Question about Dryers
John Lewis JLTDH17 tumble dryer won't heat up or dry clothes. There is also an error code of E32.
  • 6 Answers
SOURCE: dryer working but no heat
Your dryer has two separate fuses, one to turn the drum, and one to heat it. It sounds like you have a broken fuse. Unless this is a new installation, then you need to make sure you have the proper electric cord attached. If it's mistakenly connected with a range cord, it won't supply enough power to the dryer.
Posted on May 20, 2009
  • 46 Answers
SOURCE: Dryer not heating, still tumbling
your heating element could be burned out...or a thermal switch could be stucknot allowing the element to turn on
Posted on May 25, 2009
  • 530 Answers
SOURCE: dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Posted on Jun 02, 2009
guru_dev
  • 315 Answers
SOURCE: no heat in dryer.
First, I assume that the drum spins OK but there is no heat. Many things can cause this. From the most likely cause to the least likely:
1) An open thermal fuse. This is a small "thermostat" with 2 wires at the middle/top of the heater "box" (a tall narrow box on right in the back of the machine), or a plastic type on the duct close to the blower, depending on the model. You will need to remove the back cover of the machine to see these. Check with an ohm meter after disconnecting one of the leads, or jumper the 2 wires together to see if heater works (don't use this way though, fire hazard... replace the device) If this proves to be the cause of the problem, it would be wise to check all ducts and blower for excessive lint buildup. This will reduce air flow, causing overheating and blown thermal fuses.
2) A burned out heating element. Remove tall box on right, element slides out from the bottom together with the "carrier". Look for broken coil, or check 2 terminals at bottom with ohm meter.
3) Burned wires at connectors. Check for obviously overheated wire terminals at all sensors (thermostats and thermal fuses in back), heater box, main terminals where power cord hooks up, etc.
4) Bad thermostats. There are usually 2 or more. A high limit on heater box, just above terminals on the bottom. 1 or 2 will be on the duct next to the blower. Check these with an ohm meter (or continuity checker). Some have 4 terminals, the extra 2 small terminals are small heaters inside the thermostats which alter it's temperature characteristics. These will usually read around 4000 ohms or so. Check the 2 main largest terminals for continuity.
5) Only getting 110 volts: This is often overlooked, but if for some reason one of the poles feeding the 220 power from the house wiring is open but the other is OK (for example, houses with fuses where only one fuse is blown, or a bad circuit breaker with one pole open). The motor and timer run on 110. If the side of the 220 line that feeds the motor is OK but the other one is open the motor will run but the heater, which needs 220 will not heat. Check for 220 volts between the 2 outer terminals where power cord connects or between the 2 "hot" terminals of the 220 outlet the dryer is plugged into.
6) Bad centrifugal switch in motor. This is what actually turns the heater on, for safety reasons, so the heater cannot come on unless the fan is spinning. Otherwise without air flow past it, the heater would burn out.
There are 2 large gauge (usually red or yellow) wires going to the connector on the motor, these go to the contacts inside the motor that turn the heater on.
Posted on Jul 20, 2009
milten1
  • 1304 Answers
SOURCE: my kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Posted on Oct 05, 2009
Dryer heats but won't dry clothes completely
Inspect and clean the dryer is what I would do. most times it is a faulty blower wheel causes your symptoms.
Feb 16, 2013 | Amana Dryers
My kenmore 60 series gas dryer stopped drying clothes.
Check for restriction in lint chute, blocked exhaust tube, plugged lint screen
Feb 12, 2013 | Kenmore Dryers
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
Frigidaire Galaxy Dryer tumbles but heats to dry seldomly
What is the model number of the unit?
Nov 13, 2012 | Dryers
User manual for john lewis tumble dryer jldv08
Hi I need to find an instruction manual for my tumble dryer John Lewis JLDVO9, no-one seems to do it anywhere! Someone please help
Oct 18, 2012 | Dryers
Clothes not drying
Clothes not drying? Thats it? Does the dryer turn on at all? Does it tumble the clothes but doesn't get warm? If it turns on and tumbles but takes a long time to dry, then your heating element is not working. There is a thermal fuse right before the heating element that will open up if the vent becomes clogged and its gets too hot. The thermal fuse is not resettable and will have to be replaced. If the thermal fuse is o.k. then your heating element could be burned out. These two items almost require an electrical meter to read continuity to check them. Make sure the dryer is unplugged before checking these items.
Dec 21, 2011 | Zanussi TC7114W Electric Dryer
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
What is the meaning and fix for error code E60 on a John Lewis JLDV08 tumble dryer. The dryer stops mid-cycle, the door pops open, and code E60 appears on the display.
When there is an error with the door switch and sensor, the "E60" error code will appear. An unbalanced door will produce the E60 code. Try to close the door gently and listen for the click. If the error remains, the door switch may need to be replaced.
May 08, 2011 | Dryers
My dyer heats and tumbles, but doesn't dry
I'd check first for clogged vent hose or clogged lint filter or clogged vent flap on wall (outside).
If that's not a problem, it may be a faulty thermostat. Heating element is probably okay if it heats some of the time.
More info, let me know.
Charlie
Oct 01, 2009 | Kenmore Dryers
May 25, 2009 | Dryers
Dryers Logo
118 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
