Question about Polar Watches
Polar Rs800 Error code 138
Error code 138 is displayed after changing the battery
4 Suggested Answers
escapement
  • 2334 Answers
SOURCE: Error after changing battery in polar watch
Follow this link:
http://www.polar.fi/en/support/product_support?product=125
This is original Polar support site.Here you will find all the info available.
Rate me, please.
Posted on Mar 28, 2009
SOURCE: Polar F11F Error 16
you need to hold down all 4 or 5 buttons at once. This will reset your watch and bring up the message "welcome to polar fitness world". Press ok button 1x to start your setup process.
Posted on Mar 09, 2010
Coachphil
  • 347 Answers
SOURCE: Polar RS800: display/digits disappear when
Send into Polar, you may have a possible warranty issue, some of the older versions of this model had a glitch that was this exact problem.
www.polarusa.com or www.polar.fi for who to send into your area. This needs to be sent directly to Polar not the authorized service centers.
Posted on Apr 09, 2011
Polar rs800 watch intermittent screen fade
that is a sign the battery needs changing
Aug 29, 2012 | Polar Watches
Polar RS800: display/digits disappear when I press on start (red) button - batteries are not low, and same does not happen when I press any other button
Apr 09, 2011 | Polar RS800 Heart Rate Running Computer...
It appears my F6 monitor is not keeping accurant time on calories and heart rate. I like the watch but while checking my sitting heart rate is very low. When checking the heart rate on a blood pressure...
First you need to understand that the Polar system is a medical grade device and it is calculating calories based on specific information that you have inputed and heart rate data from your heart.
Most treadmills and other exercise machines use a much simpler counter that is height and weight based to calculate calories and are generally over generous with their numbers.
Depending on the blood pressure machine you are using, the pulse (not heart rate) is coming through the brachial artery, again not quite as accurate as measuring r-r variance from your heart. There is a ton of literature you can read if you are into the accurateness of the system, but I will sum up with saying that you actual calorie expenditure will be closer on the Polar than on most other devices outside of a hospital. As too the heart rate this is also true, so more likely you are getting inaccurate numbers from the other devices.
If you want pinpoint accuracy then you will need to use the Polar RS800 or S810 devices that measure and display true R-R.
Jan 12, 2011 | Polar F6 Wrist Watch
I just replaced battery since my scren was blank and now all I get as error code 14. What is the problem? How do I fix?
Pull the battery, walk away for an hour + then try again. Sometimes the new battery does not seat right and there is a residual memory issue.
If you continue to get error messages you can either try another battery or you will have to send in to polar. There is a link for the authorized service centers on my tips and tricks page.
Dec 15, 2010 | Polar RS400sd Heart Rate Running Computer...
I just replaced the battery on my polar watch and 'error' and the number 6 is on the screen. Nothing i do will unfreeze this or change it. Have already tried to take the battery out and put back in
You probably need to "short out" the battery before you can set it.
To do this you need to remove the caseback and apply a tweezers to the battery and the "AC".
The AC is usually labeled and it looks like a little gold cricle near the battery in the watch. (I realize there may be more than one gold colored small circle in there, and if it's not labeled it will take trial and error.)
With the tweezers, or paperclip would work, touch the AC and the battery at the same time and hold for a few seconds, then release and repeat once more. This should get your watch reset and ready for you to set.
Oct 23, 2009 | Polar F6 Wrist Watch
How do I change the battery?
Someone posted a link on how to change the batter on an F11. If it's not longer under warranty or you just don't want to bother with sending it back and the extra costs, you could follow this: http://timlaqua.com/2008/09/how-to-replace-the-battery-in-a-polar-f11-heart-rate-monitor-hrm/
Jun 10, 2009 | Polar M32 Heart Rate Monitor Watch
Follow this link:
Rate me, please.
Mar 28, 2009 | Polar F6 Wrist Watch
Polar F6
It sounds like most of you have the heart rate set to display in % of max heart rate. Most Polar products have the option of heart rate in BPM(beats per minute) or percentage of max.
If you look at the display during the exercise, you will see a % icon. You can turn it off in by hitting the back button and go down to HR view settings.
Hope this helps.
Chris @ Polar USA
Aug 02, 2008 | Polar F6 Wrist Watch
AXN 300 Watch
Here is the link to the user manual for your watch; http://www.polarusa.com/manuals/AXN300.pdf Check page 9 - you have to re-enter these basic settings after removing the battery, this may clear the error message although i was unable to confirm this from the manual. contact polar on; http://www.polarusa.com/default.asp and you can find a service centre who can check your watch, all the necessary link software downloads etc. Hope this helps :)
Oct 03, 2006 | Polar AXN 300 Watch
Watches Logo
53 people viewed this question
Top Polar Watches Experts
Jerry Greenberg
Jerry Greenberg
NOEL
NOEL
David Payne
David Payne
Are you a Polar Watch Expert? Answer questions, earn points and help others
