When i remove files in my mac leopard they are removed but later on on the hard disc itself they keep staying. How do i remove the files?
Most of all it are music-files that I want to remove, I have my trash overfull with all the files I have removed, but on the hard-disc itself later on, when connecting it to the TV and music-installacion the removed files really aren't removed at all....
  • maaike de klerk Jan 13, 2013
    Thank you very much, i'm really greatfull that you'll have respondes my question. Untill now i didn't find the right solution. It took a while to try the solutions you've put me, because it's not my external harddrive. Now i have it in my hands again and when i connect it to my mac the files i had removed earlyer still don't show in de window that opens in my mac. It only shows when my friend uses it to play some music whit his installation at home. The removed files aren't really removed, they just got hidden or something like that. I emptyd my trashcan... I'm not really a computerexpert, so all that about FAT and everything, i don't understand it very well... But i'll keep trying. Thank you all again....
  • 2,072 Answers
Are you right clicking on the trash can and emptying it. You pretty much have to delete files twice.
Posted on Jan 06, 2013
  • Justin
    Justin Jan 13, 2013
    If you just delete them off the, this doesn't delete the files. It just removes the pointer to the file and leaves the space used by the file flagged as "in-use" so your operating system won't write to that spot. Once you remove the file pointer in the trash can the pointer is removed and the operating system marks that space as free to write to. This STILL doesn't erase the data until another file is written over that space. Sometimes even then that old file can be recovered. You would want to format the drive to remove all those "hidden" files. In MAC land you would go to Go > Utilities > Disk Utilities > Erase tab and erase and format the partition as either FAT32 or NTFS that way a Windows computer can still use the drive.
4 Suggested Answers
SOURCE: After blackout Mac-formatted ext. hard drive won't mount says its pc-formatted
Here is my best guess and strong suggestion. First do nothing else until you have your work off loaded to some other drive or media....and I mean do nothing....don't even turn it off until this is completed. Once that is done verify your work is there. Then learn to smoke or drink and sing hallelujah.
My best guess is you lost the FAT (file allocation table)...meaning it got (literally) zapped by the power failure (spike) which makes sense since it's continually being accessed. Lacie should have a disk diagnostics program on their website....that loaded onto a diskette or cd would be my first step. It will tell you if the drive is good or not. If good and after you have off loaded your files to a safe media then the fastest solution is probably to reformat and reload your applications then reload your files. I say fastest as (in my twilight years) I have almost (it's a pride thing) given up solving hard problems the hard way...particularly when they can be both hardware and software interrelated.
A couple of other points....uploading to the net your files (even if it costs) or using a bit torrent to transfer to a friends machine (pay for the other drive) or using raid (which I am not a big fan of) or copying them to a one touch....(possibly the least expensive solution (just start it at night...it's not fast the first time and do it daily). You have too much invested to get had by Mother Nature.
Why would I tell you this....well, there was the time I worked all night to finish some code and just as I finished (without saving once) and feeling satisfied I stretched back, extended legs and knocked the plug out of the socket. I also had a computer shop
wipe my disconnected spare duplicate drive at the same time they wiped my master. Today, and I have multiple large projects I work on (mine...not others), and despite more backups in more ways than you can imagine I am still subject to bouts of paranoia.
Lastly....Am not up to date with Mac but at some of the freeware sites I have run across utilities that might be of help. Trying to restore the fat (Windows keeps two copies) might be a possibility and I assume Mac has something similar. But I would only attempt this based on what the drive diagnostics results are....i.e. if you have more than 4 bad clusters it's probably not worth taking the chance of another major disruption. Hope this helps or at least points you in the right direction. Tango
Posted on Jan 25, 2008
SOURCE: problem removing write protect from seagate free agent drive
The problem is because Mac cannot write to NTFS formatted drives. You will have to reformat the drive in Mac. You will loose all the data :( Here is a link for the how to:
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=174395
Posted on Mar 03, 2009
  • 10406 Answers
SOURCE: USB hard drive not recognized by Mac and by PC
Does the external drive work when connected to some _other_ computer? (Friend? Office? Home?)
It could be a failure either in the "hardware" inside the external-case (the USB adapter & interface)
or in the disk-drive "inside" the external-case.
So, a qualified technician can open the external drive, remove the disk-drive, and connect it directly to a computer, to see if the files can be "directly" read from the disk-drive.
If not, then you should search online for a "data recovery" service -- they are expensive, but they physically repair a damaged disk-drive, just long-enough to copy your data to another disk-drive.
Posted on May 31, 2009
HOW DO I ERASE A DISC.? DO I NEED A SPECIAL PROGRAM TO ERASE A DISC? PLEASE ADVISE..... THANKS
Open "Disk Utility". This comes with the computer and can be found in your Applications -> Utilities folder.
