SOURCE: Starter does not turn
chec fuses-bad ones can appear normal-inspec if connecs r tite at starter n solenoid area-n also relays--starter may be bad ur bike is 10yrs-test it--that electric clutch may be malfunctionin too
SOURCE: switch clicking on start up wont start lights flash at same time
tried the battery, charge it manually, sounds silly but i had this problem with my 600ss
thanks
SOURCE: yamaha virago 535 turn ignition on neutral light
These are known for starter problems... The clicking you hear is the relay but the bendix is locked up put it in about 3rd gear and rock it hard forward and back. Bendix may release. Make sure battery is good. As I said before these bike are well known for their starter problem and even after having it fixed by a dealer problem seems to show back up after a very short time. Good Luck!
SOURCE: it wont start the lights are on and its in neutral
Battery.
More than 2 years old? Strike one
Sat for a while? Strike two
You could hydro the battery if you have a tester - 1200 is good (get the tester at auto parts store for about $6.00)
You could do a voltage test at rest - 11 or more volts is good. (get volt meter at auto parts store for about $12.00)
You could measure voltage at 1500 rpms ... if you could get it started - 13 to 15 is good.
You could jump it with a car battery (engine not running) see what happens.
New battery about $30.00.
Let me know what happens ... If it isnt the battery ... we can go from there.
a
SOURCE: My 2001 Yamaha R1 has
If you push the starter button and hear a click the starter button is good. If you do not hear a click, put power to the two skinny solenoid activation wires(+ and -), if you hear a click now you have a bad starter button. Clean or replace the switch. Follow the positive battery cable to the solenoid, short across the battery power cable and the starter power cable. If the starter works you need a new solenoid. If you tap on the starter with a plastic hammer while holding the starter button, and it works, you need new starter brushes.If you take the starter apart and the coils are burnt or the armature is shorted you need a new starter.
My EWD1477 was doing this a year ago and I fixed it. Then it started
doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry
sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn
the machine to off with the Program Selector Dial. Then turn off the power at
the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button
should be flashing and the green lights on for Prewash/wash, Rinses and
Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty
any excess water. Press it again immediately after you hear water flowing into
the machine OR two audible clicks. The machine is now in pause mode with the
green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash
button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause
button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing
into the machine and the three green lights mentioned above are back on, turn
the Program Selector Dial back to off, wait 10 seconds, and repeat the process
above.
Step 5: If when you then turn the Program Selector Dial to
Whites/Intensive and hear the two audible clicks, immediately press the
Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then
press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
