Question about TallyGenicom 6306 Matrix Printer
Tally Genicom displays an error "Ribbon Fault" and stops printing. How do I rectify this problem?
4 Suggested Answers
Techvisitor
  • 63 Answers
SOURCE: error on tally genicom 6312
found this on Tally Genicom's Website about your device.
Technical Services Note
MT6xx/T6xxx (All) Paper Motion Faults 11 May 1995
T645.039
If you are having problems with recurring Paper Motion Faults that don’t seem to stay
fixed by doing the paper motion sensor calibration, try the following:
· Check the back of the form along the left side to ensure there are no black (dark) areas
in the area of the tractor drive holes. (If there are, this is probably the problem. If not,
proceed on down this list.)
Clean the sensor on the upper left tractor then run the calibration routine again. If it’s
not better yet, continue.
With Tech Access ON, do the following:
Go into DIAG - Meters - Paper Motion and monitor the sensor reading with paper
installed and removed. If the reading with paper installed is in the 300 to 350 mVolt
range, change the sensor (even if it seems to run the calibration alright). A more
normal reading would be something greater than 600 mVolts for the MT691/6092 and
1000mVolts or greater in the 645/661. Don’t forget to recalibrate the sensor. If it’s
not fixed yet, try this next step.
Run a configuration printout and then do the following:
1. Clear the NV Ram (Tech Access feature ON)
2. Calibrate the Paper Motion and Paper Out sensors
3. Restore the configuration based on the print-out you just ran
http://www.tallygenicom.com/support/technotes/tnote/d5639.pdf
my site: www.techvisitor.com
Posted on Oct 31, 2008
SOURCE: paper width error on tally genicom 2280+ printer
Power ON printer holding down ONLINE button, release it after TESTMENU is on display. Press NEXT few times, enter APM or somthing like that (or APW? cant remember), switch it to OFF. Press ONLINE. Thats it! Greetings.
ps. this is procedure direct from polish division of tallygenicom servicedesk. it works for me perfectly!!
Posted on Jan 28, 2009
SOURCE: "check ribbon " error is comming on my tally 2280+ serialprinter
The ribbon I had installed (code 061627) which says it is the correct one is in fact not. the drive pin on the printer slips while feeding the ribbon.
I have fitted a (code 062471) and now it is printing fine again.
a google search reports both these codes as compatible but they are quite clearly, not.
Posted on Mar 11, 2009
Ribbon fault error
First of all sorry for the problem.
It seems to be a logic card problem . Kindly contact with lipi for replacement of the logic card.
Aug 16, 2012 | Tally T6215 Matrix Printer
I have a tally genicom 6312 printer which gives me hammer voltage 2 error what do i do
A high resistance coil fault has likely occurred in one or more of the hammer coils.
Note: this fault message will have been preceded by printing slow-down attempts associated with On-
The-Fly thermal monitoring of hammer bank temperature.
Check the hammer bank for defective coils.
If no defective coils are found replace the Controller Board.
Dec 31, 2010 | Tally T6218 Matrix Printer
T6312
The problem coming from your logic card hammer bank cable . Need to be replace logic card and hammer bank cable.
May 19, 2010 | TallyGenicom 6312 Matrix Printer
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
Printer-Genicom 2280+ Printer stopped then continued working, often on LCD Hardware error. When turn on printer- on LCD AGA Error.
The AGA Error on the 2280+ indicates the Automatic Gap adjust is not working.
This may be caused buy;
An obstruction (eg paper jam, ribbon etc) preventing the AGA from working correctly.
The AGA flag becoming detached from the printer or damaged
An incorrectly fitted print head
Fault AGA sensor.
You can overcome the AGA error by disabling the AGA and manually setting the print had gap.
To disable the AGA
Power the pritner on holding down ONLINE, keep ONLINE held down whilst the printer initializes.
When the printer displays ASCII80 ASCII136 release ONLINE
Press NEXT until you see AGA
Select AGA and set this to OFF
You can then manually adjust the print head gap in the normal menu.
Menu>Adjust>Head change the value to increase or decrease the head gap as required.
Jul 21, 2009 | Tally Matrix T2280 Printer
Tally T2250 showing an error..
when power on the printer the printer coming leftside and showing hardware alarm
check ribbon
+0306ne -007 000
000000128 +0304
error in display. how to rectifie the problem
Jan 29, 2009 | Tally T2250 Matrix Printer
Jan 24, 2009 | TallyGenicom 2280 Matrix Printer
Bad print out
I would recomend checking the ribbon cartride fitted in the pritner. Ensure the ribbon is correctly mounted on the ribbon drive shaft.
Ensure the ribbon is not jammed.
Ensure the print head gap is not set to close the ribbon is becomming jammed
Try changing the ribbon cartridge for a new one.
Dec 30, 2008 | TallyGenicom 2348 24WIRE 480CPS Draft 136...
Paper width error on tally genicom 2280+ printer
Mar 12, 2008 | TallyGenicom 2280 Matrix Printer
Print stops after 2 pages !
Hi my tally printer 6218 giving Ribbon motion fault, what could be done to remedy this error message ?
Jan 19, 2008 | Tally T6218 Matrix Printer
TallyGenicom 6306 Matrix Printer Logo
388 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
