Question about Databecker Instant LabelMaker (2087368) for PC
I can't install Data Becker CD LabelMaker On Windows XP
I ordered this software because i had used it before. When i got it, it showed it was for Windows 95/98. I have XP. I tried using the program compatability wizard, but this didn't fix the problem. The Install Screen comes up, but when you click Install Application, the hourglass appears, and then goes away with no further action Is there something i can do to fix this? If not, Can you reccomend a software for printing CD Labels & Jewel Case Inserts that will use the DataBecker Media I have on hand.
I can't install labe databecker 98 version. I have window xp
Posted on Apr 25, 2009
You asked a long time ago. If you still use XP get Plus! for Windows XP, which contains a label creator programme based on the Data Becker software. Works perfectly.
Posted on Mar 22, 2009
My computer keeps showing blue screens, and my software is corrupted. How can I restore my files without the WINDOWS XP CD?
The Windows XP installation CD includes an option to repair an existing Windows XP installation. Using this option allows you to reinstall Windows without losing the files, personal data and programs you already have on the system. To take advantage of it, just place the CD into your CD or DVD drive on your PC and reboot the computer. During the installation you will be prompted if you wish to use the recovery console to repair a Windows installation. The recovery console is rather limited in its use, so just press the Enter key to proceed with the installation as you would normally.
blank.gif Press F8 to continue past the Licensing Agreement.
blank.gif The next screen should display a prompt asking you if you wish to repair an existing installation. Select your Windows installation (most likely it is the only one) and press R.
blank.gif This will begin the repair and reinstallation of Windows. The installation will copy files to the hard drive, reboot the system, and then proceed just like a normal installation. Follow the prompts just as you normally would any normal Windows installation.
When the installation completes, you should still be able to access all of your documents and installed programs.
Sep 22, 2011 | Computers & Internet
Tip
How-to repair Windows XP, How to Perform an In-Place Upgrade
One of the best kept secrets of Windows XP is it's built in repair feature!
In previous versions of Windows, correcting an operating system error, or installing a new motherboard, usually meant formating and reinstalling, resulting in loss of all data. Don't worry; Windows XP repair feature won't delete your data, installed programs, personal information, or settings. It just repairs the operating system!
Why would I want to reinstall Windows XP?
1) Can't start Windows XP in safe mode.
2) You have problems caused by a recently installed system update (Windows Update, hotfix, Windows XP service pack, or Microsoft Internet Explorer update).
3) Your problems can't be solved with system restore, or you can't access system restore.
4) You've installed a new motherboard, or made other major hardware changes and need to reinstall Windows.
Let's get started!
Step 1: Rule out hardware issues. Windows Repair will only fix software problems. Hardware issues can also cause boot problems (i.e. bad hard drive, memory, CPU, or power supply).
Step 2: Backup. It's always a good idea to backup your important data before making changes to Windows XP. Relax, if you follow these instructions your data will be perfectly safe.
Step 3: Boot from your Windows XP CD. Insert the Windows XP CD into your computer's CD-ROM or DVD-ROM drive, and then restart your computer. When the "Press any key to boot from CD" message appears on the screen, press a key to start your computer from the Windows XP CD. Can't boot from your CD? Please see the note at the bottom of this page (Configuring Your Computer to Boot from CD).
Step 4: A blue screen will appear and begin loading Windows XP Setup from the CD.
Note: RAID/SCSI/Unsupported UDMA users:
You will be prompted to "press F6 to install any third party SCSI or RAID drivers". Most users will not have to press F6, but if you are running RAID, SCSI or unsupported UDMA controllers, then you will have to have your controller drivers on a floppy disk. If you are unsure whether you have RAID/SCSI, then simply let the CD load without pressing F6.
When completed loading files, you will be presented with the following "Windows Setup" screen, and your first option. Select "To set up Windows XP now, press ENTER". DO NOT select Recovery Console.
Note: The system repair function will remove any updates you have previously installed that are not included on the CD. Drivers will also be reverted to their original XP versions, as well as some settings (network & performance settings may sometimes be reset to their defaults). It may be necessary to reactivate your Windows XP as well. When finished, you will have to download all of the updates from Microsoft Windows Update, because they are all replaced during repair.
Let's get started!
When presented with the screen below. press the F8 key to continue
Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation, or install a fresh copy of Windows XP.
If no installations are found, then you will not be given the option to repair. This may happen if the data or partition on your drive is too corrupted.
Note: If you install a fresh copy, all data on that partition will be lost!
Your almost finished! Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts, and have your CD-KEY ready if needed.
Do you have more than one system, or lost your CD-KEY? Visit the keyfinder page to retrieve your CD-KEY.
Update: Due to the proliferation of the Blaster and Welchia Worm/Virus be aware that a Repair Install will leave your system vulnerable. You can get infected within seconds. Do not go on line until you have enabled XP's firewall first.
Remember to run Windows Update! (install critical updates first)
Many computers are not configured to boot from the CDROM. If you cannot boot from the CDROM, this is probably due to the boot order of your devices being incorrect. You can change this in the BIOS.
You enter the BIOS from the first screen you see when you turn your computer on. To enter your BIOS, most users here will press the DEL key.
