Question about HP EliteBook 2530p Notebook
Slow running, take long time to open programs
CPU usage 20-30% memory 1.30GB difregmented, even with all programs closed, still takes forever to open any thing, also very slow to boot up, and to wake up from sleep
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 30 Answers
Download iobit advance system care 6 and run it and it it will show you whats slowing down your computer
Posted on Jan 06, 2013
What does high CPU usage mean?
Most times the hard drive is full, delete any thing you don't want ,to free up space . increase ram to four GB if you can. Get rid of add-ons Run a anti virus programe.
Mar 06, 2015 | Computers & Internet
Tip
How to Protect PC from Overheating?
Laptop over heating which is also known as Thermal Overload.This is mainly due to excess usage of CPU(More than 60%) for a long time.
To check CPU usage Right click on Task Bar>Select Start Task Manager>Performance.
or
Shortcut Ctrl+Shift+Esc
If your CPU usage is more than 50% you need to close some applications which are using 20++% CPU.
To check application which are using 20++% CPU
Right click on Task Bar>Select Start Task Manager> Processes
Search in this dialog box for programs which are using 30++% CPU
You need to close this application to prevent PC from over heating.Actually %age usage indicates load to CPU by the application.If load is to much CPU is to processes at faster speed which in turn increases temperature of CPU.
To close the program select the program,and select End Process.
If didn't found any program using 30++% CPU in this dialog box.
Select Show process from all users. and search in this dialog box and close the program.
Caution:some times your system also uses 30++% CPU inn some processes like anti virus scanning,at this if you closed the program your PC may shutdown.At this time you need to restart the PC.
This usually happens for out dated anti virus or incompatible programs.
There are some other factors like Graphics Properties and Graphic Memory,Display size, Processor type,etc.At this time its better top use a cooling pad.
Some program like camera drivers,Simulation softwares,games uses 50+% CPU.This is common these programs need to process large amount of data at short interval time which increases CPU usage but this is normal.
The processors properties are tested at 140*c so no need to worry.If the CPU exceeds the limited temperature PC will shuts down automatically,and after cooling you need to start the PC.
Thank you...:)
ANY SUGGESTIONS...?
on Feb 16, 2011 | Computers & Internet
Hi. Have Dell Xps i7 processor in (C:/ Drive 11 GB free space) and some time going very slow (page opening) & showing popups (Low Memory) like 1MB.. once I did Disk refrigerant after that solve problem but...
Given the info provided and the general performance problem, a couple of things you could try are:
1. Search for and remove malware
2. Remove unwanted software that have been installed in soft stealth mode
3. Identify high-resource app and disable/remove it
In the same order, here are guidelines on how to do each:
1. Malware Removal
Download on-demand scanners.
Update your regular antivirus program.
Disconnect from the Internet and reboot in Safe mode
Install and run the on-demand scanners
Run a full scan of your regular antivirus program.
There are any number of web sites that offer detailed instructions on the above process. Two reliable ones are:
How to Remove Malware From Your Windows PC
How to easily clean an infected computer Malware Removal Guide
2. Remove Unwanted Software
i. Click on Start, Control Panel, then on Uninstall a Program
ii. Scan through the list of installed software for suspicious looking programs. If in doubt, google the name of the program to understand its purpose.
iii. If you identify any unwanted program, right-click on it and select Uninstall/Change.
iv. When done uninstalling, simply close the Program Uninstall utility.
Usually a reboot is not necessary, but if the program publisher indicates that one is necessary, you should do so.
3. Identify High-Resource Apps
Here you run the Task Manager to identify apps that are unusually high CPU and/or memory users as well as being software that you are not aware of or don't usually use. Sometimes, it could be a legit app but is suffering a conflict with some other app, and causing the performance degradation. If both conflicting apps are legit, you could try uninstalling and re-installing them.
To run Task Manager, right-click anywhere on empty space in the Task Bar, then select Start Task Manager. Click on the Processes tab to see individual apps, their CPU and memory usage. Click on the CPU column-header to re-order the apps by CPU usage, then on Memory for memory usage.
Oct 09, 2013 | Dell Computers & Internet
My Intel D945PVS motherboard has become very slow. I tried to add memory (4g) but no help. I think it could be the motherboard or cpu. I see the cpu running at 100% a lot of time. Can you help.