Sep 26, 2011 | Apple Mac OS X 10.5.4 Leopard for Mac
Tip
How to Recover Data on Macintosh The Right Way
As a Mac user whatever you lost files from: accidental removal, formatting, system crash, virus attack, etc., DO not panic! Now, it is at least possible to recover your Mac files as long as you follow the right steps.<br /><br />It is said that about 80% Mac users are used to deleting a file or emptied the Trash bin by mistake on their Mac computer or perform format option. Do you really think those files are really gone forever or are you looking urgently for a solution to recover and restore those important files, photos or documents that you need and which you've just deleted? So what should be the right things to do when you accidentally met this kind of problem?<br /><br />Possible to Recover files from Mac machine in such case? YES, definitely. As matter of fact, when <a href="http://www.datarescuetools.com/how-to/mac-trash-recovery.html">emptied Trash Mac</a>, used Shift-Delete to get rid of the file, deleted it from within an application or used some other method of removing it that bypassed the bin, then it is still almost certainly recoverable. The file is still not really deleted. Although the space occupied by the file becomes available for re-use by other files, it doesn't get re-used straight away so the data it contained will stay on your hard drive for some time to come and may be recovered using software that knows what to look for.<br /><br />First things first - If you have Mac machines purchased after November 2007 are installed with the Leopard operating system. One of the most important utilities of the Leopard is Time Machine. This complete backup tool can backup almost anything and everything on a Mac every hour with its unique features. Once you deleted or lost your critical files, just enter your Time Machine browser, you'll easily do Mac data rescue from Time Machine backup. If time machine has failed or you forget to set the backup, then you may need to use the third party Mac data recovery software to rescue data. <br /> <br /><a href="http://www.datarescuetools.com/mac-data-recovery.html"><b>Data Recovery for Mac</b></a> is a high-end Mac data recovery solution that recovers deleted or lost files (documents, videos, photos, archives, email and more) from HFS, HFS+, and NTFS, FAT file system volumes on Mac machines based on OS X. It can scan and find lost partitions, boot sectors and other file system components within internal Mac hard drive or external device. Incorporated with 3 Recovery Options like 'Deleted Recovery', 'Raw Recovery' and 'Lost Partition Recovery', the Mac file recovery software is a powerful yet comprehensive solution to recover all your Mac data in just a few mouth clicks. <br /><br />But you should remember: before your deleted files are recovered from Mac, DO NOT attempt to put more files to the partition as this will decrease chances of Mac trash recovery for there might be a chance for your files to be overwritten. Overwritten, it is impossible to do mac data recovery. You should be aware of that.
on Aug 03, 2011 | Prosoft Data Backup 2.0 (databackup2) for...
Tip
Possible to Recover files from Mac machine in such case? YES, definitely. As matter of fact, when emptied Trash Mac, used Shift-Delete to get rid of the file, deleted it from within an application or used some other method of removing it that bypassed the bin, then it is still almost certainly recoverable. The file is still not really deleted. Although the space occupied by the file becomes available for re-use by other files, it doesn't get re-used straight away so the data it contained will stay on your hard drive for some time to come and may be recovered using software that knows what to look for.
Data Recovery for Mac is a high-end Mac data recovery solution that recovers deleted or lost files (documents, videos, photos, archives, email and more) from HFS, HFS+, and NTFS, FAT file system volumes on Mac machines based on OS X. It can scan and find lost partitions, boot sectors and other file system components within internal Mac hard drive or external device. Incorporated with 3 Recovery Options like 'Deleted Recovery', 'Raw Recovery' and 'Lost Partition Recovery', the Mac file recovery software is a powerful yet comprehensive solution to recover all your Mac data in just a few mouth clicks.
on Aug 03, 2011 | Computers & Internet
Macbook black will not start beyond the initial 'bong'. Blue screen followed by endless spinning gear. PRAM, SMV reset, no go. Safe mode can't complete. With battery or on power adapter same result....
Hello yang2699tlk,
Try this instead of using your Leopard Disc.
  1. Immediately after the "bong" press and hold down "Command + S".
  2. Wait for blinking cursor and then type fsck -y (exactly like that).
  3. If you receive an "Appears to be OK" then type reboot and hit the return key.
  4. If you receive a "Disk has been modified" then repeat the fsck -y command until you get an "Appears to be OK" then type reboot and hit the return key.
This set of commands entered in "Single User Mode" will repair your disk. If this does not work remove the hard drive, plug it into another Mac and transfer your data to a different computer. Then install a new hard drive and reinstall Mac OS X.
Hope this helps, don't forget to vote. Thanks.
Feb 27, 2010 | Apple MacBook Pro Notebook
Tip
How to Copy DVD on Mac
This step-by-step tutorial will show you how to use Copy DVD for Mac to backup DVD on your Mac (tiger and leopard). With DVD Copy for mac iSkysoft, you can even copy your DVD movies and remove their protections with just a few clicks.
