Question about Cisco Catalyst 2908 (WS-C2908-XL) Networking Switch
Cisco 2900xl switch - can't type anything in console?
My 2900 series router won't accept input in putty. i get all the output in the beginning, but once it's finished loading and doing post, it just sits there, and i know its on and working because when i unplug devices from the ports, it says line protocol changed state to up, etc.
i think my console port is gone, but im not sure.
  • Dale Van Camp
    Dale Van Camp May 11, 2010
    How are you connecting to the switch using Putty? Via the console port or using telnet?
Login with you aux port and then do a show run and see if you have "no exec" under your con 0 and vty 0 4. If so then:
  1. config t
  2. line con 0
  3. exec
  4. line vty 0 4
  5. exec
  6. ^z
  7. wr
Posted on Mar 06, 2009
Please try using Hyperterminal, it's in accessories> communications>
Use com port and click on "restore default" on next window and then ok. Then try typing it will probably work.
The console port is fine as you can see all the outputs coming from there.
Try changing the settings in putty under keyboard, make sure the bit rate selected is 9600bps.
Regards,
Harshit
Posted on Feb 01, 2009
How configure snmp on cisco 2900 series XL
Posted on Aug 31, 2009
  • 30 Answers
Try using tera term and see if that works
Posted on May 12, 2009
4 Suggested Answers
JonwVBFL
  • 56 Answers
SOURCE: Cisco error on switch
%SYS-4-P2_WARN: 1/Tag 0 The switch generates %SYS-4-P2_WARN: 1/Tag 0… messages.
This example shows the syslog output that you see when this error occurs:
%SYS-4-P2_WARN: 1/Tag [dec] on packet from [ether] port [chars],
but port's native vlan is [dec] This message indicates that an 802.1Q-tagged packet was received on a nontrunk port. The VLAN that is derived from the packet tag is different from the port native VLAN. In the error message:
  • The Tag [dec] is the VLAN identifier from the packet.
  • The [ether] is the host MAC address.
  • The port [chars] is the port identifier.
  • The second [dec] is the native VLAN number.
There is a possibility that the local port is incorrectly configured as an access port instead of a trunk port. Alternately, the remote side can have been configured as a trunk port instead of an access port.
Verify that the local port is not incorrectly configured as an access port instead of a trunk port. Also, verify that the remote side is not configured as a trunk port instead of an access port.
Posted on Feb 06, 2008
NetSalem
  • 55 Answers
SOURCE: cisco catalyst 3500xl (24 port) bad console
It is possible that your console port is configured for a different baud rate. Try to change your baud rate on your hyper terminal going from 115200 down to 2400. If it doesn't work you might have a problem with 232 driver chip that is located on the board next to your console port. You will not be able to find a schematics for this switch, it is not available for the public.
You can send this switch to me. I will glad to fix it for you.
Good luck.
336-416-1802
NetSalem
Posted on Jul 17, 2008
EngineerMC
  • 186 Answers
SOURCE: How do I connect cable modem to cisco 3560 switch and configure it?
The cable modem will need to go through a router because it needs a NAT and PAT translation table, connecting the cable modem direct would lose the ability to get to the internet.
Posted on Jun 16, 2012
I was wondering if the PWR-2911-POE and PWR-2911-AC can be installed in same 2911 router? Thanks.
