Question about LG 32LD320 32 HDTVReady LCD TV
Problem with LG 32LD320 32 HDTVReady LCD TV
When i turned on the my 32LCD TV, its work good but after 15-20 sec. tv remote & tv buttons not working enough(stop). (but tv channel on air working propoerly) i think there is some software issue When i turned on the my 32LCD TV, its work good but after 15-20 sec. tv remote & tv buttons not working enough(stop). (but tv channel on air working propoerly) i think there is some software issue or any thing els. pl help
SOURCE: LG tv turns on by itself
this problem is with the inner small micro-swtches ,the side buttons inside are getting intermittantely short...changing of those switches will solve the prob. tc--
Posted on Oct 28, 2007
FARADIO
  • 17 Answers
SOURCE: lg lcd tv remote code
HI,
BUY A NEW REMOTE FROM E-BAY OR PARTSTORE.COM,TRY A UNIVERSAL ONE IF STILL DOESN'T WORK TV INTERNAL IR INTERNAL RECEIVER IS FAULTY,THANKS.
Posted on Apr 09, 2008
  • 60 Answers
SOURCE: LG LCD and LG DVD remote codes
If both units are LG you don't have to program anything. Below the power button are 6 buttons labeled TV, DVD, etc. As soon as you push the DVD button the remote should work it. Remember to push the TV button again to make it work the TV.
Posted on Apr 21, 2008
SOURCE: frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
Posted on Feb 28, 2009
Lg lcd tv remote codeTRY ANY OF THESE: 140, 024, 040, 098,043, 259,260, 261
Posted on Jul 27, 2009
LG 32LD320-ZA remote sensor
Replace the remote sensor. this component can be located just behind the infrared window at the front panel.
Jun 13, 2012 | LG 32LD320 32 HDTVReady LCD TV
I need the 4 digit code for my LG 42LD520 in HDTVReady LCD TV to program my Remote. Thanks
Here you can find almost all the Universal remote codes
http://kbase.x10.com/wiki/Universal_Remote_Code_List
you can also manually find it follow your universal remote control user guide If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Mar 05, 2011 | LG 42LD520 42 in. HD-Ready LCD TV
I have an LG, LCD TV, I have picture but no sound
some times you have to turn it off, unplug it, wait for 20 secs and plug it in again and turn it on, this would be the last step after trying the remote control thing, you know, check if mute buttom or volume, or the languaje option, good luck, God bless
Jan 26, 2011 | LG 42LB1DRA 42 in. LCD Television
Comcast tv codes, samsung
Its quit simple to code search using the comcast controller.
Hold the setup button untill it flashes
Press 9 9 1 ...wait a second...press 1again.
Next hit channel up on the remote untill the tv turns off and this may take some time. When the tv turns off press setup to save the settings and try to power the tv on with the comcast remote. If you find that the controller will work the volume and turn the tv off but will not turn the tv on you are on a slightly wrong code and you may need to code search again.
Aug 08, 2010 | Samsung UN32C6500 32 in HDTVReady LCD TV
WHAT SHOULD THE RETURN/EXIT BUTTON DO ON MY REMOTE IT ONLY SEEMS
If you look on page 48 & 49 of your LG TV’s user manual, you will see your TV remote and a description of the buttons.
Your particular remote does not have a previous channel button or function. That backwards arrow button is to return one step in an interactive application or other user interaction functions.
However, if you get the full size LG TV remote it does have a “FLASHBK” button that will go to the prior channel. Some programmable TV remotes have this feature too.
You can go to the TV store and ask to use the larger LG TV remote that has the “FLASHBK” button on your TV on display to see if your TV will perform that function.
Good luck.
May 21, 2010 | LG 42LH200C LCD TV
I have a Zenith TV and need to reprogram my remote.. thank you for the rca ones,,
OK if you need remote code try this:
11423/10017/10463/11265/10145/10092/10030/11145/10016 .OK need how point your remote to your TV then press & hold on remote TV button at the same time remote power button until solid light come up then press & hold play button for 5 sec until TV sleep then press and hold reverse button for 2-3 sec until your TV light up if yes press stop button.
good luck.
Apr 28, 2010 | Universal Remote Control GE174Universal...
Tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Dec 29, 2008 | Vizio L32 32 in. LCD HDTV
Apr 20, 2008 | LG 42LC2D 42 in. LCD HDTV
LG 32LD320 32 HDTVReady LCD TV Logo
23 people viewed this question
Computer Repairing
Computer Repairing