I will suggest to see running processes. It will show you what processes are running and which uses more memory (also cpu usage). It might be some virus or unwanted program.
May 09, 2012 | Intel Desktop Board D945PVS - Mainboard -...
Slow running of window vista
There are many things that might cause your PC to run slowly or restart at time and then. It could be a fragmented disk; fragmented registry; a virus, Trojan, or spy ware; high CPU and/or utilization due to too many programs running; high disk I/O; or something else.
To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager Button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, Google the name and you should find what the process is for.
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. Here is a few good virus scanners that you can run to check your PC:
http://c74b6qq6lbo8zlievtv2q810g1.hop.clickbank.net/?tid=DMWDH6W3
Nov 24, 2011 | HP Pavilion dv9000z Notebook
Memory full while i'm browsing
before this happens open task manager (press ctrl alt delete simultaneously).
under performance tab see cpu usage and memory.
cpu usage should be about 2% normally.
memory should not be full.
if cpu usage seems high then a virus is trying this act or you have unwanted programs which you my end from startup.
second case is of some problem in ram
Jun 17, 2011 | Computers & Internet
My laptop is operating very slowly!I dont understand the problem!
1. First of all download and install CCleaner, it is free.
Here is the link http://www.filehippo.com/download_ccleaner/download/1d59b13e3d0824a0c054077615cab5c3/
2. Run the exe and then follow the instruction to install the ccleaner.
3. After opening the ccleaner, select all the check boxes inside the cleaner tab.
4. Click on Run Cleaner.
5. Click on Registry in the left side tab.
6. Click on scan for issues, then click on fix selected issues. Click on no when asked to back up.
7. Go to Tools Tab and then click on startup tab, Now uncheck all unnecessary and unknown application from being startup.
8. Restart ur computer.
Check now the performance.
If you think there is any virus in your pc, then scan your pc with ESET NOD32 On demand scanner or install Quick Heal. If you want free antivirus then download and install avast home edition 5.0 and register for 1 year free license. (WWW.AVAST.COM)
** After doing all this, if u further want to improve ur system performance then tell me the Operating System installed in your system then I will tell you how to improve.
Jan 31, 2011 | Computers & Internet
I had to replace the motherboard, now have problems with XP
A few hints where to start looking:
  • Open the Task Manager, switch to the Performance tab and check the CPU load. If you see a constant high CPU usage, switch to the Processes tab and check which process causes the high CPU load (column "CPU").
    Also check the memory usage graph on the Performance tab. Memory usage should be low, let's say around 400MB if not many programs are running.
    In the "Physical Memory" section, check the Total value. It should (approximately) show the amount of memory actually installed.
  • Open the Device Manager (Control Panel --> System --> Hardware tab --> Device Manager).
    If error icons are displayed, try to reinstall the drivers for these devices (download the latest versions from the manufacturer's website, if possible)
  • Open the Event Viewer (Control Panel --> Administrative Tools --> Computer Management --> Event Viewer) . Check all logs for errors and warnings. Try to understand and to solve the problems. Especially pay attention to those that did not occur before the time that you changed the motherboard.
Mar 10, 2010 | ZT Group Cisnet PC Desktop
I have a AcerPower FH P4 -- 100% CPU usage all the time prob...
Boot your PC into "Safe Mode" (tapping the F8 key on boot to get to the option) and run a full/complete Virus scan with Anti Virus with up to date virus definitions and see what that yields.
Feb 09, 2009 | AcerPower FH - P4 631 3 GHz (S6463624) PC...
DVD BURNING : TAKES TOO MUCH TIME AND CPU USAGE GOES TO 60%
Based on the laptop model you have listed, I am afraid to say that there is not much that you can do about the time it takes to burn DVDs. Computers often come with re-writeable (RW) drives that have different speeds. Thus, on older laptops or desktops, the drives are very often slow and will take a large amount of time to burn a full DVD. As for the CPU usage, writing data from a hard drive to a DVD or a CD is a very memory and performance heavy task, especially on older computers. You can attempt to free up resources by closing as many non-essential programs as possible prior to burning a DVD... but that will not dramatically increase the speed. Not using the laptop for other purposes while it is burning a disc may also speed up the process.
Nov 01, 2007 | Dell Inspiron 2200 Notebook
HP EliteBook 2530p Notebook Logo
300 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
