Question about LG enV VX9900 Cellular Phone
Bad Cell Phone Charger connection
Hi, I've had this Verizon LG EnV VX 8900 for about 5 months, and lately my charger (the cord as well as the cell phone outlet) has been giving me trouble. I don't know exactly why, but it's like I plug in the charger yet my phone just sits there and doesn't charge up, and I don't know why! And then the cord outlet in the bottom of my phone became physically loose, which is not good, and unexpected since I haven't treated it carelessly. For the first couple of weeks since when this happened, I just ever-so-slightly tweaked or moved the charger cord around in the cell phone charger outlet until I got the correct...angle, i guess? And at that point, my phone would charge. But today my battery has died and I've been here sitting with my phone for at least half an hour trying to find the right angle at which to plug my cell charger into my EnV and it simply will NOT charge, and I'm honestly starting to worry. After looking for online advice, I came across several other reports of customers with the same model cell phone and identical problems, claiming that the EnV is a faulty phone/design that should be recalled, and that the only way to fix it is to pay the 50 dollar deductible and just get a new phone. I'm a pre-med student (with no cell phone insurance...I couldn't afford it) who has literally no extra money in my wallet right now, and there's no way I can afford a new phone...I didn't think I'd need to buy another one 5 months into getting this one! I desperately need my cell phone for academic reasons (I'm applying for a prestigious campus position and I NEED my phone working in case I am contacted about the position). What should I do?
  • hastyste Jan 19, 2009
    I'm sorry, I meant to write VX 9900 as the description for my EnV, in case that helps. Please help me, I honestly need some serious help with this, please.
  • Anonymous Mar 25, 2009
    if you look at the connection area on the bottom of the phone, its most likely the metal became enlarged or the thing in the middle is loose.
    i suggest a new phone. if you have insurance, complain and they might just give you a new one.
    Problem Solver:
  • 5 Answers
If you go onto Ebay, you can get something called a universal cell phone charger. This plugs into the wall and charges the battery directly, rather than using the phone port. They cost between one and three dollars. I had the same problem and was told to do this and it works very, very well. Good luck!
Posted on Oct 17, 2009
Well it does that cause you arent taking the cord out right. you prolly damaged the outlet cause of it too.. try a new charger or get a n el cheapo en v or diferent phone off ebay
Posted on Jan 21, 2009
How I increase battery lifebon my enV
turn down the brightness to minimum required ,turn off anything unnesseary that you dont use as bluetooth ,Ir anyting like that, a trick use on my phone which seems to work atleast on my zte blade and my iphone 3GS is to connect the phone to the charger and let it charge to max then i restart the phone and connect the charger again for another hour and the batterylife seems to last one day more
Feb 21, 2011 | LG Pcmicrostore Brand Lg Env Vx 9900...
Loose connection to LG phone charger
use something like a small screwdriver to bend the two metal contacts inside the phone socket up a little so they press more firmly into the mating contacts in the channels on the charger plug.
if the charger plug wants to fall out, you can bend up a cutout/tab in the top metal shell part a little so the plug "clicks in" a little better.
it's a bad design.
Jul 31, 2009 | LG enV VX9900 Cellular Phone
Wont charge
your charging port is loosely connected to *********** board. You need to go to a repair shop and get it fixed.
Apr 18, 2009 | Verizon Communications LG enV Cell Phone -...
How do you dismantle the end of the charger?
Absolutely not. You must use the LG charger, or you might get an improper amount of current into the phone and toast it.
Jan 04, 2009 | LG enV VX9900 Cellular Phone
Ive put my phone on the charge, but it isnt charging, whats the problem? my env cell phone isnt charging when i put it in the charger
Your port could be messed up or it could be the charger. Take it in to verizon and they will look at it for free.
Dec 15, 2008 | LG enV VX9900 Cellular Phone
My daughter's LG EnV charging port
You can get a charger at factorydirectcellular.com. The link is
http://www.factorydirectcellular.com/home/universal/universal-battery-only-charger.htm
The charger charges the battery independent of the phone. It is the only one I have found and it works GREAT. I had a couple issues at first but the rep, Matt, bent over backwards to resolve them. I would recommend this charger and company to anybody. The charger is a universal charger and will charge other cell phone batteries as well. The only con is that it does take a little longer to charge than using the port.
Sep 06, 2008 | LG enV VX9900 Cellular Phone
My enV will not charge!
Hey i think i just figured out the problem to all the port charging issues for the envy and envy 2 phones with verizon. its not the phones, its the charger cord! the part that goes into the phone. it gets pulled out over time from pulling the cord out of the phone all the time. get a pair of pliers. grab the end and push the metal end of the cord against somthing hard, push it back in so it is at the appropriate depth. this should make it charge properly again!
Jul 17, 2008 | LG enV VX9900 Cellular Phone
Broken charger port
i have the same problem with my enV my friend stripped the wires to my charger at the part where you plug it into the phone so now to charge my phone i tape the red wire to the positive on the battery and the black wire to the negitive there will be a shiny metal goldish color thing (there like 4 lil gold bars) on your battery that looks like this --> (negative) | | | | (positive) | - | | | + | tape the wires on the outside were the symbols are - and + and try not to let it toch the middle bars on the battery or it wont work and dont cover the little bars up with tape put the battery back in the phone making sure the wires dont move to much and it should charge sometimes you got tape the battery onto the phone to make sure it doesnt pop out but its what i do and it saves you money on having to go buy a whole new one or if you know someone with the same phone give them your battery to charge it :)
Apr 18, 2008 | LG enV VX9900 Cellular Phone
LG enV VX9900 Cellular Phone Logo
1,106 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
