Question about Amana AOCS3040SS Electric Single Oven
Concealed oven I bought a new house with this oven and i am not having manual.I tried to bake pasta 2-3 times in my oven.The cheese on the top becomes red in 20 minutes but the pasta on the bottom was not even hot properly as there are no rods at the bottom. Then i read online that it has concealed bake but how to use that ? Can i get manual from anywhere? Thanks Ritu
  • pely Nov 18, 2007
    I tried to cook a turkey in the SMEG oven, the top was cooking and the bottom not even getting hot, I read somewhere that food should neither be cooked with water in the baking dish, or covered with foil, both of which I did is this correct, and if so why.
  • 76 Answers
Consealed bake means that the bake element on the bottom had a metal plate above it to make it easier to clean and to allow you to use the lower racks without burning the bottom of your food. To use, you want to make sure that the oven temperature that you set has been reached before putting in your food to be cooked. You also should put the racks one notch lower than you normally would. If you do this, you should have no problems with your food cooking unevenly.
Posted on Jul 11, 2007
SOURCE:
How do I bake a store bought frozen pie in my proline convection oven ?
2 Easy Ways to Cook a Frozen Pie - wikiHow
https://www.wikihow.com/Cook-a-Frozen-Pie
  1. Cached
Rating: 64% - ‎28 votes Baking a frozen pie can be simple-open the box, toss the pie in the oven, and ... I baked a store-bought frozen pie in my new oven in the regular bake mode. Missing: proline
Baking Directions - Willamette Valley Pie Company
https://www.wvpie.com/products/baking-directions/
  1. Cached
  2. Similar
DO NOT DEFROST, keep this pie frozen until you're ready to bake it. ... If the crust becomes darker than you think it should be, cover it with foil for the last ... Convection oven: Bake for 80 to 85 minutes at 330 degrees F. Ovens may vary. ... Our Product Line · Buy in Your Area · Fundraisers · Baking Directions · Pie Ingredients ... Missing: proline
How to get pie crust to brown on the bottom - Flourish - King Arthur Flour
https://blog.kingarthurflour.com/2017/.../how-to-get-pie-crust-to-brown-on-the-botto...
  1. Cached
Nov 13, 2017 - KitchenAid Pro Line Mixer ... Getting a brown, flaky/crispy bottom crust on your pie is all about ... Placing them on the oven's middle rack to bake resulted in pie with ... And you can keep using it - so long as you place it on your oven's .... For a two crust apple pie convection bake would work, but I would ...
43 best Eat Convection Oven Recipes images on Pinterest ' Cooking ...
https://www.pinterest.com/candijjj/eat-convection-oven-recipes/
  1. Similar
See more ideas about Cooking recipes, Toaster ovens and Convection oven recipes. ... Bring the oil to a boil for a quick and easy dessert recipe for chocolate ...... Toaster Oven Recipes - Prepare Chicken Pot Pie in a Toaster Oven! .... Tip: If you can& find microwavable ravioli, use one bag to 16 ounces) frozen ravioli.
32 best Toaster Oven Treats images on Pinterest ' Toaster oven ...
https://www.pinterest.com/blackanddecker/toaster-oven-treats/
  1. Similar
See more ideas about Toaster oven recipes, Toaster ovens and Convection oven recipes ... Homemade Toaster Strudels - these are SO much better than the store bought kind... ...... Toaster Oven Mini-Pies are easy to make and absolutely yummy! ..... Oven toasted Ravioli using frozen ravioli, sounds like a yummy appetizer ...
May 24, 2018 | Ovens
How to bake pizza, how much time to keep
Do you have one of those microwaves with the built in broil and bake unit where you would pull the pan out from the top?! If so, I don't know! :o ....but based on my experience in making pizzas, I strongly recommend that you put it on for 5 minutes intervals at about 375 degrees (+/- 25 degrees) and check it until the cheese in the middle is melted. I would NOT recommend putting it directly in the microwave using infrared radiation bc pizza like that tastes really bad. In an oven, put the pizza on for about 15 minutes and check every 3-5 min after that.
May 05, 2012 | Ovens
I have kenmore gas oven ignitor glows but will not light
Hello there:
It doesn't bake dot_lineone.gif Bake igniter
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
If you are certain the igniter is ok, it might be a good idea to call a professional appliance technician.
Need a new oven igniter? Click here for most common oven igniters or enter your oven model number in our PART SEARCH. ^ top clear.gif It doesn't broil dot_lineone.gif Broil igniter
When the broil igniter becomes weak or burns out, your oven would not broil. The broil igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the broil igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_range_oven.aspx#ixzz1CgFQ7lBJ
Feb 01, 2011 | Kenmore 33169 Gas Single Oven
Broiler works, but bake doesn't
make sure oven is set for manual and not time bake if set for manual and oven does not come on check the bake element any appliance parts house can test your element
Nov 18, 2010 | Frigidaire PLEB27T9DC Electric Double Oven
Can i slow cook in my oven, does it have aslow cook facility i have lost my manual, if it does please explain what to do. thanks
No, there is no slow cook. The bottom oven works as a normal fan assisted oven and the top oven relies on elements concealed in the floor. The top oven takes a long time to warm up.
Oct 30, 2010 | Stoves 720EF Electric Double Oven
Getting oven back on fahrenheit instead of celsius
Actually for the Whirlpool Accubake I just figured out, the bake button didn't work, but holding the broil button did the trick.
Apr 19, 2009 | Ovens
OVEN NOT BROWNING CAKES
put dynamite in container. if it blows up, too bad
Apr 12, 2009 | Jenn-Air JGW8130A Electric Single Oven
Bake and Broil not working
Product manuals
Product manuals are available for most in-stock items.
Order a product manual by calling 1-800-366-PART (1-800-366-7278). Or download a free product manual at ManageMyHome.com.
Aug 01, 2008 | Kenmore 33169 Gas Single Oven
I want the oven to start when I am not there, how does it work
you probly have a time bake feature built into the oven each one diff consult the manual, if your oven has it itll be listed there
Feb 23, 2008 | Maytag CWE4800A Electric Single Oven
Using the ovens
It's not dumb, it's the oven. You simply hit bake, temperature and then bake again. Of course you have to choose whether to bake or convection bake and you choose this when you hit the first and last bake command.
Oct 19, 2007 | Jenn-Air WW30430P Stainless Steel Electric...
Amana AOCS3040SS Electric Single Oven Logo
298 people viewed this question
Top Amana Ovens Experts
Steve Allison
Steve Allison
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you an Amana Oven Expert? Answer questions, earn points and help others
