NOT CLEAR TO BACK LIGHT - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
What is the brand name and model number to your TV? Provide sufficient details please.
Posted on Jan 05, 2013
My toshiba TV 50L4300u goes from clear to blurry back to clear every other second
Sounds like back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Aug 26, 2015 | Toshiba 50 Inch Cloud LED TV 1080p Smart...
Harley 2011 road glide ultra code p1510 engine light stays on
disconnect positive side of battery wait 20 seconds hook back up this wii clear codes if it comes back on tank to dealer for check something is wrong bad plugs need oil chang needs air filter bad gas cape some thing minor bit those things you can try to clear cold i would try gas cap first
Aug 29, 2014 | Motorcycles
Installed new oxygen sensors but light is still on
You need to clear the check engine light with a scanner. If you clear it and light comes back on check for a new code number. If you bought your parts locally the parts store should scan/clear your codes for free.
Mar 01, 2014 | 2001 Chevrolet Silverado 1500
Even after replacing the toner cartridge the toner light remains on and the copier will not operate. I have tried agitating the cartridge with no effect. Occasionally on switching on it will operate for a...
Hi Paul
Please answer me a few questions and Ill look into your issue when I get some time later today
Are you using Sharp original toner or after market?
Is the light the "billard ball" one and is it on solid or blinking
Is the drum light on also?
What is the page count on this machine
"clear, density select, clear, density select, dilpay blinks 00 then use arrows for up, zoom for down, to put in 22, press copy then arrow in 05, press copy.. result will be 3x 2 digits repeaed, clear to exit to start of service mode
what is the drum count?, same as above but 12 instead of 05 for second lot of entry
TRy doing clear density, clear density, then 10 copy, can you hear toner motor turning for 30secs?
Dont play in service mode you can damage machine if wrong stuff is put in;)
(clear then clear again to exit all the way out of service mode)
Please post back results/answers
Cheers
Soulvisitor
Oct 10, 2011 | Sharp AL-1217 Copier
How to reset all of the codes with out taking out the bat. i know there is a way just can't remember how please help me out her
Hello: If the car is a 1995 or older all you need to do is disconnect the negative battery cable for 30 seconds, but if the condition that caused the light to come on has not been corrected the light will come back on. For 1996 or newer you have to use a scan tool to clear code to turn the light off and again the condition that caused the light to come on has to be corrected or the light will come back on. For 1996 or newer you can go to auto zone, advance auto, o'riely auto parts store and they can clear code and not charge you.
When they clear the code the light will go out.
Oct 17, 2010 | Oldsmobile Intrigue Cars & Trucks
The ''service engine soon light'' came on
clear light and see if light comes back on. turn key from on to off 40 times to clear light and codes
Jan 04, 2010 | 2004 Ford F150
How to Clear a Check Engine Light and Reset the Computer.
you can use the scanner to clear the computer or even disconnect the battery for a minute or two then reconnect it but if the light comes back it needs to be fixed to keep the light off. just fixing the problem won't turn the light off
Nov 08, 2009 | 2001 Dodge Caravan
How do I clear cheak engine light on b6000 mazda pickup
You disconnect the battery negative cable for a few minutes, but if the problem is not fixed that turned the light on it will come back on in around 20 miles/
May 10, 2009 | Mazda B-Series Truck Cars & Trucks
BAS ASR problem
ok, first you have to clear the codes.
in this type of cars you cannot clear codes with a regular obd II it has to be the factory scanner or similar. after you clear the codes drive it for a while. when light comes back on scan it again and that is going to be your true problem. if you replaced the switch but didn't clear the code the light will be still on because the computer doesn't know that you fixed the problem. so try it out and let me know if worked.
May 15, 2008 | 1998 Mercedes-Benz CLK
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
