Question about Brakes for Ford Ranger FX4 Off-Road
I haved a ford FX4 I got changed the calipers and now it is bloked
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 137 Answers
SOUNDS LIKE THERE NOT BLED PROPERLY.TAKE BLEEDER SCREW OUT AND CLEAN!!
Posted on Jan 11, 2014
I purchased a 2007 ford ranger fx4 off road automatic supercab at 100000km when i got an oil change at 115000 i was told that the front differential and transfer case oil needed to be changed i went back...
It is impossible to look at fluids and tell if they need to be changed in any vehicle with mileage on it. Many states even have laws against people at service stations from putting your fluid next to new fluid.
The bottom line is as a part gets used it builds up an amount of dirt or sludge. You can change the fluid and a week later it will look exactly like what you took out. That is why you go by mileage not appearance.
Mar 26, 2011 | 2007 Ford Ranger FX4 Off-Road
The passenger front caliper on my 2003 FX4 once in a while will not release all the way. When you beat on it with a hammer it will release. It always seems to do it on Hot days. Is there a solution or...
I suggest replacement....it may stay engaged and cause overheating and seizure of bearings and axle shaft....this is risky if it occurs while driving. Also, these components are a lot more costly than a caliper.. Consider too, that the other caliper is same age and maybe due for failure. !
Sep 07, 2010 | 2003 Ford F150 Regular Cab
2006 F150 FX4 Let off the brake pedal and turn as
its probably your calipal or cran shaft
Apr 11, 2010 | 2006 Ford F-150
Shavings in transmission pan f150 2002 f150 fx4
how big are the shavings? if they're any bigger than metal dust that collected on the magnet i would say there is a serious problem.
Apr 05, 2010 | 2004 Ford F150
My rear end chatters around corners and if im pulling a trailer my abs light and the wrench shaped light will come on in my 2004 f150 fx4 supercrew
If you have a locking rear diff,it could be the clutches on the side gears or lack of fluid and special additive. Sounds like the wheel speed is off enough on corner,to set the ABS light,when it chatters. Don't over look parking brake and rear caliper issues.
Mar 10, 2010 | 2004 Ford F150
LOOKING FOR THE BEST WAY TO LIFT A 2007 FORD RANGER FX4 ROUGHLY A 2" LIFT FRONT AND REAR.
Go for a supension lift. Rancho and skyjacker are two of my favorites. A body lift will allow for bigger tires but you can run into shift linkage problems. With a suspesion lift you get the bigger tires without having to modify little else
Feb 06, 2010 | 2007 Ford Ranger FX4 Off-Road
Does the 2001 F-350 have a limited slip? If Yes, do the have certain issues?
If you have the FX4 option, it does. The FX4 models are basically a standard 4x4 with an Off Road package that includes a few extras like upgraded heavy duty Rancho shocks, limited-slip rear differential, added skid plates for the fuel tank and transfer case, and two "FX4" decals on both back bed-sides instead of the standard "4x4".
I checked the Ford truck forums and found nothing out of the usual for limited-slip differentials as far as having problems. Older years yes, current year don't seem to have problems.
Jan 10, 2010 | 2001 Ford F350 Super Duty SuperCab
I cannot figure out how to get the calipers off of the rear of an F150 FX4. Are the bolts covered somehow?
The bolts should not be covered by anything. You can locate them on the back side of the calipers where the bracket wings down toward the axle.
May 30, 2009 | 2005 Ford F-150
2004 Ford F-150 extended cab FX4. 4WD problem
Your front hubs are automatic locking hubs, and the gears are hard nylon. These hubs break very easily, therefore causing you to lose your front wheel drive in 4 high, or 4 low. If you replace the hubs with "WARN (name brand) " manual locking hubs, you will never have the issue again. Of course, you will have to get out of the truck and manually lock the hubs, but they are metal gears, and much more durable. I've personally seen the issue several times, and changing the hubs has resolved the issue every time.
May 01, 2009 | 2005 Ford F-150
Brakes for Ford Ranger FX4 Off-Road Logo
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
