Question about Video Game Consoles & Games
Unsure how to get the old white Xbox 360 console on hdmi when there is no hdmi plugin for a hdmi cord. On the back there is a cord that says HDTV and TV and I play on AV1 on TV. I have tried to get HD
    New Friend:
    Problem Solver:
  • 6 Answers
HDTV means component
Posted on Jan 05, 2013
Daniel9
  • 58 Answers
SOURCE: Xbox 360 Elite compatible with 62' Mitsubishi HDTV?
I have it and it works great! For all TVs, the TV have to be on fixed settings on standard, dot-by-dot mapping, noise reduction off. The camera's exposure the same for both side-by-side shots. Just set it on standard and it should work...
Posted on Jun 11, 2007
SOURCE: playing dvd's at 1080 resolution with xbox 360
The 360 will upconvert DVDs to 1080P only through a VGA cable or an HDMI cable.
Posted on Dec 11, 2008
lil_fatty_8
  • 44 Answers
SOURCE: cant play games due to "put disc into a xbox 360 console"?
This problem is caused by your disc drive.... A new disc drive bought off of ebay, generally costs about 50 bucks, including the shipping and handling..... You will need to open your xbox to get the model number... yes, it does matter... Once you get the new disc drive... you need to open up the old disc drive... and you will see a memory chip inside and you will need to be VERY careful not to rip any of the parts it is connected to... once you have the chip out... you will need to take the chip out of the new disc drive, and replace it with the chip from your old disc drive... (each xbox 360 has its own unique memory, which can only otherwise be installed by flashing it through a sata computer which much more complicated than it really should be).... once you put the old chip into the new disc drive... put everything back together... for a tutorial on opening an xbox 360 and also fixing disc drive in your 360... i recommend youtube,,, and the person's name i recommend is "fixyourownxbox" These videos are definitely helpful, and saved me mucho dinero $ :D.... Good luck... if you have anymore questions, dont be afraid to ask... i would be more than happy to answer them
Posted on Dec 28, 2008
SOURCE: HOOKING UP XBOX 360 TO HDTV
You have to use the regular red and white cords(not the yellow) and u have to use all 3 hd cords. If ur tv doesnt have a place to put the cords in, then it isnt HD. Also on the plug connecting to the 360, there is a switch that has HD and regular, switch it to HD. hope this helped.
Posted on Feb 19, 2009
techprogrami
  • 57 Answers
SOURCE: Xbox 360 nothing displayed on the screen
first make sure the switch on your cable is on "tv" not "high def"
Posted on Jun 01, 2009
XBOX 360 HDMI Problem green/purple screen
Try the following:
Reconnect your console and TV:
  1. Remove any devices placed between the console and the TV.
  2. Connect the HDMI cable from the back of your console directly into the HDMI port on your HDTV or monitor.
  3. If you're using an audio-only A/V cable, unplug this cable and then connect the HDMI cable from the back of the console directly into the HDMI port on your HDTV or monitor.Learn more about connecting your console to a TV.
Note If your HDTV has an image-enhancement feature or any kind of digital noise-reduction feature, turn this feature off. See your HDTV user manual for instructions.
Jan 24, 2014 | Microsoft Xbox 360 Console
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
I have the new black xbox. We just changed tvs to a new plasma samsung and when i plug all of the cords in and turn on the xbox it works, except that the colors are bloack and white. It gives a good...
make sure that if you have the hd cords plugged in the switch is on hdtv and if the regular cords are plugged in the switch on the a/v cords says tv. make sure the red cord is in the correct socket. if you are using hdmi cord then it needs replacing. also you may find some sucess by changing the output in the xbox settings.
Jul 31, 2011 | Microsoft Xbox 360 Console
Got a new xbox 360 and kinect, have to change my tv settings to play the games i have but then get a very different picture with very dull colours
Ah, this happened to me when i got a 360S. You have an old 360, no? And you used the HDTV conmponent? Go to the console settings, and fool around with the display a bit. You'll find what you want. Just make sure you're using the OLD 360 cord or an HDMI cord; the new ones are **** and only designed to work with extremely old TVs.
Jan 30, 2011 | Microsoft Xbox 360 Console
How do i connect an x box 360 to a HD ready tv please explain simply
Every xbox comes with the HD av cords. However they are not only the standard red, white, and yellow. But they also come with green, blue, and red av cords. These are the HD cords.Your HD tv should have green, blue, and red outlets on the back of the tv. It also has a another red and white outlet under it. So you have to take the HD cords and plug them into the appropriate outlets and then take the red and white cords from the other set of avs and plug them in right under those cords so you will have sound when you turn your xbox on. On my tv the red and white outlet is right under the HD outlet. But your tv may be different. And make sure that the "box" on the cord that reads either TV or HDTV is flicked toward HDTV.
Aug 27, 2010 | Microsoft Xbox 360 Console
XBOX 360 HMDI connection help
Your console must have the HDMI connection inorder for it to use the HDMI cord. Most newer consoles have the connection. If your only connection looks like a trapazoid and there is no connection under it stating HDMI, then you do not have a console with the HDMI connection.
Please visit our eBay store at http://stores.ebay.com/Garons-Biz or from garonsbiz.com for all of your Xbox 360 and PS3 repair item needs
Jul 02, 2010 | Microsoft Xbox 360 Console
Dont know where to plug the cables in on my tv
Depending on how old the TV is, you may have to resort to using the composite plugs (red, white, yellow) plugs instead of the HDMI or component plugs as used with newer hdtv's. Your XBOX should have these cords or adapters available within the packaging. Just double check that you have these in the back of your TV.
Apr 16, 2009 | Microsoft Xbox 360 Pro System Console
Xbox 360
Yes I have mine hooked up to a old Tv
Regards
Mick
Nov 12, 2007 | Microsoft Xbox 360 Elite Console
Xbox 360
On your AV cord theres a switch that changes it from HDTV, to TV
Make sure its switched to TV if your not using HDTV, or switched to HDTV if ur using that. If you need pics let me know I can get you some so you can see where the switch is.
If that doesn't resolve it check your cords, make sure the cords match the colors.
Oct 17, 2007 | Microsoft Xbox 360 Console
How do i connect my 360 to run on HDTV to a bush lcd tv?
HD is a new sort of signal transmitting/receiving technology; therefore, all software and hardware components you have to use must be able to support the relevant technology. (HDMI=High Definition Multimedia Interface)I am not sure if your 360 has an HDMI output, but if it has one, you have to use one of those HDMI cables. As well, the LCD model you mentioned has to be able to support HDMI signals. As I know, scart plugs don't usually support HDMI. Similarly, individual connector cables don't support it either. All you need to have is a digital coax cable.
Apr 16, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
18 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
