What does error 1 mean on a swan sw1020w washing machine 1400 spin 6kg load
gdmisp
  • 66 Answers
SOURCE: washing machine
BELT NEEDS REPLACED OUR THE DIREC DRIVE NEEDS U JOINT.
Posted on Jul 03, 2008
barkencoa
  • 3463 Answers
SOURCE: Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
Thanks.
Posted on May 27, 2009
GodBlessU
  • 3513 Answers
SOURCE: Hi, there i a knocking noise during the spin cycle
I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. Also another way to check is to move the inner durm up and down to see if there is any play in it
Check for bearing failure by seeing if there is any vertical movement between the moving stainless drum and the fixed outer drum. There should be no vertical movement between them - if there is the bearings have failed and will soon collapse. Check for rusty spray around where the pulley shaft enters the outer drum - early indication of seal and bearing failure. Another method of checking is to remove the drive belt and rotate the drum by hand - there should be no noise, roughness or resistance to rotation. Changing bearings is an involved job, only attempt if you are mechanically competent.
As for changing the bearings.
Power off, remove covers. Disconnect drive belt, remove drive pulley. Remove heater, thermostat and pressure switch. Check if drum splits at front, rear or the middle. If the drum is a plastic welded one- ie one which doesn't split, then its game over. If it splits at front or middle, drum will prob. need removal from machine. This involves dismantling the suspension and damping system and removal of door seal and concrete weights. Undo the drum fixing system - either a clamping ring or a series of peripheral bolts and split the drum. If the drum splits at the rear, removal from machine probably not required. Remove the clamping system and pull off the rear plate. Seal and bearings will come away with the plate. Seal needs to be dug out with a suitable lever and the old bearings hammered out with a punch from opposing sides of the backplate. Refitting is, as they say, a reversal of the above process.
However Unplug the appliance and take the top off.
Check the weight on the top to see if it's slack.
Open the door and with your palm upward put it on the edge of the drum.
Lift it until the weight comes on. Is there a lot of movement?
Press down on the inner drum and swing it side to side, does it sound/feel rough?
Finally, tip the machine rearward a little and from underneath check to see if the front weight is loose.
If all of the above are ok then it's likely the drum support spider has broken one of it's legs and the inner drum is knocking as it spins.
To sort this out you would need to strip the appliance down and remove the inner drum to try and change the bearings and the inner drum support.
This is a major strip down of the appliance.
Hope this helps
Thanks for contacting fixya.com
Posted on Nov 12, 2009
SOURCE: telmann washing machine 6kg has
  • i have found with this washer usually E3 is that the magnet has come out of the top.. under the lid there is ment to be a little magnet black sits in the little gap to the right of the machine lid. without that it wont work properly. hope this helps
Posted on Aug 04, 2010
tunde007
  • 2382 Answers
SOURCE: i have a zanussi 1200 6kg washing machine.
Hi, the flashing red light is an indication that you have a problem with your machine not spinning and draining.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Posted on Nov 20, 2010
The erore E33 little swan front loading w/ machine
I suggest that you search online for "error code e33 + little swan" you'll find most websites will offer some information.
Jul 11, 2015 | Washing Machines
How can I find out the age of my washing machine
where did you buy it from they may have records on your purchases and could advise you on the purchase date.
Feb 24, 2015 | Indesit IWC6105 1000 Spin 6kg Load Washing...
How long does it take in a full cycle of wash to dry
Depends on several things. How big the drum is eg 6 kg or 7kg .the spin speed... The material ie. cotton drys faster than woollen items.is it a washer dryer or do you have a separate dryer.normal full load 6kg on a 1200 rpm spin of mixed fibres takes 1 hours 30 mins at 40 c then the dry time can take roughly 1 hour to 90 mins.
Dec 23, 2014 | Washing Machines
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
Dec 20, 2012 | Fisher and Paykel Washing Machines
LG washing machine direct drive when i put it on it washes and goes down to 9 mins then stops, sometimes an error code comes up UE? CAN U HELP PLEASE
It means Unbalanced Error, it means the machine cant balance the load during the spin cycle, normally happens if there is too little a load i.e 1 or 2 things or overloaded. It is designed to protect the bearings. If it happens with a normal load try stopping it and re-arranging the load by hand and putting it on a spin only cycle. Hope this helps.
Feb 28, 2011 | Washing Machines
6kg 1400 spin I do not have a manual
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Feb 14, 2011 | Zanussi Washing Machines
We have a Samsung WF8802 RPZ washing machine with a 5ud fault code. What is the problem?
We have a Samsung WF8604NGW front loading dimond 6kg washing machine. We had the 5ud error message. It turned out the filter was clogged with fluff from a new set of bathroom mats my wife washed. To fix: Put the machine on to drain (if poss) - should be 1 minute on our machine however as the machine was so clogged it took around 15 to finish. Also use the draning tube located next to the filter (on our machine) to get rid of as much water as poss. Now remove filter and clear (warning some water will remain in the system) Before spinning any laundry run the rinse cycle (with an empty drum) a couple of times and clear the filter each time. If the filter is still clogged the laundry will spin heavy as the water will still be in the drum leaving you with no very dry laundry and a horrible noise during the spin. Regards Rik.
Nov 14, 2010 | Samsung Washing Machines
Bad vibration during spin
Good morning! It's common to a washing machine to go out of balance everytime we exceeded the prescribed capacity load (as indicated in the enclosed manual upon purchase of the unit). the fitted new pump is not the source of such problem. Please try to review the manual of your machine and take note of the required capacity load which I think should not exceed 6kg. Best regards.
May 02, 2009 | Washing Machines
Err 7
Err7 is a motor error.Check out the following Haier washer manual link (page number 17).
for washer manual click here
The only solution suggested is to replace the motor.
Jan 08, 2009 | Haier Washing Machines
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
