
Also check the brushes to make sure that they are spinning while you're using the vacuum. Sometimes when the belt breaks, and the brushes no longer spin, this can cause the machine to not pick up as well as if the belt was new. If you're brushes aren't spinning try replacing the belt and see if this fixes it.
If this was helpful, please be so kind and rate the repair, or leave feedback. Thank you,
Chris Jones
May 17, 2010 | Bissell 89Q9 Bagless Cyclonic Vacuum
How to replace belt on a bissell proheat clearview plus carpet cleaner
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Jan 27, 2010 | Bissell 7901-R Clearview Proheat Plus...
Using too much solution AND leaving dirty streaks in my carpet
Jul 31, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Less than normal or no pickup from cleanerhead
These are not real powerfull vacuums (I know not what you have heard) but make sure bottom plate is fully sealed I see customers put these on wrong and the brush does not make good contact
Nov 29, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bissell Proheat
Take it outside, upside down and have a good look at the brush area. I use a garden hose to clean it after every use.
Aug 23, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
56 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
