Question about Jetway V266B Motherboard
Will this motherboard use 1gb ram memory 184 pin
Or should I use 2x 512mb ram
    President:
  • 1,179 Answers
Since it uses ddr 2 RAM you should use pairs. Your max supported on this board is 2 GB so if you want to max out you could install 2 x 1 GB. Hope this helps.
Posted on Jan 19, 2009
I have 266 mhz 256MB RAM with intel D845 board. I want to upgrade it to 512mb or 1GB. Can you please tell me whether 333/400mhz will be suitable or where can I get it in hyderabad
hlo hyn you should get RAM 200/266 MHz of 512mb or 1Gb
below are the specifications your motherboard can support.
  • Two DIMM sockets supporting 2.5V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
for more info click this link http://www.intel.com/support/motherboards/desktop/d845gbv/sb/cs-012820.htm
Aug 18, 2011 | Intel D845GBV (BOXD845GBVL) Motherboard
I want tobuy 1gb memory card for my ms 6787 ver2.. what is the specific type of memory card is the best for my board (1gb or 512mb only)
For this particular motherboard, you need a 184-pin DDR SDRAM DDR 266 (PC 2100) memory module. These can be found in sizes ranging from 256MB to 1GB. There are several places that these could be found on the internet. Pricing for a 1GB module seems to be around $44 or $45 USD currently.
The MS-6787 supports a maximum of 2GB of RAM (1GB in each DIMM slot).
Hope this is helpful!
May 09, 2011 | MSI P4MAM-L (MS-6787) 400/533 MHZ FSB...
Which RAM to be used in Motherboard D101GGC
1GB 184-pin DIMM
  • Module Size: 1GB
  • Package: 184-pin DIMM
  • Feature: DDR PC2700
This is taken from the Crucial memory configurator for your specific motherboard.
Go to this link for more info.
http://www.crucial.com/store/listparts.aspx?model=D101GGC
Dec 22, 2010 | Intel D101GGC Motherboard
RAM Slot does not recognize more than 512MB ( 184 )
Consider updating your motherboard bios.
http://www.asrock.com/mb/download.asp?Model=K7VT2&o=BIOS
Also make sure that your memory is correct for this system:
- Max. capacity of system memory: 2GB DDR or 2GB SDRAM
- DDR x 2, DDR266/200 non-ECC, un-buffered memory
- SDRAM x 2, PC133/100 non-ECC, un-buffered memory
Jun 26, 2010 | Asrock K7VT2 Motherboard
I have a intel 845gvsr board, want to replace a Ram. What type of RAM is suitable for this board?
Your Intel D845GVSR has,
1. Two ram slots.
2.Maximum Amount of ram is 1GB for EACH ram slot.
3.Maximum TOTAL Amount is 2GB, (1GB in each ram slot)
4.Uses DDR Sdram at 400MHz, (PC3200), OR
DDR Sdram at 533MHz, (PC4200)
This is an example of DDR Sdram at 400MHz, (PC3200),
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1354&name=PC3200-DDR-Dual-Channel-Memory&Nav=|c:1352|&Sort=0&Recs=10
(Not advertising for this website. There are many places to buy ram memory)
512MB + 512MB = 1024MB, or also stated as 1GB
1024MB = 1GB
Nov 13, 2009 | Intel D845GVSR Motherboard
New ram memory on dell dimension celeron trying to
You should check with the folks at Dell since whoever wrote their technical manuals for this machine can't do basic math. There are 2 memory slots and each can handle a maximum capacity of 512MB, yet they claim the maximum capacity for the machine is 2GB instead of 1GB. Using 512MB modules would probably work.
Jul 06, 2009 | Dell Computers & Internet
Ddr ram sdr ram i am same time input that tw0 thats not show two ram capacities just show one ram'' asus p4s533 model please help me
Hi safran0785,
The Asus motherboard, P4S533-MX can run two different types of memory.
(Just not at the same time & in different slots).
You can use 2, 184-pin memory, PC2700/PC2100 MHz or PC1600 up to 2GB. (1GB DIMMs) inserted in the two memory slots closest to the CPU.
Or you can run SDR memory, 168-pin PC133 or PC100MHz DIMMs up to 1GB of memory in the last two slots farthest from the CPU.
You can not run both types of memory at the same time.
The 184-pin DDR PC2700MHz memory is much faster then SDR memory.
The maximum amount of system memory supported is 2GB.
Need more information/questions, just post here.
Good luck safran0785!
Mike
Mar 22, 2009 | ASUS P4S533-MX Motherboard
2 x 1GB Samsung PC2100 appearing as just 1GB (2 X 512MB)
Hi Patrick,
I see you're point. I know this, you can not run "more than" 512MB in any DIMM slot. That is shown at the bottom of page 10 & the top of page 11. You can not run both types of memory at the same time, even though the chart looks like you could. The description term on page 10, states; Users only can install either 168-pin SDRAM Module or 184-pin DDR DRAM Module at one time. (You can't run both). You can run 4x512MB in all banks using184-pin DDR SDRAM. Or you can run 4x512MB in all banks of 168-pin SDRAMs. Total of 2GB.
So you can not run 1GB of memory in any bank.
Mike
Jun 29, 2008 | Jetway V266B Motherboard
High density memory
need low densisty on ebay 35 buck eash 1 gb ok works on picky mobos way better
Feb 07, 2008 | Dell (E210882) Motherboard
Type of memory for e210882 motherboard
the memory you're about to purchase will not work. the maximum gig that the computer can handle per stick is only 1 gig. this system is not designed for 4 gig barrier.
hope this helps.
thanks.
Feb 05, 2008 | Dell (E210882) Motherboard
Jetway V266B Motherboard Logo
85 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Tony
Iqbal Husain
Iqbal Husain
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
