Question about Trilogy Alarm Lock T2 TRILOGY® Digital Locks DL2700
After putting in the code i get a green light but wont unlatch
Lock wouldnt unlock from key pad i get a green light from code turn handle wont open im getting power to motor when putting code in and the key will open it
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: key in code, lite turns
Dos it work with the key?
THanks!
Posted on Oct 12, 2010
  • 963 Answers
SOURCE: I have a Trilogy DL
This is the website for Alarm Lock, the manufacturer:
http://www.alarmlock.com
First find out if you are dealing with a D2700 or the newer enhanced version. Press any 2 buttons and *,if you get a green LED and 6 beeps it is the new version.
Then please contact them for technical assistance.
Posted on Nov 08, 2011
Key wouldnt open door today put key in ingition it wouldnt start, no lights coming on at all? it isnt the battery as its been checked
The Key would not work the Door Lock or your Remote?
Corrosion on your Battery if no lights are coming on or your Battery is going bad and you need to recheck it
Apr 12, 2013 | Cars & Trucks
We have a Sentry safe model number SC 3877. We just changed the batteries. We are imutting the correct code, the light turns green but does not give the 1 beep and we cannot open the safe. If we put in...
http://callitout.com/quotes/index.php/kick-it-to-the-curb/55/sentry-fire-safe-wont-open-its-broken/
Its the most reazonable answer and it worked!!!!!!! dial the code and tap on the handle so it would get lose
Jan 16, 2011 | Sentry Fireproof Safe
How to set up th ebatteries in my sentry safe DSW5781?
Locksmiths agree
1. Remove and discard the screw (if
equipped) at the base of the lock case.
2. Turn the electronic lock case to the
right (clockwise), from 12 o’clock to
2 o’clock, and remove.
• Insert 4 new AA batteries (not included) to power
this lock.
• Replace the electronic lock case and turn to the
left (to 12 o’clock) to reassemble.
NOTE: The yellow LED will light when the batteries
need to be replaced.
3. Turn the key (if your safe is equipped with a key
lock) to the right so the lock cylinder pops out.
4. Enter the factory code. When the green light appears, you
have four seconds to turn the handle down to
open. Try this several times before proceeding to
the next step.
To unlock safe:
Enter the 5-digit factory code, a pre-programmed
user code, or a pre-programmed user pin
programming instructions. When the
green LED lights you have 4 seconds to turn the
handle and open the safe.
To lock safe:
Close the door and return the handle to the
horizontal position. For greatest security, depress
the key lock (if equipped) with your finger.
Aug 15, 2010 | Sentry Fireproof Safe
Fault in Central Locking
The barrel is easy to remove and based on replacing mine(the same problem with someone elses help) when a rat forced it with a screwdriver one night but failed except to damage 3 of my locks.Open the door and by the inside area of the door handle end theres a small torx screw, undo it a few turns and the smaller piece of the handle will be loose to the touch, turn a little more(screw wont come out fully) and remove the barrel in one piece.I stripped mine and using a breakers yard barrel i took the numbered little key slots inside and put them in the same code as mine to use the origional key.All key slots are numbered so write down your sequence when stripping down it's easy.
Dec 22, 2009 | 2000 Volkswagen Passat 4Motion
Factory code will not open model # DA3831 safe
i am a locksmith that has worked on several of these. The safe is manufactuered with three types of lock mechanisms 1. combo dial 2. digital 3. advanced digital the advanced digital is what you have there are no green lights on it. look at the manual carefully there are 2 seperate sections on the digital key pads yours will be the second.
Nov 23, 2008 | Sentry Fireproof Safe
My sentry safe will not open after entering the code it reads "err"
You have to press the program / enter button after you enter the code How to open electronic sentry safes.
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open
Aug 10, 2008 | Sentry Fireproof Safe
How to open my safe with the code
Apr 18, 2008 | Sentry Fireproof Safe
Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
Mar 29, 2008 | Sentry Fireproof Safe
Forgot how to open my fireproof lockbox
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
Nov 03, 2007 | Sentry Fireproof Safe
Trilogy Alarm Lock T2 TRILOGY® Digital Locks DL2700 Logo
137 people viewed this question
Top Trilogy Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Trilogy Lock and Locksmithing Expert? Answer questions, earn points and help others
