Question about HP Computers & Internet
Hp laptop pavilion shuts off by itself
HP Pavilion 8330 . My laptop keeps shutting down on its on .
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 30 Answers
Its either a bad power chord or the power supply or fan
Posted on Jan 06, 2013
mailtoravi
  • 186 Answers
SOURCE: how to have access to the processor fan for hp pavilion dv5000
I found the Service Manual of the Notebook which contains the procedure about how to remove each and every component of your Notebook and below is the link to access the same :
http://h10032.www1.hp.com/ctg/Manual/c00700932.pdf
Best way is to copy the entire link and paste it in the address bar of a new web browser and press enter to open the link.
Hope this is helpful...
Posted on Oct 06, 2008
pagebor
  • 2785 Answers
SOURCE: using HP Pavilion ZD8000 laptop
plz check the powersupply unit, processor temperature.
Posted on Nov 29, 2008
  • 2976 Answers
SOURCE: hp laptop shuts itself down
Get a can of air and really blow the intake & exaust ports and ALL fins. A laptop cooler really helps with this problem but, you have to blow them out too.
Google HDD thermometer and download a temperature indicator. It will show you when things are starting to heat up. Mine runs between 25-33 degrees celcius and will shut down randomly around 34 or above.
Posted on Jan 29, 2009
durtopian
  • 408 Answers
SOURCE: i bought HP Pavilion dv5 6 months ago and fan not working
Your cooling fan sounds to have went out,causing it to overheat and shut down.It also could be something in the fan stopping it from turning.Try cleaning it or blowing it out with it off.But it mostly sounds to have went out.
Posted on Aug 05, 2009
  • 15 Answers
SOURCE: HP pavilion laptop shuts down abruptly
It sounds like something is overheating to me. Also, it could be a bad motherboard. Try putting your laptop on a hard surface. I carnt stress this enough. Also, you can try cleaning out the laptops cooling vents with some compressed air (you can get it at pcworld). At the end of the day and it still wont work, send it in for repair. Good luck
Posted on Jun 12, 2010
My hp pavilion dv9720us will run for about ten mins and then shut off
you can try to hover around the fan outlet the dust gathers and stops the cpu cooling down and then the cpu wiil shut down to protect the laptop from overheating if it runs longer but shuts down you will need to get in to the laptop and do the same around the heatsink fan and cpu
Jan 08, 2013 | HP Pavilion dv9000z Notebook
I have a hp pavilion dv1000, it keeps shutting down, I had the fan replaced by Hp six months after I bought it. Is there a recall for this lemon?
are you sure that it shutting down because of fan
it may be a virus problem or OS problem too
try to find out main problem
thanks
Nov 12, 2010 | HP Pavilion dv1000 Notebook
I have a HP Pavilion Entertainment PC. I push the
It sounds like a power supply problem (low voltage), or could be a battery going bad. Also, the vents to the cpu fan could be clogged up and overheating the cpu, causing it to shut down. You can spray the vents and area out with compressed air. Other than that, it will have to be serviced.
Good luck and hope this helps.
Jul 08, 2010 | HP Pavilion DV5234US Notebook Laptop
Pavilion dv4000 PC Notebook: My hp pavilion dv5 laptop runs very hot and then t...
The easiest way to clean it is to use a can of compressed air and blow it through the airflow vents.
Check out this link for other solution.
http://bootmylaptop.com/laptop-shuts-off-after-a-few-minutes/
May 18, 2010 | HP Pavilion dv4000 Notebook
A little more information would help, does it get hot or is the fan doing overtime! Laptops are notorious for sucking in air to cool it as well as all manner of dust fluff and hair which block the air flow and cause over heat and consequently shuts itself down do avoid damage. Ckeck and clean air vents.
Apr 04, 2010 | HP Pavilion dv9000z Notebook
HP Pavilion DV5-1112 15.4 has shut down and can not repair itself.
If its that terminal simply put recovery CD in and boot off CD, follow on screen instruciotns to reformat .
NB = =In doing so will wipe all data from disk.
Dec 21, 2009 | HP Pavilion dv5-1000us Notebook PC
My hp 6700 laptop is not staying on when it is switched on. It keeps wanting to start up, but then shuts itself back down
The motherboard is to blame. These models had bad motherboards. Contact HP support and arrange to have the laptop sent in. There is a service advisory on their website if you dig deep enough. They try to hide it from ya ;)
Oct 27, 2009 | HP Pavilion dv6000z Notebook
Hp laptop shuts itself down
Laptops are designed (by software) to shut themselves off as a protection measure. The most common problem is high temperatures. Do you hear your fan racing while you are using it? Do you sit your laptop on soft surfaces (like the bed or carpet floor) while using it? Do you smoke around your laptop while using it? These are common things that cause high temperatures on your laptop and will cause it to shut down. May not be your case but just a though. I would take it somewhere or open it up yourself(if you are pass your warranty time ONLY) and clean out the dusk with some air.
Hope this helps!
-Curtis
Rate It!
Jan 29, 2009 | HP Pavilion dv5-1000us Notebook PC
Computers & Internet Logo
99 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
