Question about Car Audio & Video
Delsat pioneered byexperts DSR5500 how to edit
Delsat pioneered byexperts DSR5500 how to edit codes?
On that previous question the product is a Pioneer PD-M910
That is not how it works. You must use the email link to add info that is requested by an expert or go back to the question and edit it.
Jul 28, 2017 | Pioneer Car Audio & Video
Restarted my LX1 and gets stuck on FSck-Data on the display.
Called Pioneer-said my hard drive or data is corrupt-have to send in for repair-flat rate of $695.00 to repair.
Aug 27, 2009 | Pioneer PRV-LX1 DVD Recorder
Pioneer DVR-K17RS ATA ACER CODE=39
Code 39 for cd/dvd drives is a common problem, you need to edit the registry to fix this error. See these instructions on how to fix code 39.
Mar 28, 2009 | Acer Aspire 5610-4648 Notebook
Can't download Roxio Venue Suite that came with my optical drive
Yes, there is something to do with operating system because most likely it only works for 32Bit OS only.
Mar 11, 2009 | Pioneer DVR-213LS DVD±R Dual Layer Burner
My pioneer dvr-k17b ata device failed instalation error code 39 could not load driver
1) uninstall your dvr from device manager
2) write REGEDIT at RUN
3) look for UPPERFILTER using search in the edit menu. After you have found it, delete this registry
4) repeat the same for LOWERFILTER
5) Go to the device manager, scan for hardware changes. Win Vista will now successfully install your DVR
Dec 26, 2008 | Pioneer DVR-212DBK 18X SATA DOUBLE LAYER...
from your description, it's windows problem.
You can either reload your operating system or edit the windows registry.
To edit the windows registry follow this step from Microsoft:
http://support.microsoft.com/kb/314060
Oct 05, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
it's windows issue, you just need to edit windows registry.
Follow this step from microsoft:
Jul 01, 2008 | Acer Aspire 5610-4648 Notebook
Try to remove the device from Device manager, and then reinstall or upgrade the driver. If the error continues to occur, it may be possible to edit the operating system Registry to resolve the issue.
Click the Start button, press run and type regedit.
  1. In the Registry Editor window, in the left pane, double-click the HKEY_LOCAL_MACHINE folder.
  2. In the HKEY_LOCAL_MACHINE folder, double-click the System folder.
  3. In the System folder, double-click the CurrentControlSet folder.
  4. In the CurrentControlSet folder, double-click the Control folder.
  5. In the Control folder, double-click the Class folder.
  6. In the Class folder, click to select the {4D36E965-E325-11CE-BFC1-08002BE10318} folder.
  7. In the right pane, click to select the UpperFilters registry value.
  8. Press Del / Delete to remove the registery entry.
  9. In the Confirm Value Delete dialog box, click the Yes button.
  10. In the right pane, click to select the LowerFilters registry value.
  11. Press Del / Delete to remove the registery entry.
  12. In the Confirm Value Delete dialog box, click the Yes button.
  13. close the regedit window.
  14. Restart the computer.
Feb 11, 2008 | Acer Aspire 5100 Notebook
Car Audio & Video Logo
69 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
