Question about LG RUMOR Cellular Phone
Earpiece Won't work
I was using my phone that day, then someone called me when i said hi nothing happened. i hung up and nothing happened no sound. Not even the button sounds. I tried playing music recordings and it worked, so i guess that the speakers work but not the earpiece. I turned off the phone and the phone chime thingy also was playing. I turned it back on and nothing still worked. What should I do?
  • Anonymous Mar 12, 2014
    I have a Samsung Galaxy Ace II. I have the alarm set to go off to gentle music each morning at 7 am. This happens. But the music keeps playing and playing. Even once I turn the alarm off or if I hit the snooze button. Music plays and plays until I restart the phone. It's driving me nuts! Any suggestions?
Enable yoiur bluetooth
Posted on Jan 23, 2009
  • Shaye Charl
    Shaye Charl Jan 06, 2014
    really?
  • Shaye Charl
    omg that worked! how did you know?! THANK YOU!!!!
When ever i call someone i cant use the front screen because they can hear me but i cant hear them unless i have them on speaker its verry inconvenient what should i do to fix this ?
Problem is with your phone's speaker it is bad and needs to be either worked on or replaced. But another issue is that, something might be blocking the earpiece hole, making the phone to view the intrusion as an actual earpiece insert an earpiece to confirm that nothin is blocking it.
If notin is bocking it, then take care of the faulty speaker.
You could get it fixed at a local repairer's.
But pending that time, if you have a handsfree device, use it to make your calls for convenience sake.
I hope I was able to help?
Have a great day.
Jun 01, 2011 | LG enV3 VX9200 Cell Phone
You cant here the dialing ton when calling someone
Hi, when you try to call and you don't hear a dial tone,is because the ear piece that makes you hear some one calls you is damaged and will need to be replaced.
Usually gets damaged by itself and to replace the earpiece, you will need to disassemble the phone to be able to replace the hear piece.
The earpiece is located atthe top head of all phones. And is easily to locate.
When you replace the earpiece you cannowhear the dial tone on your phone.
Thanks for using fixya.,.
Jan 11, 2011 | Cell Phones
Having problem with my Motorola V365. I can not hear anything on phone. need to use speaker Help
Hi, The earpiece of the phone you are using is bad. The earpiece is a small speaker inside the phone that allows you to hear when someone calls. It is collected close to where you put your ear when you are making calls.
When you replace the earpiece, the phone will work properly.
Have a nice day.
Sep 25, 2010 | Motorola Mobility V365 Cellular Phone
Hi, When someone calls me, I can only speak on speakerphone. My G1 ear piece is not working properly. PLEASE PEOPLE, I NEED SOME SERIOUS HELP THANK YOU!!!
Hi, When you make calls and you people hardly you, It means that the earpiece which allows you to hear
people that is located at the top of the phone if faulty and needs to be replaced with another one.
Have a nice day.
Sep 12, 2010 | HTC G1 Smartphone
I have no sound what so ever on my phone, i cant even make phone calls as i hear nothing but the person on the other end of the line can hear me fine!!!!!
Hi
I think the problem you are experiencing has to do with the earpiece of your phone.All you need to do is to get to a phone store and replace the earpiece so that your phone can work perfectly again.
GOODLUCK
Jun 23, 2010 | Samsung Tocco Ultra Cell Phone
Can't hear voice calls on my Samsung Tocco Ultra
The problem with your phone is that the earpiece of your phone is bad, that is why you cannot hear anything while you call or if you are called.
All you need to do is to change the earpiece of your phone and you will see that after changing it, you can hear when people call or when you are called.
Replace the earpiece as said and you will see that your communication with other people on the phone will move smoothly.
Take care.
May 06, 2010 | Samsung Tocco Ultra Cell Phone
I can't hear the person talking on the phone earpiece. The volume is on high and the speaker phone works fine?
Sir/Maam,
It can be that the earpiece is broken. Try calling someone without using any earpiece, if that works that proves the earpiece is damaged or broken.
If that doesn't work, then the speaker in your phone must be damaged.
Hope i helped you, thanks.
Feb 27, 2010 | Cell Phones
My LG vx-8700 vibrates, but no sound works on the phone. The caller can hear me, but I hear nothing (ringing, caller, voicemail, etc.) EXCEPT through the earpiece. I CAN hear all through the earpiece, but...
I just had this same problem. It is a hardware issue. Call verizon back explain the situation, they will call your phone to verify that the mic and speaker aren't working and they will send you a replacement within 2 days.
A temporary solution is plugging a wired headset into the phone and taking it out, it will work for a few hours.
Aug 06, 2009 | LG Car Charger For VX8700, VX8800 Venus,...
Earpiece on phone has no sound coming out. can talk but can't hear
i have that problem too. using the speakerphone will help but calls arent clear..
Nov 01, 2007 | Motorola Mobility i870 Cellular Phone
Is it mic problem or audio ic problem
Hi, speaker on handsfree is normally seperate from earpiece, earpiece speaker may need replacing. Had same prob with Motorola V575. Hope this helps.
Nov 11, 2006 | Sony Ericsson K750
LG RUMOR Cellular Phone Logo
230 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