Step 1: Select Copy DVD Mac Source
In the 'Select Source' field, click and select 'Select source DVD folder'. Then browse your computer hard disc and select your DVD movie (either in a folder or from your DVD ROM).
Step 2: Select Copy DVD Mac Method
Copy DVD Mac allows you to copy DVD to a folder on your hard disc or directly burn DVD to a new DVD disc.
In the 'Select DVD Copy Method' field, click to select a method to output the selected DVD movie:
If you want to output your DVD movie to a folder on your hard disc, you can select the 'Output DVD Folder' option, and specify a directory to save the copied DVD movie.
If you want to directly burn your DVD movie to a new DVD disc, you can just select the DVD ROM where you have inserted a blank DVD disc.
Step 3: Program Settings
Set Buffer Directory: Specify a directory on your hard disc as the buffer directory to store the temporary files generated during the conversion. We recommend that you select a folder on a hard disc that has relatively big free space.
Select Language: Select an interface language for the program. The currently available languages are English and Simplified Chinese.
Step 4: Start copying
Note: If you are copying a DVD disc from your DVD ROM to a new DVD disc, DVD Copy for Mac iSkysoft will ask you to insert a blank DVD disc when the program gets ready to burn. Then you can just take the original DVD disc out and insert a blank DVD disc.
on Jul 15, 2010 | Computers & Internet
Tip
How to burn MP4 to DVD on Mac OS X
Want to convert MP4 to DVD on Mac OS X?
MP4 is the official multimedia container for MPEG-4 video and audio, which is widely used on iPod, iPhone, iTunes, PlayStation Portable (PSP), etc. If you have a few of MP4 videos and movies and want to watch with DVD players connected with TV on the big screen, or to keep the movies, share with friends and family, burn MP4 to DVD is a good choice.
What you need to burn MP4 videos to DVD on Mac OS X?
To burn MP4 files to DVD, you need a DVD burner that can convert MP4 to DVD on Mac OS X(including Mac OS X 10.4 Tiger, Mac OS X 10.5 Leopard, Mac OS X 10.6 Snow Leopard). Nero 9 and Daniusoft DVD Creator for Mac are your solutions. Nero is a powerful DVD Burner that performs many functions and is a bit complicated. In contrast, Daniusoft DVD Creator for Mac is much more user-friendly and meets all your needs such as burn videos and photo slideshows to DVD, add DVD menu, edit videos and pictures, add transitions and effect, etc.
Below is the step by step guide on how to burn MP4 to DVD on Mac OS X
Step 1. Load files
Just click “+” button to import MP4 files to this program or simply drag and drop them to it. And rearrange the file list by using the up-down arrows.
Step 2. Edit files (Optional)
To personalize your DVD files, you can edit MP4 files and slideshows as well by clicking “Edit” button. For video files, you can crop the frame size, trim into several clips, append effects, add picture/text watermark and rotate.
Step 3. Create DVD Menu (Optional)
This Mac DVD Creator also allows you to create your own DVD menu with rich selections of DVD menu template. Simply click “Menu” button to select one and set the “Frame”, “Button” and “Text” to customize your DVD menu
Step 4. Start to burn
After all necessary settings, you need to insert a blank or rewritable disc to your Mac if you want to burn video files on DVD disc. Or you can simply convert the videos to DVD folder, .dvdmedia or ISO file on your Mac for later burning.
That is it! Now, with MP4 movies burned onto DVD, you can easily play your videos on your home DVD player
on May 21, 2010 | Computers & Internet
Grey screen,computer unable to read leopard disc, tried to reset pram using command option p and r with no result, difficulty ejecting leopard disc, sometimes able to get blue screen with holding down the...
I would by pass disk repair and unfortunately go straight to reinstalling Leopard. When you get icon and it asks what you wish to do you want to reinstall and safe old files. Once you reinstall leopard you will find all your old files in previous system located in hd icon.
Oct 13, 2009 | Apple iMac G5 Desktop
How do I retrieve deleted accidental photos?
uFlysoft Photo Recovery for Windows is an advanced utility that recovers lost images, audios, video clips, and pictures from almost all digital cameras, memory cards, hard drives, memory sticks, USB flash drives, and various others. The easy-to-use Photo Recovery utility is available for both Windows (Windows 7, Vista, XP, 2003, 2000, and 2000) and Mac (Mac OS X 10.6 (Snow Leopard), 10.5 (Leopard), 10.4 (Tiger), and 10.3.9 (Panther)Use the Data Recovery for Mac to acheive Photo recovery on Mac) operating systems.
Aug 18, 2009 | Samsung S860 Digital Camera
Installing new system software on G4 imac where system removed
Well the flashing question mark means its not finding a bootable device meaning the hard drive has no OS on it. You should be able to put jaguar on it if its a retail version and not one from another mac product. Let me know how this works for you
Nov 16, 2008 | Apple Power Mac G5 Desktop
Computers & Internet Logo
David Payne
David Payne