No, both of them are power supplies. PWR-2911-AC is the standard power supply but the PWR-2911-POE is a bigger power supply to power up EHWIC or single/double-width line cards. Moreover, there is no physical way to put two same/different power supplies into a 2900 router. But 3800/3900 routers can support dual power supplies. Cisco 2900 Router Price Buy Cisco ISR 2900 Series Routers 3Anetwork com
Apr 03, 2015 | Cisco Computers & Internet
Tip
Guide to Reset Password on a Cisco Router
How do I reset the password on my Cisco router?<br />I bought a Cisco 1700 router from an auction, but there is a password. How can I reset the router to original factory specifications? <br /><br />Sky sagem wireless router reset password? I just got this sky wireless router second hand and it has a password set on it. i tried to press the reset button at the back but it does not do any thing, it still comes as a password is set.<br /><br />How to reset password on dlink wireless router? I have a dlink wireless router model number DIR 825 . It works good but I am trying to access internet on my ipod and the password i have set is incorrect , this also happened when i tried to access internet on my laptop. When i first set up my ps3 i dont recall having to put a password in but this was when i first got the router. How do i reset the router password or find out what the password is AND if i reset the password or reset my router will my ps3 have to be reconnected or will it stay?<br /><br />How to reset password on a router? I recently acquired a linksys router (used) and need to know how to reset the password so that I can use it. Also, is there any way to modify a router to be useful as a cell/wifi blocker, or as a signal booster?<br />... <br /> ----From Yahoo Answers<br /><br /><br />To reset password on a Cisco/D-link/Linksys/Netgear router is a very common problem among people who want a secure network environment for surfing on the internet. If you are confused with the complicated procedure to reset or change the password on a router, or if you are trying to configure a Cisco router, but a password is blocking you from enable mode, don't worry, just do the steps as follows, password reset on a router is no longer upset to everyone.<br /><br />First, be informed that what you need:<br />.<a href="http://www.router-switch.com/Price-cisco-routers_c1">Cisco Router</a><br />.Computer<br />.Internet Connection<br />.Blue Serial Cable<br /><br />Guide for You to Reset Password on a Cisco Router:<br />1. Download a program called Putty from the first resource site below. PuTTy is a terminal emulator application which can act as a client for the SSH, Telnet, rlogin, and raw TCP computing protocols (PuTTy on Wikipedia).http://en.wikipedia.org/wiki/PuTTY<br /><br />2. Connect one end of the blue serial cable to the Cisco Router and the other to your computer. Open up the Putty program on your computer and select the radio button next to "serial" on the right-hand side of the start window. Click on the "Open" button in the bottom right-hand corner of the Putty start window to open the terminal.<br /><br />3. Power the Cisco Router on. As soon as the router begins loading in the green and black Putty terminal window, press the "Ctrl" and "Break" keys simultaneously until its going into rommon mode.<br /><br /><br />4. Once in rommon mode, you have to change the configuration register number to make the router boot from a blank configuration file. For the 2800 series Cisco Routers, the command "confreq 0x2142", changing the register number to 2142, worked. Search on cisco.com for information on your particular <a href="http://www.router-switch.com/Price-cisco-routers_c1">Cisco Router Series</a>.<br /><br />5. Type the restart command in rommon mode, which is "reset". This will boot the router up again. When it is finished, you should be able to type "en" to get into enable mode without a password.<br /><br />6. Once you change the running-config in RAM and save it to the startup-config in NVRAM, remember to change the configuration register number back to its default (usually 0x2102). This is important if you change anything on the running-config. <br /><br />Easy five steps help you finish resetting password on a Cisco router. Easy instruction, easy to follow. <br /><br />
on Jul 19, 2011 | Computers & Internet
Tip
Cisco 1841 Router, Hot Sales Product Cisco 1800 Business Router
