Question about Dishwashers
Age favorit 438 not taking on water just Making a loud noise This happened before but resolved itself cannot figure out why it's suddenly stopped as was working fine before power cut!
    New Friend:
    Problem Solver:
  • 6 Answers
Check the inlet filter on the hose at the tap?
Posted on Jan 05, 2013
bigg t
  • 640 Answers
SOURCE: Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Posted on Feb 24, 2008
aborcass
  • 2651 Answers
debris caught iside pump assy is what it sounds like
  • 11 Answers
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Posted on Jan 15, 2009
SOURCE: Kenmore Ultra Wash water supply started making
It sounds like the solenoid valves which let in the water are not fully opening and causing chatter -- probably corroded . Turning the washer-water supply faucets down (to the left) will probably stop it, but the solenoid valves need to be checked.
The reason opening the sink faucet stops the noise is that it reduces the water pressure to the washer -- this is the same effect as turning the washer faucets down.
Posted on May 05, 2009
  • 39 Answers
SOURCE: making a loud noise and not pumping water into
not sure of the make, but check the drain hoses for stoppage
http://www.squidoo.com/Bosch_Dishwasher_Drainage_Problem_Fixes
Posted on Nov 02, 2009
The dryer suddenly started making a very loud scratching/clanging noise while running, it is NOT a thumping noise. can't figure out how to remove front
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
May 19, 2011 | LG Dryers
I have a H100ID1 natural gas heater. For the past 2 weeks it has been heating the water but making a loud banging noise and shaking the whole heater. It stopped making the noise and won't heat the water....
Is it leaking? Has anything shaken loose inside? If you can get it to light the cause and fix for the banging and shaking is here: https://sites.google.com/site/haywardpoolheater/
Takes about 30 minute and you are done, but you have to figure out what else has gone wrong to stop it lighting
Jul 01, 2010 | Hayward 100,000 BTU Pool Heater H100ID1 -...
The outdoor fan on my central a/c is suddenly making a lot of noise. I have a Bryant - model #697CNO36. Thanks
Depending on the age and usage of the motor. And whether or not the motor is an oil-free motor or not will help to determine the problem.
Most times, a loud noise coming from a motor itself is contributed to the bearings going bad in the motor. This can be cause by lack of maintenance, blades out of balance, or the blade too far down the shaft and creating unusual wear on the motor.
You will most likely need to replace the motor and run capacitor in order to get rid of the noise. But only finding out how and why the noise started will allow you to prevent it from happening again.
Jan 12, 2010 | Bryant 463AAC008BA Air Conditioner
Loud noises
did you size the gas line properly? sometimes if the gas pipe isn't sized properly it will cause some pretty loud wistling noises. also if you have something in the fan like bugs or lots of dust it will cause alot of problems with noises
Jul 24, 2009 | Rinnai Digital Remote Water Heater Control...
Suddenly making loud static noise
I have a dect 6.0 cordless phone and all of a sudden it started making this very loud, high pitched continuous whisltling sound. It only stopped when I took the batteries out. After putting them in the phone seems fine now.
Any ideas what happened?
Jun 28, 2009 | Uniden Cordless Phone
Loud noise from Fan and compressor
i have the same problem with mine. I took the back cover off at the bottom and the fan was going. get a scredriver and barely touch the center of the fan while it is on and if it stops making the noise then it is the fan motor. The bearings are getting ready to go out and it needs to be replaced.
Mar 22, 2009 | Samsung 24.8 Cu. Ft. Side-by-Side...
Spin cycle not working, was making loud noises,water won't drain
i dont have a model number ..just tip unit prop it up try and spin unit with belt on with your hand ,,than take belt off and spin pump pully..by itself...onthejob
Jan 24, 2009 | Maytag Performa PAV2200
Loud noise
Replace the water valve... It"s vibrating when closing. Do you have hot water feeding the unit?
Oct 22, 2008 | Aprilaire 550 Humidifier
Refrigerator is making a loid noise
** the y do sound directly related. water is dripping down your ice maker falling on to bucket? well a small amount of water is also falling onto the evaporator fan assy, freezing and the **ise you hear is that fan blade "cutting" through the ice.you can lift the arm turning the Ice maker to the off position, itll stop calling for water,and your **ise should stop as well
Mar 10, 2008 | Refrigerators
Dishwashers Logo
18 people viewed this question
Top Dishwashers Experts
