Question about Samsung SMH7185STG Stainless Steel Microwave Oven
How do I replace the fuse in a samsung model smh7135wc
How do I find and check if I have a blown fuse?
  • alan pearlstein Jan 05, 2013
    I'm sorry my samsung model is a SMH7185WC (white)
Replace fuse
follow the next steps and fix it. use the VOM . God bless you
1. No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
3. Open thermal protector or thermal fuse.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some models).f8629014-97b9-47e3-91bd-92cf0f66526b.gif
Jun 16, 2013 | Samsung SMH7178STD Microwave Oven
Samsung microwave not working
First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
God bless you
Apr 02, 2013 | Samsung Microwave Ovens
Heathware infrared oven broke
Remember use the DVOM. First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
God bless you
Apr 02, 2013 | Microwave Ovens
No power
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.Remember use the VOM.
God bless you
Apr 02, 2013 | Electrolux E30MO65GSS Convection Microwave...
My emerson microwave will not power on
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open. Use the VOM
God bless you
Apr 02, 2013 | Emerson Fans Emerson MW8115SS Microwave...
No power
see this causes and fix it. God bless you
Sep 27, 2012 | Kenmore 30 in. Microhood Combination
Kenmore microwave 911 41479791 no power?
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Sep 24, 2012 | Microwave Ovens
Mh3184xpq-4 is dead, i have replaced the fuse...what else could it be?
see the next steps: use the common sense God bless you
Aug 01, 2012 | Whirlpool MH3184XP Microwave Oven
My M4155sp stopped working. No power at all (yes, I checked the power source). Replaced the fuse behind the keypad, - still nothing. Any suggestions?
please see the next step: God bless you
see the diagram attached.
Jul 26, 2012 | Whirlpool MT4155SP Microwave Oven
Does'nt heat up
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Aug 05, 2009 | Samsung Microwave Ovens
Samsung SMH7185STG Stainless Steel Microwave Oven Logo
20 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
