Question about Refrigerators
Daewoo US style Fridge-freezer FRN-U20IA Fridge is fine & freezer cold but fan at top of freezer has stopped circulating so cold air all at bottom. Consequently items on top 2 shelves not freezing - help please
  • humphreyscri Jan 07, 2013
    Does anyone know if the fan can be replaced / mended or is it a circuit board problem?
4 Suggested Answers
  • 125 Answers
SOURCE: Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Posted on Feb 07, 2008
  • 9 Answers
SOURCE: freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Posted on Jul 09, 2009
SOURCE: The bottom freezer keeps icing up at the intake
The problem is with the defrosting system. Likely one of three components: the defrost timer, the defrost thermostat, or the defrost heating element. In my case, it was the thermostat. But first check out the timer since it is easily accessible under the front of the freezer. A red shaft sticks out. It has a notch in it, so make a mark on the housing, lined up with the notch, and check over a few hours to make sure it is turning. If not, you need to replace it. If it turns OK, turn off the power and remove it. Check the resistance between contacts 1-4 while rotating the shaft manually. It should read zero ohms for most of the rotation, then be an open circuit for the rest of the rotation. Now check the resistance between contacts 1-2 during rotation. Most of the rotation, it should be an open circuit, then zero ohms for a small part of the rotation. If it fails this test, replace it. If it passes, then the problem is most likely the thermostat. You need to turn off the power and remove the drawers and drawer rails of the freezer, then remove the back panel. Defrost, if you haven't done that already, and remove the thermostat. You can test it (see below), but I would suggest just ordering a new one and replacing since this is likely the culprit if the defrost timer is OK. If you want to test it, check its resistance at room temp (should be an open circuit), then stick in a a working freezer for an hour or so, and test it immediately after pulling it out of the freezer (now should have very little resistance). If it is an open circuit when cold, no power can get to the defrost heating element! GOOD LUCK
Posted on Sep 15, 2009
Daewoo FRN-U20IA top of freezer compartment won't freeze
It was the fan at the top of the freezer that had stopped working after 3 years, therefore the freezing air wasn't getting to the top of the freezer. From the inside, unscrew light unit and unclip, pop out two circular discs at top and unscrew one screw. Unscrew 2 more screws and prise the back panel off. (Arrows mark the clips). Pull off fan, take out motor, replace (keeping rubber bits) and push back fan with a bit of nail varnish on spindle. Put everything back together. Turn on, depress door light switch and after 30 seconds fan should rotate. You can buy a fan on eBay or from www.4daewoo.co.uk for about 40 pounds.
Feb 27, 2013 | Daewoo FRSU20IA Freezer
Freezer is working fine. Bottom Control for Crispers working fine. Upper section of fridge not getting cold.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
May 26, 2011 | Frigidaire Refrigerators
Freezer works fine but the refigerator does not get cool
Oct 11, 2010 | Frigidaire FRT17G4B Top Freezer...
The freezer compartment of my daewoo FRN-U20DA is not cold enough and the ice is melting. The fan does not come on and there is no fault indicated on the display panel.
when the fan is not working. you cannot expect an ice cause the fan is to drive the cold to become an ice and to maintain the coldness.
Jun 23, 2010 | Freezers
Whirlpool side by side - freezer is fine. Fridge not cold
This is a common problem, and worth fixing if the frig isn't to old. The frig is making cold air just fine, which is a plus! All we need to do is get that air to circulate throughout the entire appliance.
Behind the freezer wall is a fan called an evaporator fan. This fan simply blows the air straight up the back of the freezer. From here it enters the frig at the top left and sinks to the bottom. Then it re-enters the freezer and continues its loop :D
So, either the circulation is being obstructed by something (maybe ice build up), or the fan is out.
Behind the freezer wall is the evaporator fan (that has probably stopped moving). Either ice build up (or some obstruction) has stopped it, or it has just served its time and needs to be replaced. Generally I would just replace it. You never know if it has been damaged from ice blockage or whatever the problem may be. If the motor is trying to spin and it is being held in place, bearing could be wearing out or completely gone which will just cause you more pain in the near future. So replace that puppy and you should be all set! :D good luck!
P.S. Naturally, if the fan is fine but you have something blocking the air flow, just fix the air flow problem in an apppropriate manor :)
May 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Daewoo FRS2021IAL has a warm fridge
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 26, 2009 | Daewoo Refrigerators
We had a power outage and top half will not work
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 08, 2009 | Refrigerators
Freezer is working fine but the fridge has stoped workin the model number is enb5289x
I was unable to locate your specific model number but the following rules apply. The usual cause of this is a blockage in the air flow from the freezer to the fridge side.
1. Possible stick baffle valve. This a the vent that allows air to enter at the top of the fridge from the freezer. Check it for obstruction. Alternately if the return vent is blocked the same problem will occur.
2. a defrost problem will cause the air circulation to stop. This can usually be seen by a large amount of frost build up on the back wall of the freezer. This will require a more thorough diagnosis as the circuit contains several parts which could fail.
3. Bad circulation fan. This will not force the air to circulate causing a warm fridge and a cold freezer.
Jul 28, 2008 | Electrolux Refrigerators
Fridge doesn't get cold enough
 If the evaporator fan is not running. The fan itself could be faulty or the door operated light/fan switch could be faulty.
If the evaporator fan is running. The fridge is not defrosting and ice has built up on the evaporator and the air is not circulating properly into the fridge compartment. The fan circulates cold air into the fridge and back through the fridge control which is normally just an adjustable flap which allows more or less cold into the fridge depending on the setting. If the fridge is not defrosting, the defrost timer could be faulty or heater element could be blown.
Nov 03, 2007 | Roper RT12VKX Top Freezer Refrigerator
Daewoo Fridge Freezer not getting cold
Possible problems are a bad evaporator fan motor or a defrost problem. If the back panel in the freezer is frosted up then it is a defrost problem. If no frost listen for the fan in the freezer. If you don't hear it then it may be the problem. Not circulating the cold air.
Oct 04, 2007 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