Most Dell, Toshiba, Gateway, Sony & HP systems will press F2.
Compaq users will usually have to press F10.
IBM typically uses F1 or F2.
Other brands may have different keys to press to enter setup, F1, F2, Del, Tab and CTRL+S. If possible see the manual for your computer or motherboard. Also, the BIOS will usually display which button to press to "enter setup" during POST (if it flashes by too fast, press the Pause key).
When you enter the BIOS setup, you need to change the boot order. The CDROM should be setup before the Hard Drive. Each BIOS is different, but here is an example:
on Jun 18, 2010 | Computers & Internet
Will your software work on my Mac running OS 10.6.2 I bought your CD labels and need a design template
Unfortunately the Memorex LabelMaker ExpressIt Label Design Studio software is only compatible with Windows 98SE, Me, 2000, and XP.
If you install Boot Camp, you can install Windows and use this software in a virtual computer. (However, you need a licensed copy of Windows.)
There are third party video editing software packages that have label design components (Roxio Toast is one package.) The Memorex labels should be compatible with some of these programs.
I wish that I had better news.
May 18, 2011 | Memorex LabelMaker
I do not have the code of installation, my game is original and I preserve everything, except the manual. Thank you and sorry my bad english jeje.
Unfortunately, when games get to be that old if you don't have your CD key you're kind of out of luck. You could try calling Data Becker and get them to give you a new code, but I cannot guarantee that they will give you one.
Mar 02, 2011 | Data Becker HighLand Warriors for Windows
How install window xp & how to connect data card or setup for internet
To install Windows XP you first need a bootable Windows XP Disc or an ISO image. Using that you can boot your windows and install the operating system.
Once you get your bootable Disc or boot from the disc and follow the onscreen instructions to install the windows xp operating system. Make sure that you have all the data of yours backed up and you have a geniune windows xp product key.
once your operating system is intalled, connect the data card and insert the cd that came along with the datacard to install the drivers and the software. incase you did not get a cd, or you dont have one, please visit the site of the datacard manufacturer and download an appropriate drivers and software and install them. This should get your data card up and running.
Thanks and please remember to rate and leave a testimonial if you find the solution useful.
Feb 22, 2011 | Cell Phones
I'm trying to install CD Label Maker (Data Becker)and can't install to windows 7 (64 bit). Is there an upgrade availabe? Installation CD is for Windows 95/98
Often old programs will install if you go to the CD and make install.exe or start.exe "run as administrator".
Some times you also then have to run the program, after it is installed, in compatibility mode. Again, right click on the program icon, select the compatibility tab, select an old OS like XP or what ever the program used to run in.
Aug 22, 2010 | Computers & Internet
My window xp is corrept what to do
Don't worry it is very easy to fix it.
Let's get started!
When presented with the screen below. press the F8 key to continue.
Jun 24, 2010 | Computers & Internet
Hw to copy my Your Handwriting fonts from Windows 98 to XP
i had the same proble mabe the file is crupted or bad sector try to use ur 98 os cd to fix it
Aug 05, 2009 | Databecker DATA BECKER 1000 Essential...
Data Becke30,000. Business Card software I can't reinstall the CD
If you did not go to Start/Settings/Control Panel and deleted it from there....You can try the following....
1. Go to the desktop trashcan and see if the icons for the
software is there. If it is highlight rightclick and select restore.
2. Launch Windows Explorer, select the C: drive if it asks for
permission to display the contents say yes or ok.
Look for Program Files folder and open it. Look for a folder
that resembles the program name i.e. Databecker or something
similar to it. Open the folder and look for an *.exe file tthat may
have a large file size. (*note may contain subfolders so keep
opening them)
3. You can try a System Restore
a. Start/Programs/Accessories/System Tools/System Restore
b. Try to restore to a day that you think you had the
program available
Good Luck
Jan 21, 2009 | Databecker Computers & Internet
Asus m2n-mx se plus windows xp wont boot
All you need is the hard drive manufacture's setup software. Flashing you're bios is not the answer. On each drive (SATA & IDE) is the name & model number. Go to the Mf's site & download the free setup software, tools & utilities. Most sites will list software you can download to creat a bootable floppy disk or software to creat a bootable CD. Run the software on the SATA drive. Than unplug the SATA data cable & connect one IDE at a time. Again down load the Mfg's setup software. Do the same for the other IDE. Disconnect the data cable for the IDE drives. Do a fresh install of windows. (DO not allow windows to format the drive)! Just install windows & the motherboard drivers. Than update windows. Durring reboot press & hold the power on button on the PC untill it powers off. Connect the two IDE drives. Check the pin settings on the IDE drives. Set AS; Primary IDE drive 1 as master with a slave. Set IDE two as a slave drive.
Check the bios Boot setting. Make sure the SATA drive is listed in the boot order. Save & exit the PC. Windows should boot just fine.
Good Luck!
Still have an issue, post the trouble here with a description.
Mike
Jun 27, 2008 | ASUS M2N-MX Motherboard
Computers & Internet Logo
359 people viewed this question
Top Databecker Computers & Internet Experts
Lawrence Oravetz
ray gallant
Are you a Databecker Computer and Internet Expert? Answer questions, earn points and help others
