Question about Cisco Catalyst 2908 (WS-C2908-XL) Networking Switch
Hi my cisco router is not working - Cisco Catalyst 2908 (WS-C2908-XL) Networking Switch
  • 1 more comment
  • Gopi Venkatesan
    Gopi Venkatesan May 11, 2010
    Tell me the exact problem,
    is it powering up or not?
    Are you able to login to the router?
    What is the issues you are facing
  • Noe Lana
    Noe Lana May 11, 2010
    1.) is it power on?
    2.) is it properly configure?
  • Dale Van Camp
    Dale Van Camp May 11, 2010
    Can you please elaborate? What isn't working - power, switching, routing, etc?
Hi I heard about the problem of your not working router. Let me give you some hints that might solve your problem.
1. Verify wether your router is getting power.
2. Are there any new changes made to the configurations on the router? If so that might be the problem.
3. Is it giving you an error? If so how often does this error pops up?
4. Is it a repeatal problem or is it the first time you are encountering this problem?
Please take this up with your network administrator and please be honest when answering the questions he/she is asking you about the problematic router.
Posted on Mar 18, 2009
Cisco router does not broadcast
The wifi does not broadcast? Check in the setup page to make sure wifi is turned on and its setup to broadcast (It is possible to set it up to broadcast "invisibly" so strangers can't see the network and use your internet) RTFM
Jan 19, 2014 | Cisco Computers & Internet
My router working slow
A slow router and/or disconnecting wireless router can be caused by several things. Please click on this link and follow my instruction to resolve these issues :-
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
Jun 14, 2010 | Cisco (WS-X3011) Router
Hi, what's a password on the router Cisco Catalyst 2960 default?
Try using username (none) pass public/private/secret or
cisco - cisco, ADMIN - changeme, pixadmin - pixadmin, root - attack, superuser - superuser as username - password. These are the defaults credintials for the Cisco routers.
Stelios.
Feb 22, 2010 | Cisco Rf Catalyst 2960 24-PORT 10/10
Ethrnet problem for cisco 1841 router?
Hi
You must enter the interface configuration mode and issue the command:
no shutdown
Mar 19, 2009 | Cisco (1841) Router (cisco1841)
User manual for cisco 1800
1800 series is a MSR (Multi Service Router) with that you can build a network with voice,data and enhanced security. In selected models Wireless is also available.
Check the manual in the following link
http://www.cisco.com/en/US/products/ps5853/index.html
Mar 13, 2009 | Computers & Internet
Unable to connect 2 routers need help!
Do you have any funky subnets for your Cisco router? Do not connect the wireless router to your network yet, as it may have the same IP address as your other router.
Basically the easiest way to do this is to set a dedicated IP for the 2Wire router on the Cisoo router. Then make them stay on the same subnet, but give an IP range for your Cisco router, like 1-50 or something. If you give the 2Wire router IP .51 for instance, then give the Wifi users on the 2Wire IP range from .52-75 or something.
Make the 2Wire router only use wifi and not serve DHCP addresses. Then you setup the 2Wire router to get its info from the Cisco router.
I searched and there is no howto out there for doing this with a Cisco router. However, here is one I used to setup a similar scenario with a Netgear router. It worked. If you are able to translate a bit, it might work for you:
http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=306896&action_code=5&highlight_info=16778323,235,239&turl=http%3A%2F%2Fkbserver.netgear.com%2Fkb_web_files%2Fn101236.asp&answer_id=6056802#__highlight
Here is another article:
http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=306896&action_code=5&highlight_info=16777285,246,260&turl=http%3A%2F%2Fkbserver.netgear.com%2Fkb_web_files%2FN101496.asp&answer_id=6056800#__highlight
Let me know if you are able to work through this. You need to give the 2wire router a static IP and you need to NOT use it for wired connections, and not use it to serve DHCP settings.
Jan 21, 2009 | 2wire 2700HG-B Router (2700HGB)
Cisco 2960 power supply
The Cisco 2960 has a life time warranty. Contact the seller and they should be able to get the switch exchanged at no cost.
Jul 31, 2008 | Cisco Rf Catalyst 2960 24-PORT 10/10
7910 IP Phone
please check if firewall is ON on your netgear router...
Dec 12, 2007 | Cisco 7910 IP Phone
Cisco Catalyst 2908 (WS-C2908-XL) Networking Switch Logo
107 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
