How do you disassemble the Dimplex CLB20R to replace the bulb?
2 Suggested Answers
  • 4736 Answers
SOURCE: How do you disassemble the
Good information. Thanks for sharing it.
Posted on Aug 23, 2011
Change bulb in dimplex mrl20
Search YouTube for Dimplex Electric MRL20 bulb replacement.
This video link may be just what you need:
https://www.youtube.com/watch?v=UD3kROvvuX4
Nov 01, 2017 | Dimplex Heating & Cooling
How do I replace bulbs on model DS5603 Mod G electric fireplace
Do you need to replace the upper or lower light bulbs?
For both, first open the door of the fireplace. For the upper light, locate the upper bulb bracket (above the door). Bend the bracket down. Unscrew the old bulb and replace it with 7 W clear chandelier or candelabra bulb with an E12 base. Bend the bracket back up to its original position. Close the door, if only the upper bulb is out.
You will need a Phillips blade screwdriver to replace lower bulbs. Open the door (if it wasn't already open). Locate the screw that holds the log set in the center of the ember bed. Remove that screw and the log set. Locate the bulbs that are behind the log set and determine if one or both bulbs need to be replaced. Unscrew the bulb(s) to be replaced. Screw in the replacement 60 W clear chandelier or candelabra bulb with the E12 base. Replace the log set and press firmly against the glass. Replace the screw that holds the log set. Close the fireplace door.
The procedure to replace the bulbs is on page 4 of the service manual. It is also on pages 10-11 of the Owner's Manual. The documentation is available from Dimplex: http://www.dimplex.com/en/customer_support/technical_and_troubleshooting . The direct link to the service manual is http://www.dimplex.com/cms/publications/7400650000R04.pdf . The Owner's manual is here: http://www.dimplex.com/cms/publications/7206570100R09.pdf .
I hope this helps.
Jan 12, 2017 | Heating & Cooling
How do you change the light bulb in a dimplex gem 20 heater?
Hi, First ALWAYS disconnet from the mains!
To change the bulb on your Dimplex you'll firstly need to remove the log effect, there are 2 small black head pozi type screws hidden at the front one on the left and one on right which your bulbs are under situated in their holders (as there are 2 of them) they are mini screw types as opposed to the standard baynot type replace the defective bulbs with like for like once fitted reconnect the mains and try if working, JOB DONE! Page 14 on the link shows exactly how to do it Regards Steve.
http://www.dimplex.com/cms/publications/7400070000r01.pdf
Aug 07, 2014 | Dimplex Compact Electric Flame Stove...
Bulb replacement
Dimplex uses common bulb types. Either incandescent or halogen. Consult your owner's manual for bulb type and wattage, then visit your local hardware or convenience store. It should be easy to find. If you lost your manual, simply remove the old bulb and bring with you to the store.
Feb 04, 2013 | Dimplex CS3311 Compact Heater
Flame effect dimmed on my dimplex stockbridge stove
You most likely have a couple light bulbs burned out. Refer to your owner's manual on how to access the bulb area, and replace with the appropriate watt bulbs. Most Dimplex stoves use standard incandescent 60w bulbs, a few use halogen. This is often annual maintenance.
If you can't find your manual, you can request one to be emailed to you from Dimplex, their service line is:
Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Dec 18, 2012 | Heating & Cooling
How do I replace the light bulb in a Dimplex Springborne electric stove?
You can access the bulbs by removing the rectangular access panel on the back of the stove, just above the bottom edge of the stove. Be sure to turn the unit OFF and unplug it before attempting the bulb replacement. The bulb type is 60 watt, small base, clear chandelier bulb.
I hope this helps you and thanks for choosing FixYa.
Jul 25, 2011 | Dimplex Compact Electric Flame Stove...
The heater on my dimplex fire appears to be working however i replaced dud bulbs with new bulbs, and they are not working?
dear sir/madam
have you checked for the power supply before changing the bulbs,if not please check it then you come back to us we will help you.
Aug 06, 2009 | Dimplex DS5598 Mid-Size Heater
Dimplex air heater
my guess is the power switch is shot.
Oct 31, 2007 | Dimplex DS5598 Mid-Size Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
