Question about HP Pavilion dv9000z Notebook
Keyboard malfunction Whenever I turn the numpad on and off, the keyboard buttons such as 'j' or 'k' start typing numbers. (This computer has a built in numberpad so the keyboard should not be showing numbers at any point.) I tried re-installing the drivers, but to no effect.
  • mricu Mar 08, 2009
    We have the same problem with our DV9000 laptop! It was just returned from HP due to their Limited Warranty Service Enhancement (because wireless card stopped workinh and left hinge was broken) and they replaced the mother board.
    After calling HP they say the built in recovery does not have the proper drivers for the keyboard and I needed to buy the recovery DVDs from them. I'm trying to look for a work around:-(
  • 44 Answers
Most laptop keyboards use some letters of the right hand as numpad.
You must see some numbers in blue color over that letters.
This is why those letters write numbers when you turn on the Numpad.
Posted on Jan 19, 2009
My Satellite A100 laptop has no numerric key pad so how can I type special characters?
you should have numbers on the keyboard which you can access using the Fn button... you can also use these without the FN button by htting the NumLock button, then use as normal keypad....
other that that try using the Alt button and the Fn with the corresponding digits.So hold down Alt, FN and tap the corresponding digits/letters on the keyboard.
If you need to use a numpad a lot, then can purchase a USB numpad - often included with USB kits from gadget shops.
Nov 29, 2013 | Toshiba Satellite A205-S4617 Notebook
Hi good day. I'm having a problem with a compaq mini 110c-1010EE netbook. Number "4" is the usual input that comes out whenever i open the start menu on a windows 7 OS. Also when i open skype or...
all that to say the built in keyboard is dead.?
please tell what it does and does, not do...
lets stick to simple first. notepad wins SIMPLE hands down.!
try usb standard keyboard yet?
it must work .
this helps prove what's failing,
i take it a mouse works USB and then built in pad right?
if not the OS is corrupted.
or the run box.
you click start button, and then click run or search
and the keyboard is dead.
i think there is switch for turning on the screen keyboard (virtual )
that may be turned on, but you'd see that clear as day on the screen.
so in effect there are 3 keyboad.
the screen keyboard.
the main kbd
and a desktop usb keyboard.
which work and not, tell the reason, why.
if all were dead,then the OS is corrupted.
Sep 18, 2017 | Compaq Computers & Internet
Function key plus number pad doesnt work. numpad is supposed to be fn key plus the four rows of 7890 uiop jkl; m,./ if NumLock is off, the +-*/ work, but not the numbers. the numbers behave as...
A numpad usually outputs the cursor movements with the shift bar depressed. That suggests to me that you need to turn of the Caps lock key, or otherwise make a change to the keyboard setup. Maybe there's a Fn key combo that needs to be toggled.
Oct 15, 2017 | ASUS 90-A4C1K1000 Keyboard
What is the fastest way of typing an é? I have been going through start, accessories, system tools, character map, copying, pasting, but there must be a quicker way?
If you are doing this on a laptop then you are stuck. About the only way is to use character map and copy as you have been or to try to program a quick start key to paste it.
The ALT-0233 is meant to be used on a 101 key pc type keyboard and the laptops do not use the same layout. Your only options would be to use a external keyboard instead of the built in one. I've tried a few things such as the built in numpad using function and an external numpad but neither worked for me. Your laptop may be different so it worth trying.
Sep 01, 2009 | Acer NSK8458AN Keyboard
KEYBOARD NUMBERS
There should be a button called "numlock" which will enable to you use the keypad to the right of the keyboard, however, you don't need to "lock" the keyboard to use the numbers on the top row.
Apr 15, 2009 | Dell 0Y3740 Keyboard
Keyboard acts like a keypad
Sounds like your Nom Lock button is on! It turns 7890 uio jkl m,. to numpad. You can just switch it off with num lock button top right on keyboard.
Best wishes,
Chillimar
Jan 27, 2009 | IBM ThinkPad T40 2373 Notebook
Toshiba satellite note book
Your laptop keyboard has a modern emulated numpad. It acts like the numpad on a regular keyboard (since there clearly isn't room for one on your lappy).
Make sure that you are not holding the Fn key while typing, and most important, turn off Numlock. (There should be a button for it on your keyboard and a light that shows if it's on accordingly, the light should have a number and lock logo on it).
Hope this helps! Stay spicy and happy lappying!
Dec 16, 2008 | Computers & Internet
How do i get a pound sign on a dell computer
Press and hold the Alt+key and while doing that type 0163 using the numpad.
This means on your notebook keyboard, you have to hold the Alt and Fn-key and than press the keys which contain the blue numbers.
So in your case press: m j o l in this order...
Regards,
Thx_nb
Dec 14, 2008 | Dell 0Y3740 Keyboard
Half my keyboard prints lettersand the other half iopklm prints numbers i changed key boards and the new one is the same
What keyboard brand and model do you have?
I know for laptops that if you have the numlock on it changes those keys to type numbers. It could be the same for your desktop keyboard if it doesn't have a numpad at the right side.
Aug 16, 2008 | Computers & Internet
Number pad
There is a Fn key on the bottom left of the keyboard and a num lock key at the top right of the keyboard (depending on the model) Hold the Fn key and then press the num lock key, that should fix your problem.
Dec 10, 2007 | Zippy EL-610 Electron Luminescent Keyboard
HP Pavilion dv9000z Notebook Logo
262 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
