Actronair am24-1 zone 3-4 missing after factory reset
I did a factory reset on my am24-1 panel and now i have lost zones 3 & 4 tried the faqs on actron but no succes please help
  • 54 Answers
SOURCE: Carrier 38TXA030 not working
That sounds like a very efficient system Gratz. You can try a reset by throwing the breakers off and back on and check all your micro fuses on boards and zone controllers. GL!
Posted on Jun 11, 2008
SOURCE: zoned system one zone not working
I hit the reset button on the main unit and that reset all the sensors. It was so easy but when I called Carrier's customer service line they told me there was nothing they could recommend. Not very good customer service. Avoid Carrier brand if possible.
Posted on Jan 23, 2009
  • 17 Answers
SOURCE: I get the error code E2 It only shows 2 zones on my 4 zone syst
I reset the circuit breaker to the panel and everything is good now.
Posted on Jun 25, 2009
SOURCE: Yamaha RXV661 Receiver has Zone 2 Vol Fix error message
i have the same problem. i have a rx-v661. i goto the zone 2 settings and try to change the volume and it says VOL FIX. I cannot hear anything out of zone 2. It takes the current volume that is in zone 2, but i cannot hear anything. it has been working fine for at least a year.
Posted on Jun 27, 2009
  • 118 Answers
SOURCE: I have a Yamaha RX-V1400. Can no longer select ZONE 2
check the setup menu in the receiver to reset the outputs for zone use instead of 7.1 use
Posted on Nov 03, 2009
My Honeywell HZ311 3 zone system (Cool & Heat) system all lights are flashing. Please advise how do i reset (restart) the stem. Thank you!
Honeywell TrueZONE HZ311, HZ322, HZ432 Manual
www.manualslib.com > ... > Other > HZ311, HZ322, HZ432
View and Download Honeywell TrueZONE HZ311, HZ322, HZ432 manual online. ...Page 3. Zoning System Design Manual IntroductIon Fig. 2 depicts a typical residential layout with three zones. ... Zoning System Design Manual Plan the Zones In planning azone system, here's what you need: Panel ... Restore password.
Sep 29, 2015 | Cars & Trucks
Change language on DSC maxsys keypad
I can help you default the system. I got this out of the manual.
Hardware Reset of Memory to Factory
Defaults
If the Installer's Code is lost through inadvertent
programming, the only means of reprogramming the
system is by a hardware reset. If the Installer's Lockout is
enabled, there is no way to reprogram the system without
entering the correct Installer's Code.
The PC4010 can also be reset through software in the
installer's programming. See "Factory Default" in the
Programming Guide.
Note: Panels returned to DSC with the Installer's
Lockout feature enabled and no other apparent
problems will be subject to an additional service
charge.
To reset the panel to factory default conditions:
1.Power the system down by removing both AC and
battery power to the main panel.
2.Short the zone 1 terminal and the PGM terminal on the
main panel.
3.Restore power to the main panel.
4.Wait for 20 seconds then remove the short between
the PGM and zone 1.
5.The system will have reloaded the memory with
factory defaults. All modules will have to be enrolled
again. The event buffer is the only part of memory that
is retained during a factory default.
May 21, 2014 | Home Security
Cannot clear zone, how to factory reset SC-100 skylink
There is no factory reset for the zones. User must follow instructions in the manual to clear all the devices in a zone.
Search the manual for "ADVANCED PROGRAMMING". Then look for "TO CLEAR A ZONE". Follow the instructions to clear a zone. Note that zones 1, 2, 3, and 4 are for sensors and zone 5 is for remotes. Each zone can accommodate a maximum of six devices.
Each command can erase one zone. If more than one zone is to be erased, repeat the command for each zone.
Jul 26, 2012 | Skylink Group Skylink Sc-100 Security...
I have a vsx92 that worked great up till my wife disconnected the hdmi cables to swap satellite to cable. Video runs through hdmi to the projector. I do hear audio, all cables are correct but I get no...
We had a similar problem, but was with the audio side. You can attempt the system reset like this;
Use this procedure to reset all the receiver's settings to
the factory default. Use the front panel controls to do this.
Set MULTI-ZONE to OFF.
1 Switch the receiver into standby.
2 While holding down HOME MENU on the front
panel, press ? STANDBY/ON.
The display shows RESET ? NO ?.
3 Press ENTER on the front panel.
4 Select 'RESET' using ?/?, then press ENTER on
the front panel.
The display shows RESET? OK.
5 Press ENTER to confirm.
OK appears in the display to indicate that the receiver
has been reset to the factory default settings.
Hope this helps. I switched to Onkyo for my receiver.
Feb 08, 2011 | Pioneer Audio Players & Recorders
How do i reset my pioneer vsx 919 ah amp reciever back to its original settings
In the manual, page 72
Resetting the system
Use this procedure to reset all the receiver's settings to the factory default. Use the front panel
controls to do this. Set MULTI-ZONE to OFF.
• Disconnect the iPod and USB memory device from the receiver beforehand.
2 While holding down ENTER on the front panel, press ?µ STANDBY/ON.
The display shows RESET < NO >.
3 Select 'RESET' using PRESET +/-, then press ENTER on the front panel.
4 Press ENTER to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default settings.
• Note that all settings will be saved, even if the receiver is unplugged.
Feb 01, 2011 | Pioneer VSX-919AH-K A/V Receiver
I have a dsc power 832, and have replaced the battery, but i can not get it returned to the ready state as it shows an alarm memory stating ''panel lid''. How do i reset this alarm message?
An "alarm Memory" indicates that a zone was activated the last time the system was armed. To view what zone caused the problem press the * key (star) + the 3 key. To reset the memory simply arm the system and disarm. Hope this helps.
Apr 21, 2010 | DSC Power Supervision Relay For Smoke And...
Starck clock wrong time zone
-Make sure clock is in radio sync mode. This is in the manual so won't repeat here.
-Press & release SELECT. Clock time numbers should flash
-Press & hold SELECT. It should enter clock settings mode
-Bottom of screen next to moon phase you should see the current time zone. PST after reset
-UP & DOWN will move through time zones.
-Press & release SELECT when done.
-Each time SELECT is pressed will move to a new setting like 12/24 hour etc.
-Press SELECT until clock numbers stop blinking or leave it alone to return to normal mode
-This should also work on the other Oregon Scientific Starck models.
Feb 08, 2009 | Oregon Scientific Starck Large Music...
Zone 2 issues
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there
Aug 03, 2008 | Yamaha RX-V659 Receiver
No zone 2 sound coming from yamaha amp rx-v861
We had the same problem - I think it was reset when the power went off in a storm. Went to Yamaha website (http://www.yamaha.com/yec/faq/faqdetail.html?CNTID=206010&CTID=5009135) and found the following worked:
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control [SIDE SELECTOR SWITCH] to [AMP]. (Located to the right of the volume buttons on the Remote).
  2. Press the [SET MENU] button on the remote control.
  3. Arrow down to Manual Setup and press the [ENTER] button on the remote control.
  4. Arrow to the Sound Menu option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
Feb 16, 2008 | Yamaha RX-V661 Receiver
Heating & Cooling Logo
412 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