The Cisco 1841 router is designed for secure data connectivity and provides significant additional value compared to prior generations of Cisco 1700 Series routers by offering more than a fivefold performance increase and integrated hardware-based encryption enabled by an optional Cisco IOS Software security image.<br /><br />The <a href="http://www.router-switch.com/cisco1841-p-97.html">Cisco 1841</a> dramatically increase interface card slot performance and density over the Cisco 1700 Series while maintaining support for more than 30 existing WAN interface cards (WICs) and multiplex trunk cards (voice/WICs [VWICs]-for data only on the Cisco 1841 router).<br /><br />The <a href="http://www.router-switch.com/cisco1841-p-97.html">Cisco 1841 router</a> offers embedded hardware-based encryption enabled by an optional Cisco IOS Software security image; further enhancement of VPN performance with an optional VPN acceleration module; an intrusion prevention system (IPS) and firewall functions; interfaces for a wide range of connectivity requirements, including support for optional integrated switch ports; plus sufficient performance and slot density for future network expansion and advanced applications as well as an integrated real-time clock.<br /><br />Cisco 1841 router Product Details<br />Product Description Cisco 1841 router<br />Device Type Router<br />Form Factor External - modular - 1U<br />Dimensions (WxDxH) 34.3 cm x 27.4 cm x 4.75 cm<br />RAM 128 MB (installed) / 384 MB (max) - SDRAM<br />Flash Memory 32 MB (installed) / 128 MB (max)<br />Data Link Protocol Ethernet, Fast Ethernet<br />Network / Transport Protocol IPSec<br />Remote Management Protocol SNMP<br />Digital Signaling Protocol ADSL over ISDN<br />Features Cisco IOS IP Broadband , firewall protection, 128-bit encryption, hardware encryption, VPN support, VLAN support, Intrusion Prevention System (IPS), 256-bit encryption<br />Power AC 120/230 V ( 50/60 Hz )<br />System Requirements Microsoft Windows 98 Second Edition<br /><br />P.S. If you would like a new sealed Cisco 1841, the competitive price offered at RouterSwitch.com is US$586.00 per. Visit Cisco 1841 to see more...<br /><br />Notes: Router-switch.com is a World's Leading <a href="http://www.router-switch.com/">Cisco Supplier</a>, founded in 2002. It sells new, used and refurbished Cisco network equipment including Cisco routers 800/1800/1900/2800/2900/3800/3900 series, Cisco switches, Cisco Firewalls Security, Cisco IP Phones VOIP, etc.<br /><br />
on Jul 07, 2011 | Computers & Internet
How to Recover the Password for Cisco 2900 Router
www.cisco.com/.../support/routers/...routers/tsd-produ...
Jul 08, 2014 | Computers & Internet
What collaboration capabilities are available on the new Cisco 2900 and 3900 Series routers?
According to my experience and knoledge: the Cisco 2900 and 3900 series platforms have collaboration feature parity with the Cisco 2800 and 3800 Series platforms, so all of the following collaboration capabilities and solutions are present:
• Cisco Unified Survivable Remote Site Telephony (SRST)
• Cisco Unified Border Element
• Time-division multiplexing public-switched-telephone-network (TDM PSTN) and private-branch-exchange (PBX) gateways
• VoiceXML contact-center gateways
• Cisco Unified Communications Manager (UCM) media resources (allowing conferencing, transcoding, and Media Termination Point [MTP])
• Resource Reservation Protocol (RSVP) Agent
• Cisco Unified Communications Manager Express (CME)
• Cisco Unified SIP Proxy
• Gatekeeper
Cisco 3900 Series Routers
Jun 25, 2014 | Computers & Internet
Tip
How to Select a Very Right Router for Home or Business
No matter which group you belong to or stay with? If you want to connect outside world through computer, router is an essential element of modern home and business networks. A router lets your computer connect to the Web to read your favorite Web sites, check e-mail, IM friends, or teleconference with colleagues....
When we speak of routers, I usually think of Cisco---a network giant, even though so many others such as Nortel, D-link, Netgear, etc. Because Cisco router is considered as the top choice while choosing a router for home or office, and the more important is that Cisco System offer SOHO, small, medium and large-sized offices or enterprises with different types of routers to meet their different needs.
As we known, the popular Cisco router in the market are Cisco 800 series, Cisco 1800 series, Cisco 1900 series, Cisco 2800, Cisco 2900, Cisco 3800, 3900, 7200 and 7600, etc.(for small to large businesses), also Cisco Linksys-E series for home.
More choice, harder to select the very one for family or for enterprise. But it doesn't matter if you evaluate and weigh the following eight criteria that can help you figure out which router best fits your needs.
Your Usage and Router's Performance For home or for office (small or large size?), first be clear about it. Different demands require different performance of router. For example, choosing a one for family, you may just want to surf on the internet, no need of a router as a heavy-duty gamer or a small business, Cisco Linksys-E series will fit you. Because you know the more expensive the router, the more features it will contain. However, it doesn't necessarily buy a higher performance router. And for business, especially for large or head offices, router's higher performance and safety is vital elements which must be considered while buying. Cisco 1800, 1900, 2800, 2900(for small to medium-sized business or enterprise branch office, Cisco 3800, Cisco 3900, Cisco 7200, Cisco 7600(for medium to large-sized business and enterprise head office), these types can meet companies' various requirements...
Expandability The router usually has a default number of interfaces-but some routers, such as the 3600 series, have none. So, pay attention to the number of interfaces you can add on top of the default.
