Question about Craftsman 1000 Degree Infrared Thermometer Non-contact W/ Laser Pointer
Calibration for craftsman 1000 degree infrared thermometer
The unit does not seem to be accurate
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 74 Answers
Apparently the reason it is not accurate is that it is a Piece of crap and Sears will not stand behind it. I recommend you do not purchase any type tool that requires precision from Sears.
Posted on Sep 03, 2014
WMH1163XVD seems to no be on full power. Takes 1 minute to heat up a piece of bacon
1 minute to cook a piece of bacon sounds pretty fast, really.
Try this:
MICROWAVE HEATING POWER TEST
The following test will provide a suitably accurate measurement of the output power of any microwave oven. Variations or errors in performing this test will produce uncertain results. If the line voltage (from the electrical outlet) is low, the magnetron output will be correspondingly low.
Equipment needed:
- Microwave safe container with 1000 mL (1 Liter) gradation.
- Fahrenheit or centigrade thermometer
Procedure:
Pour exactly 1000 mL (1 Liter) of cool tap water into the container. Using the thermometer, stir the water, then measure and record the temperature. For accurate results the water should be about 60 degrees F (20 degrees C).
Place the container on the center of the oven cooking shelf (do not leave the thermometer in the container and remove any metal racks), and heat the water (at full power) for 63 seconds. Use the second hand of a watch, not the oven timer.
After the heating time is completed, immediately remove the container, stir the water, re-measure and record the temperature of the heated water.
Subtract the starting water temperature (step 2) from the ending water temperature (step 3) to obtain the temperature rise.
To determine the output power in watts, multiply the total temperature rise by a factor of 38.75 if you're using a Fahrenheit thermometer or by 70 if you're using a centigrade thermometer.
If the oven is grossly underheating or overheating, then you probably have a bad magnetron.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
mini_manual_behind_grille_small.jpgdee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jul 18, 2011 | Whirlpool WMH1163XVS Microwave Oven
Wattage Power
Unfortunately, the old owner's manual doesn't say, but you can do a test to see what its heating power is:
Equipment needed:
Procedure:
Apr 28, 2010 | Hotpoint RVM1435 Microwave Oven
What is the wattage?
Oddly, the owner's manual doesn't say.
You can contact GE customer service here, or if it's working properly, here's a test that will tell you how much output power it has:
Equipment needed:
Procedure:
Apr 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Hotpoint microwave oven, countertop, model RE964. How many watts is it?
The owner's manual (which you can download here) does not say, but most of their ovens from that era were 700 watts.
There is a way to check:
Equipment needed:
Procedure:
Jun 06, 2009 | Microwave Ovens
G E oven temp fluctuation
No, that is just fine. As a matter of fact, older ranges often had 50 to 60 degree swings in temp. Your oven temp (assuming your thermometer is dead on accurate) is 347 + 365 / 2 = 356 degrees when set at 350. I never mess with ovens which are within 10 degrees of set temp. (when checking the temps, make sure to take the readings after the oven has cycled on and off at least three times, and use a good digital oven calibration thermometer)
Mar 18, 2009 | Kitchen Ranges
I have a microwave peanut brittle recipe but it burns, someone told me that I need to calibrate my microwave. How do I do that?
Equipment needed:
Procedure:
Dec 15, 2008 | Microwave Ovens
89 gmc 5.7 cooling problems
Hi! Screw-1
Some times I even get a little confused when the temperature gage in the cabs are not as accurate as we would expect. If you leave the radiator cap loose and put a thermometer in the coolant, or better yet ask around and find a infrared thermometer (you can leave the cap on). Check this reading at both ends of the radiator. Even if the water is at 210 degrees F, at the inlet from the top hose, as long as the coolant is at a lower temperature at the opposite end, this should be fine. If the radiator cap is leaking you may want to make sure the cap is ok.
If the gaskets are old, the pressure change with the breather off may indicate the PCV valve is not working properly. I believe the crankcase breather is still in the air breather. The combination of problems as well as excessive blow by will also cause leaks.
InMrFixIt
Sep 04, 2008 | 1989 GMC K2500
My whirlpool microwave heats up the top cover / outer metal casing. It seems to get hotter and hotter, even though the food inside may not be all that hot. Eventually it may even stop running the...
If the cooling fan is not running, then that definitely needs to be addressed to prevent magnetron damage.
-.htmThere should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
-.htmYou can usually find helpful exploded view diagrams and order parts by entering your full model number here.
It might be useful to first do a standard heat test.
-.htmMICROWAVE HEATING POWER TEST
Equipment needed:
Procedure:
To determine the output power in watts, multiply the total temperature rise by a factor of 38.75 if you're using a Fahrenheit thermometer or 70 if you're using a centigrade thermometer.
-.htmWe're happy to help and we appreciate your thoughtful rating of our answer.
Jul 12, 2008 | Whirlpool Microwave Ovens
How can you check to see if your microwave oven is working at full power
Equipment needed:
Procedure:
Jul 06, 2008 | Microwave Ovens
Craftsman 1000 Degree Infrared Thermometer Non-contact W/ Laser Pointer Logo
224 people viewed this question
Top Craftsman Measuring Tools & Sensors Experts
Vuk B
S Sigs
S Sigs
Are you a Craftsman Measuring Tool and Sensor Expert? Answer questions, earn points and help others
