Question about LG 42PX5D 42 in. Plasma HDTV
Favourite setting lost when switched off
I have set numerous channels under the favourites option but channel seven keeps dropping off the list. When i re-add it to the list it is lost again next time i switch on the unit - all other channels stay fine. Very annoying.
I think it is actually Channel 7 causing the problem. I have the same TV and have noticed that Ch7 only drops off the Favourites list when 7 telecasts a program in Standard Definition (SD) on the High Definition (HD) channel 70. They usually seem to do this when broadcasting sporting events. You can check if they're broadcasting in SD on the HD channel 70 by pressing the "INFO" key (also labelled "<<", just above the "TEXT" key). The channel description will read "70 7 SD Digital" instead of "70 7 HD Digital". (You will also see this when you change to channel 70 during these times.) Every time they've done this, I've lost the 7 HD channel from my favourites list. If you re-program channel 70 into your favourites list while it's broadcasting in SD, it will disappear from the favourites list when 7 starts broadcasting a HD signal again. I think I read somewhere that this happens because channel 7 isn't really transmitting a SD-resolution (576i) program on the HD channel, but instead just redirecting your TV to the SD channel's signal (Ch 7 on the tuner) - or something like that! I haven't yet found a way to stop this from happening other than to not change to HD channel 70 when they're telecasting a SD program! I have to admit, it's annoying, but it's a minor glitch in what I believe is an otherwise outstanding TV. I intend to email Network 7 about this problem. Maybe if the problem is their fault and enough people hassle them about it, they might do something to fix it! - Mav (Australia)
Posted on Aug 24, 2007
SOURCE:
How to set up favourites on foxtel
  1. Press the active button .
  2. Select setup.
  3. Select favourite channels.
  4. Highlight the channel then press the yellow button and an F symbol will appear next to the channel name. ...
  5. Press select to save your favourites.
How to set up my favourite channels on iq3
https://electronicshelponline.blogspot.com/
Aug 12, 2018 | Televison & Video
My channel list is empty. How do I manually add channels. NOT ACTUALLY SCAN.
First you have to connect your source of channels to the television via a receiver, whether satellite or cable, or 'free to air'. Then you instruct your television to scan for all of the channels. Then after that, you can either choose (say) channel 1432 on the remote, or scan upwards from channel 1000, or set it as a favourite.
It sounds to me that you have nothing connected to the television, or the supplier of the signal (the receiver) is switched off :>)
Dec 04, 2016 | Televison & Video
My child pushed buttons on remote and now I only get PG14 channels. How do I allow it to recieve all my cable channels?
check that the tv /receiver is not in favourites mode, there may be an option to sort channels in the channel list...try there.
If you cannot fine the corrective try resetting to default and retuning from scratch.
There may be an option fo isolate the control functionality so that others cannot mess about with the settings, it may need a passcode to be set, try that after correcting the issue
Apr 29, 2015 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
How do I set up a user channel list on my cox remote? I want to set up all subscribed channels, and then a separate group for just the channels i like.
Select settings, select favourite and keep adding channels to that and if necessary you can even name it. All this is there in the settings with help menu visible at the bottom of the screen. Just follow it.
Jul 04, 2012 | Televison & Video
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
Feb 27, 2012 | Toshiba Televison & Video
I have tried to retune my tevion lcd 1507id because of the change in the granada area. The tv retuned but i have no itv, channel4 or channel 5
These will have been rolcated to a different channel number. You can select the programme guide & scroll through all the channels until you find thier new location number, then you could either take note of these new numbers or go into the set up menu where you can re-arrange the channel numbers back to 4/5 etc or set them on your favourites listings
Dec 08, 2009 | Televison & Video
Cant change ''favourite'' channels or get ''menu''
Make sure the batteries are fresh in the remote control ( I am assuming you are using a remote control to access the on screen display) If you have a universal remote and replaced the batteries you most likely will have to enter the code for the specific TV that you have.
Jun 14, 2009 | Televison & Video
Query about listening to radio stations
I created a 'favourites' list of programmes and added the radio channels. Then I could select them in the same way as I did my favourite TV programmes.
Dec 29, 2008 | Televison & Video
We purchased an LCD TV very recently (2 days ago) and when we turned it on it automatically stored the channels in our area. However, after our initial excitment of the picture quality etc we discovered...
Manually type in channel 9 and then hit <enter> so the TV switches to that channel. Then go to the "setup" screen and navigate around until you find the "channel setup" section. There you will find an option to memorize channels, including the channel you are on.
Sep 06, 2008 | Samsung Televison & Video
LG 42PX5D 42 in. Plasma HDTV Logo
422 people viewed this question
Ekse