Router's Integrated Services This refers to functionality supported by a router that previously required separate boxes. For example, a 16- or 32-port switching module in a router negates the need for an Ethernet switch; having a firewall, VPN server, and IDS/IPS sensor in a router can negate the need for a firewall, VPN concentrator, and dedicated IDS/IPS appliance.
Support and Reliability Cisco routers are traditionally reliable, and Cisco is always offering a high level of support. When purchasing a router, you will have various levels of support options. Select the best level for your organization. Of course, using these features in your decision-making process requires some research. You could peruse the Cisco Routers Product Portfolio, scan through the specifications, and select the router yourself. Or, you could also use the criteria above to work with are seller or directly with Cisco to determine which routers offer the features you need.
Warranties Router manufacturers always provide a warranty package together with their equipment. The length and terms of these warranties vary widely. A better warranty may indicate a manufacturer more committed to support their products, while a lesser warranty could indicate a somewhat lesser standard of product quality or reliability. Always consider router warranties when making your purchase decision.
Router's Cost Router manufacturers or router suppliers (like Cisco router supplier) sometimes offer rebates or other discounts from the full retail price of their routers. So you can buy a suitable router at a very great price while router is at a big discount. (Routerswitch.com, hardware.com, often have big discount for hot routers, like Cisco 1800, Cisco 1900, Cisco 2800, Cisco 2900, etc.
Actually, besides considering router's basic function, performance, quality and style, you must notice router's price. So you'd better make a comparison among different routers in order to choose a highly efficient and cost-effective one.
More you need pay attention to while buying a router...
on Jun 15, 2011 | Computers & Internet
Console interface problem on the switch
HyperTerminal sucks. Use PuTTY and make sure you have the correct baud rate of 9600 set.
Putty Link:
http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html
Mar 30, 2010 | Cisco Catalyst 3550-24 24-Port Ethernet...
I had forgotten the password of my Cisco Catalyst 3550 Switch
password recovery procedure 3550 catalyst cisco switch
1>Attach a terminal or PC with terminal emulation (for example, Hyper Terminal) to the console port of the switch. Use the following terminal settings: ¨ Bits per second (baud): 9600 ¨ Data bits: 8 ¨ Parity: None ¨ Stop bits: 1 2>Unplug the power cable. 3>Power the switch and bring it to the switch: prompt 4>Issue the flash_init command 5>Issue the load_helper command. switch: load_helper switch: 6>Issue the dir flash: command. Note: Make sure to type a colon ":" after the dir flash.
7>Type rename flash:config.text flash:config.old to rename the configuration file. 8>Issue the boot command to boot the system. switch: boot Loading "flash:c3500xl−c3h2s−mz.120−5.WC7.bin"...############################### ################################################################################ ###################################################################### 9>Enter "n" at the prompt to abort the initial configuration dialog. −−− System Configuration Dialog −−− At any point you may enter a question mark '?' for help. Use ctrl−c to abort configuration dialog at any prompt. Default settings are in square brackets '[]'. Continue with configuration dialog? [yes/no]: n !−−− Type "n" for no. Press RETURN to get started. !−−− Press Return or Enter. Switch> !−−− The Switch> prompt is displayed. 10>At the switch prompt, type en to enter enable mode. Switch>en Switch# 11>Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#copy flash:config.text system:running−config Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded.
Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded. 12>Overwrite the current passwords that you do not know. Choose a strong password with at least one capital letter, one number, and one special character. Note: Overwrite the passwords which are necessary. You need not overwrite all of the mentioned passwords. Sw1# conf t !−−− To overwrite existing secret password Sw1(config)#enable secret <new_secret_password> 13>!−−− To overwrite existing enable password Sw1(config)#enable password <new_enable_password> !−−− To overwrite existing vty password Sw1(config)#line vty 0 15 Sw1(config−line)#password <new_vty_password> Sw1(config−line)#login !−−− To overwrite existing console password Sw1(config−line)#line con 0 Sw1(config−line)#password <new_console_password> Write the running configuration to the configuration file with the write memory command. Sw1#write memory Building configuration... [OK]
Mar 24, 2009 | Cisco Catalyst 3550-24 24-Port Ethernet...
Cisco Catalyst 2908 (WS-C2908-XL) Networking Switch Logo
2,342 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
