Question about Porter Cable 332K Quicksand Random Orbit Sander W/ Case
Need help disassembling Porter Cable random orbit sander
I have a Poerter Cable 333VS random orbit sander. It would appear it needs new brushes, but I am having a little trouble knowing how to disassemble it so I can check the brushes before ordering them. Couldn't see the answer on the on line user manual.
  • johnmoran73 Feb 23, 2009
    I too have a porter cable model 333 random orbit sander. The speed of the pad slows almost to a stop when applied to the wood with any pressure. Is this problem the belt? It couldn't be the bearings could it? There is no sound like a slipping gear when this happens.
  • 2,176 Answers
Go to Dewaltservicenet.com and in the center of the page under needing parts type in your tool model number it will take you to another page and scroll down to the type 1 or 2 and click on it. It will bring up an exploded view of this tool. Why do you think that you need brushes? usually I have to replace the bearings and the brushes are pretty durable. Let me know if I can help further
Posted on Jan 21, 2009
Installing brushes in porter cable 7336
Go on line to porter cable customer service ask for a blow out of the motor of your 7336 assembly 6 inch variable speed sander they will have the parts blow up showing each part with a line going into each area where the parts fit together Good luck
Aug 26, 2012 | Porter Cable 7336 6 Inch Variable Speed...
I have a Mastercraft random orbital sander Model 54-7206-2 and need a dust bag. Is it available, how much, and how do I order it in Canada?
I just had the same problem. I couldnt find any information online.
call the toll-free help line
1800-689-9928
Tell them the make of the sander and what kind of part you need. They will look it up and ship it to you in 7-10 business days
Feb 20, 2011 | Porter Cable Porter-Cable Variable Speed...
I am using a Model 343 type 2 Porter Cable random orbital sander. It worked just fine, I turned it off, and 20 minutes later it would not turn back on. No strange noises, smells, etc. it just wouldn't...
Plug in the sander, Turn it on and Wiggle the wire around the plug. If your sander jumps on and off your plug need to be replaced.This should be a easy fix if you are a bit mechanically inclined. If that doesn't work, get a ohm meter and see if your cord is hooped. If cord is fine then look at the brushes.
Jan 10, 2011 | Porter Cable Tools & Hardware - Others
My porter cable 5" random orbit sander will not do any thing no nothing help
first check your cord. volt ohm meter for continuity. check the brushes, not worn down and move up and down. check the switch with the volt ohm meter.
Aug 31, 2010 | Porter Cable Palm Grip R.O.S. With Kit Box...
Slows down and looses power intermettently
you need new brushes or clean out the holes they go in so they move freely
Aug 08, 2009 | Porter Cable Porter-Cable Variable Speed...
Porter Cable Random Orbital Sander rotates but does not "orbit"
Just solved my problem with Porter Cable 333 orbital sander which just groaned. I thought the worst. I carefully took it apart on the garage floor and immediately suspected it needed lubrication as the motor turned hard. I used my flexible long plastic tube lubrication and put some on the bottom bearing shaft the best I could. I worked it around and around. I began to feel it turning easier. I applied more oil and kept moving and it became completely free. I put a drop on the top bearing even though it was loose. I put it all back together and it works like new. Lesson: do not look for the worst when a tool quits. Suspect the culprit to be lack of lubrication!!!
May 20, 2009 | Porter Cable 332K Quicksand Random Orbit...
Porter Cable 332K Quicksand Random Orbit Sander W/ Case  Logo
1,022 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim Parker
Jim Parker
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
